2nd MagicMirror
11 Posts 2 Posters 3.7k Views 2 Watching
    Ray
    So I have my 1st magicmirror completed for quite some time now and it works perfectly. it Does everything I want. Good job guys on creating all the modules for it. I normally start it by using a very simple script, inside is
    pm2 start MagicMirror
    and it’s executed in terminal mode
    I want to create another magicmirror from scratch. but I want to keep the one I have
    I could call my new one magicmirror2, When it’s completed
    I would like to be able to start either 1 by using pm2 . If this is possible
    can you please tell me how to do this
    has anybody tried this
    S 1 Reply Last reply Mar 26, 2022, 11:19 PM Reply Quote 0
      sdetweil @Ray
      @Ray sure. make another script in the installers folder, mm.sh is the current one
      fix the pm2_MagicMirror.json
      name and script name
      then
      pm2 start pm2_MagicMirror.json
      then pm2 save
      note you can use a different config file on the same install to run two different instances
      for example
      mm1.sh
      #!/bin/bash
      # This file is still here to keep PM2 working on older installations.
      export MM_CONFIG_FILE=config/config.js
      DISPLAY=:0 npm start
      and mm2.sh
      #!/bin/bash
      export MM_CONFIG_FILE=config/config2.js
      the pm2_MagicMirror.json (from my scripts repo)
        "apps" : [{
          "name"        : "MagicMirror",
          "script"      : "/home/pi/MagicMirror/installers/mm.sh",
          "watch"       : ["/home/pi/MagicMirror/config/config.js"]
      change the name and the paths
      R 1 Reply Last reply Mar 26, 2022, 11:48 PM Reply Quote 1
        Ray @sdetweil
        @sdetweil okay I think I understand. I will give it a try . I am going to make my new magic mirror in a couple of days
        wanted feedback 1st before I start
        I appreciate the response
        I will let you know how it goes
        S 1 Reply Last reply Mar 26, 2022, 11:50 PM Reply Quote 0
          sdetweil @Ray
          @Ray my install and fixuppm2.sh scripts use the pm2_MagicMirror.json to give the app a good name
          (instead of mm.sh)
          pm2 status shows the names of the managed apps.
          pm2 info (appname or number) give all the info about it
          pm2 --help shows all it can do
          R 1 Reply Last reply Mar 27, 2022, 12:02 AM Reply Quote 0
            Ray @sdetweil
            @sdetweil okay I think I get it
            so just to make sure my current magic mirror folder is called
            I will be renaming that MagicMirror_1st_mirror
            not shouldn’t hurt anything. It should start as normal
            S 1 Reply Last reply Mar 27, 2022, 12:12 AM Reply Quote 0
              sdetweil @Ray
              @Ray you don’t have to make a new folder, only a new config file
              R 1 Reply Last reply Mar 28, 2022, 8:36 AM Reply Quote 0
                Ray @sdetweil
                @sdetweil I am aware of that. now Sam, I did not know we could do all that.
                In the future I will have 2 options now
                But following your instructions that you gave me
                I wanted to thank you very much for the help that you gave me
                I followed your instructions that you gave me after several tries, I now have
                2 MagicMirror folders one is labeled MagicMirror and the 2nd 1 I labeled
                MagicMirror_First_Mirror
                and both folders are now listed in pm2
                │ 1 │ FirstMirror │ fork │ 0 │ stopped │ 0% │ 0b │
                │ 0 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b
                Thank you very much for your help.
                I would be happy to post my procedures. for other beginners If you like.
                Just let me know and I will post it here. It’s my way of giving back to this site for all the hard work everyone does
                S 1 Reply Last reply Mar 28, 2022, 12:37 PM Reply Quote 0
                  sdetweil @Ray
                  @Ray cool! glad you got it working
                  did u actually create two directories (folders) with Magic mirror installed ?
                  you didnt have to do that… just different start scripts using different config files
                  R 1 Reply Last reply Mar 28, 2022, 2:12 PM Reply Quote 0
                    Ray @sdetweil
                    @sdetweil I understand that now, but I already made it
                    and it works perfectly. in the future I will have 2 choices now
                    The reason I was looking for something like this. I want to generate a separate mirror for testing. That way if it crashes I won’t have to worry about it because all files and folders will be separated from the 2nd mirror folder
                    the 2 separate magic mirrors will work perfectly for me. I will definitely consider your 2nd option. In the future
                    S 1 Reply Last reply Mar 28, 2022, 4:07 PM Reply Quote 1
                      sdetweil @Ray
                      @Ray ok, understood
                      R 1 Reply Last reply Mar 28, 2022, 4:13 PM Reply Quote 0
