    2nd MagicMirror
    11 Posts 2 Posters 5.8k Views 2 Watching
      Ray
      So I have my 1st magicmirror completed for quite some time now and it works perfectly. it Does everything I want. Good job guys on creating all the modules for it. I normally start it by using a very simple script, inside is
      pm2 start MagicMirror
      and it’s executed in terminal mode
      I want to create another magicmirror from scratch. but I want to keep the one I have
      I could call my new one magicmirror2, When it’s completed
      I would like to be able to start either 1 by using pm2 . If this is possible
      can you please tell me how to do this
      has anybody tried this
        sdetweil @Ray
        @Ray sure. make another script in the installers folder, mm.sh is the current one
        fix the pm2_MagicMirror.json
        name and script name
        then
        pm2 start pm2_MagicMirror.json
        then pm2 save
        note you can use a different config file on the same install to run two different instances
        for example
        mm1.sh
        #!/bin/bash
        # This file is still here to keep PM2 working on older installations.
        cd ~/MagicMirror
        export MM_CONFIG_FILE=config/config.js
        DISPLAY=:0 npm start
        and mm2.sh
        #!/bin/bash
        cd ~/MagicMirror
        export MM_CONFIG_FILE=config/config2.js
        the pm2_MagicMirror.json (from my scripts repo)
          "apps" : [{
            "name"        : "MagicMirror",
            "script"      : "/home/pi/MagicMirror/installers/mm.sh",
            "watch"       : ["/home/pi/MagicMirror/config/config.js"]
        change the name and the paths
          Ray @sdetweil
          @sdetweil okay I think I understand. I will give it a try . I am going to make my new magic mirror in a couple of days
          wanted feedback 1st before I start
          I appreciate the response
          I will let you know how it goes
            sdetweil @Ray
            @Ray my install and fixuppm2.sh scripts use the pm2_MagicMirror.json to give the app a good name
            (instead of mm.sh)
            pm2 status shows the names of the managed apps.
            pm2 info (appname or number) give all the info about it
            pm2 --help shows all it can do
              Ray @sdetweil
              @sdetweil okay I think I get it
              so just to make sure my current magic mirror folder is called
              I will be renaming that MagicMirror_1st_mirror
              not shouldn’t hurt anything. It should start as normal
                sdetweil @Ray
                @Ray you don’t have to make a new folder, only a new config file
                  Ray @sdetweil
                  @sdetweil I am aware of that. now Sam, I did not know we could do all that.
                  In the future I will have 2 options now
                  But following your instructions that you gave me
                  I wanted to thank you very much for the help that you gave me
                  I followed your instructions that you gave me after several tries, I now have
                  2 MagicMirror folders one is labeled MagicMirror and the 2nd 1 I labeled
                  MagicMirror_First_Mirror
                  and both folders are now listed in pm2
                  │ 1 │ FirstMirror │ fork │ 0 │ stopped │ 0% │ 0b │
                  │ 0 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b
                  Thank you very much for your help.
                  I would be happy to post my procedures. for other beginners If you like.
                  Just let me know and I will post it here. It’s my way of giving back to this site for all the hard work everyone does
                    sdetweil @Ray
                    @Ray cool! glad you got it working
                    did u actually create two directories (folders) with Magic mirror installed ?
                    you didnt have to do that… just different start scripts using different config files
                      Ray @sdetweil
                      @sdetweil I understand that now, but I already made it
                      and it works perfectly. in the future I will have 2 choices now
                      The reason I was looking for something like this. I want to generate a separate mirror for testing. That way if it crashes I won’t have to worry about it because all files and folders will be separated from the 2nd mirror folder
                      the 2 separate magic mirrors will work perfectly for me. I will definitely consider your 2nd option. In the future
                        sdetweil @Ray
                        @Ray ok, understood
                          Ray @sdetweil
                          @sdetweil :thumbs_up:
