    NODE.JS problem after 2.19
    4 Posts 3 Posters 977 Views 3 Watching
      selyjohns
      My MM doesn’t work anymore since last update this morning.
      It seem to be a problem with PIR SENSOR module. Look like a problem with the version of node.js, but my knowledge is too bad to understand the problem…
      Can someone could help me please ?
      Thank you in advance.
      Here’s the pm2 logs.
      /home/pi/.pm2/logs/mm-out.log last 15 lines:
      0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|mm       |
      0|mm       | [02.04.2022 12:16.33.654] [LOG]   Starting MagicMirror: v2.19.0
      0|mm       | [02.04.2022 12:16.33.674] [LOG]   Loading config ...
      0|mm       | [02.04.2022 12:16.33.691] [LOG]   Loading module helpers ...
      0|mm       | [02.04.2022 12:16.33.843] [LOG]   Initializing new module helper ...
      0|mm       | [02.04.2022 12:16.33.849] [LOG]   Module helper loaded: MMM-ModuleScheduler
      0|mm       | [02.04.2022 12:16.33.914] [LOG]   Loading module helpers ...
      0|mm       | [02.04.2022 12:16.33.918] [LOG]   Initializing new module helper ...
      0|mm       | [02.04.2022 12:16.33.923] [LOG]   Module helper loaded: MMM-ModuleScheduler
      0|mm       | [02.04.2022 12:16.34.531] [LOG]   Launching application.
      0|mm       |
      0|mm       | > magicmirror@2.19.0 start
      0|mm       |
      0|mm  | [02.04.2022 12:20.46.159] [LOG]
      0|mm  | Starting MagicMirror: v2.19.0
      0|mm  | [02.04.2022 12:20.46.181] [LOG]
      0|mm  | Loading config ...
      0|mm  | [02.04.2022 12:20.46.197] [LOG]
      0|mm  | Loading module helpers ...
      0|mm  | [02.04.2022 12:20.46.348] [LOG]
      0|mm  | Initializing new module helper ...
      0|mm  | [02.04.2022 12:20.46.353] [LOG]
      0|mm  | Module helper loaded: MMM-ModuleScheduler
      0|mm  | [02.04.2022 12:20.46.415] [ERROR]
      0|mm  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
      0|mm  | was compiled against a different Node.js version using
      0|mm  | NODE_MODULE_VERSION 93. This version of Node.js requires
      0|mm  | NODE_MODULE_VERSION 101. Please try re-compiling or re-installing
      0|mm  | the module (for instance, using `npm rebuild` or `npm install`).
      0|mm  | [02.04.2022 12:20.46.419] [LOG]
      0|mm  | [02.04.2022 12:20.46.422] [LOG]
      0|mm  | [02.04.2022 12:20.46.428] [LOG]
      0|mm  | [02.04.2022 12:20.46.457] [ERROR]
      0|mm  | App threw an error during load
      0|mm  | [02.04.2022 12:20.46.461] [ERROR]
      0|mm  | Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
      0|mm  |     at process.func [as dlopen] (node:electron/js2c/asar_bundle:5:1800)
      0|mm  |     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1199:18)
      0|mm  |     at Object.func [as .node] (node:electron/js2c/asar_bundle:5:1800)
      0|mm  |     at Module.load (node:internal/modules/cjs/loader:988:32)
      0|mm  |     at Module._load (node:internal/modules/cjs/loader:829:12)
      0|mm  |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      0|mm  |     at Module.require (node:internal/modules/cjs/loader:1012:19)
      0|mm  |     at require (node:internal/modules/cjs/helpers:102:18)
      0|mm  |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:112:48)
      0|mm  |     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31
      0|mm  | [02.04.2022 12:20.46.465] [ERROR]
      0|mm  | Whoops! There was an uncaught exception...
      0|mm  | [02.04.2022 12:20.46.481] [ERROR]
      0|mm  |     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31 {
      0|mm  |   code: 'ERR_DLOPEN_FAILED'
      0|mm  | }
      0|mm  | [02.04.2022 12:20.46.486] [ERROR]
      0|mm  | MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm  | [02.04.2022 12:20.46.488] [ERROR]
      0|mm  | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm  | [02.04.2022 12:20.47.011] [LOG]
      0|mm  | Launching application.
      0|mm  | [27831:0402/122047.955144:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
      0|mm  | [27864:0402/122048.123836:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
        selyjohns
        Please look like at
        https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/24?_=1648901728548
        So no solution.
        Problem “solved”.
        Nice day.
        • T Offline
          tanvir586 @selyjohns
          @selyjohns hi can you try
          Cd MagicMirror/modules/MMM-PIR-Sensor
          And then
          npm i magicmirror-rebuild
          Then
          ./node_modules/.bin/MagicMirror-rebuild
          It might work.
            sdetweil @tanvir586
            @tanvir586 said in NODE.JS problem after 2.19:
            MagicMirror-rebuild author said because this module is archived, he won’t fix his rebuild tool for it anymore
