    MMM-GroveGestures -> ShellExec "Python script"
    3 Posts 2 Posters 1.1k Views 2 Watching
    • Robert_KR Offline
      Robert_K
      Good day fellow builders,
      I’m building my second MagicMirror and it works for 95%.
      I’m using the MMM-GroveGesture module to switch between Pages (MMM-Pages and MMM-Page indicator).
      I’m having WS2801 LED’s connected. For these LED’s I wrote two Python scripts. When executing the python scripts in the RPI (4) terminal they work flawless.
      However I want to activate the scripts by the gestures. So with the up gesture, switching on the LED’s, and with the down gesture, switching them off.
      Reading the MMM-Grove Gesture module readme I can use three types of executions:
      • shellExec: “…”,
      • notificationExec: { … },
      • moduleExec: { … },
      Now I’m a bit lost. I tried to use the shellExec command, but it does not start my python script. If I change it to for example ‘sudo reboot now’ the execution of the gesture does work. Here is (a part) of my config file:
       			module: "MMM-GroveGestures",
      					autoStart: true, //When Mirror starts, recognition will start.
      					gestureMapFromTo: { //When your sensor is installed with rotated direction, you can calibrate with this.
      										"Up": "RIGHT",
      										"Down": "LEFT",
      										"Left": "UP",
      										"Right": "DOWN",
      										"Forward": "FORWARD",
      										"Backward": "BACKWARD",
      										"Clockwise": "CLOCKWISE",
      										"anti-clockwise": "ANTICLOCKWISE",
      										"wave": "WAVE"
      					defaultNotification: "GESTURE",
      					pythonPath: "/usr/bin/python", // your python path
      					defaultCommandSet: "default",
      					commandSet: {
      								"default": {
      											"LEFT": {
      											notificationExec: {
      											notification: "PAGE_INCREMENT",
      											payload: null
      											"RIGHT": {
      											notificationExec: {
      											notification: "PAGE_DECREMENT",
      											payload:null,
      											"UP": {
      											shellExec: "sudo reboot now",
      											"DOWN": {
      											shellExec: "python ws2801_uitschakelen.py",
      So I’m wondering, how to start my python script with this module? Anyone can point me in the right direction? Thanks in advance.
      Regards Robert
        sdetweil @Robert_K
        @Robert_K
        sorry, jumped too fast… you want to know HOW to launch
        see my PythonPrint module which launches a python script …
        https://github.com/sdetweil/MMM-PythonPrint
        well. actually its probably the first…
        https://forum.magicmirror.builders/topic/16554/mmm-pythonprint-customisation/2?_=1648232499718
        the gesture node_helper does exec
        so the same command you would do from the commandline…
        but python has trouble with libraries when invoked in the background…
        • Robert_KR Offline
          Robert_K
          So after some thinkering with the hint I got, I’ve got the code working:
          "UP": {
          shellExec: "python /home/pi/ws2801_inschakelen.py",
          "DOWN": {
          shellExec: "python /home/pi/ws2801_uitschakelen.py",
          Thanks for the help!
