    Cannot find module 'module-alias/register'
    3 Posts 2 Posters 1.1k Views 2 Watching
    • N
      NoRoots
      Hey Guys!
      I want to run MagicMirror headless on a Raspberry Pi 4, running Raspian Lite, and show the actual Content on a spare iPad.
      I followed the Setup tutorial but now i´m stuck with this message:
      pi@raspberrypi:~/MagicMirror $ npm run server
      > magicmirror@2.19.0 server
      > node ./serveronly
      node:internal/modules/cjs/loader:936
        throw err;
      Error: Cannot find module 'module-alias/register'
      Require stack:
      - /home/pi/MagicMirror/serveronly/index.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
          at Module.require (node:internal/modules/cjs/loader:1005:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:9:1)
          at Module._compile (node:internal/modules/cjs/loader:1103:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
          at Module.load (node:internal/modules/cjs/loader:981:32)
          at Function.Module._load (node:internal/modules/cjs/loader:822:12)
          at Module.require (node:internal/modules/cjs/loader:1005:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/serveronly/index.js'
      The Config file is pretty vanilla, these are the changes i made to access MM from a Browser.
      let config = {
              address: "0.0.0.0",     // Address to listen on, can be:
              port: 8081,
              basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              ipWhitelist: [],
      What am i missing here? There are some threads regarding this error, but all of them are about an incomplete update, missing the “npm install” part. since this is a fresh setup and i did the install part, i can rule that one out.
      Thanks for your Help!
      BR
      • N
        NoRoots @sdetweil
        yes, i did the npm install after git clone.
        I tried both versions:
        npm install --only=prod --omit=dev //as seen in the tutorial
        npm install // as seen in the forum
        damnit…
        i just did npm install again, and now it works.
        Thanks!
        The iPad is an Gen. 8 with the latest iOS. it works just fine!
          sdetweil @NoRoots
          @NoRoots did u do the npm install ? after git clone?
          probably can’t use older ipad.
          it doesn’t support the latest JavaScript idioms the mm code uses. es6…
          • N
            NoRoots @sdetweil
            damnit…
            Thanks!
