How do I know if a monitor is suitable for a MagicMirror
I would guess an IPS panel would be much better than a TN one, right? Better viewing angles and more brightness(like nits wise). I don’t think I need to worry about refresh rate or something but higher resolution would be better I guess.
am I on the right track so far :)
@oraturk75 My rules:
Must plug HDMI into the bottom, top, or side, not the back. (Flat against the case)
Must have VESA Mounting if I keep the shell on.
Must remember if it’s on or off through power outage.
@MMRIZE I just bought a couple of those for a mirror I was building where the monitor I had on hand had rear-facing HDMI ports. They work. But they do add some depth. Also, it constrains you a bit on where you put your Pi if you’re using short HDMI cables.
But yes, they do work.
@oraturk75 said in How do I know if a monitor is suitable for a MagicMirror:
I have just seen a post where the guy purchased a naked LCD panel then a separate controller board and a power supply; rather than taking the plastic cover off from a full blown monitor.
I did something like this for another project (Retro arcade in a briefcase). I used an old laptop and ripped the LCD out, bought a controller board off Ebay and then powered it via direct 12v input. It’s definitely possible.
My only caution is that the ribbon cable connecting the controller board to the LCD was easily detached from the monitor. Solvable with a little tape, but do watch for it.
