    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 16.3k Views 3 Watching
      sdetweil @Richard238
      @Richard238 right. MagicMirror is running. you have to stop it before u can update
      as it appears we need to upgrade node and npm as well…
      pm2 stop all
        Richard238 @sdetweil
        @sdetweil And then rerun the script?
          @Richard238 yes
            Richard238
            pi@magicmirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            No LSB modules are available.
            doing test run = true, NO updates will be applied!
            update log will be in /home/pi/MagicMirror/installers/upgrade.log
            Check current Node installation ...
            Node currently installed. Checking version number.
            Minimum Node version: v16.9.1
            Installed Node version: v16.1.0
            Node should be upgraded.
            Node.js upgrade defered, doing test run
            Check current NPM installation ...
            NPM currently installed. Checking version number.
            Minimum npm version: V7.11.2
            Installed npm version: V7.11.2
            No npm upgrade necessary.
            saving custom.css
            upgrading from version 2.18.0 to 2.19.0
            fetching latest revisions
            there are 5 local files that are different than the master repo
               config/config.js.sample
               fonts/package-lock.json
               modules/default/newsfeed/newsfeed.js
               package-lock.json
               vendor/package-lock.json
            any *-lock.json files do not need to be saved
            do you want to save these files for later   (Y/n)?
            Checking for modules with removed libraries
            processing dependency changes for active modules with package.json files
            processing for module MMM-MysqlQuery please wait
            skipped processing for MMM-MysqlQuery, doing test run
            processing complete for module MMM-MysqlQuery
            restoring custom.css
            test run, restoring files stashed
            pi@magicmirror:~ $
              Richard238
              pi@magicmirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
              doing test run = false
              Installing Node.js ...
              gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
              Reading package lists... Done
              Building dependency tree
              Reading state information... Done
              nodejs is already the newest version (17.3.1-deb-1nodesource1).
              The following package was automatically installed and is no longer required:
                python-colorzero
              Use 'sudo apt autoremove' to remove it.
              0 upgraded, 0 newly installed, 0 to remove and 63 not upgraded.
              node version is
              Node.js installation Done! version=v16.1.0
              saving custom.css
              there are 2 local files that are different than the master repo
              updating MagicMirror runtime, please wait
              > magicmirror@2.19.0 install
              > echo "Installing vendor files ...
              > " && cd vendor && npm install --loglevel=error
              changed 3 packages, and audited 10 packages in 22s
              found 0 vulnerabilities
              > magicmirror@2.19.0 postinstall
              > npm run install-fonts && echo "MagicMirror² installation finished successfully!
              > magicmirror@2.19.0 install-fonts
              > echo "Installing fonts ...
              > " && cd fonts && npm install --loglevel=error
              added 2 packages, removed 1 package, and audited 3 packages in 5s
              > magicmirror@2.19.0 prepare
              > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
              no husky installed.
              added 3 packages, removed 4 packages, changed 35 packages, and audited 266 packages in 2m
              20 packages are looking for funding
                run `npm fund` for details
              npm notice
              npm notice New major version of npm available! 7.11.2 -> 8.6.0
              npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.6.0>
              npm notice Run `npm install -g npm@8.6.0` to update!
              npm notice
              npm ERR! code ERESOLVE
              npm ERR! ERESOLVE unable to resolve dependency tree
              npm ERR!
              npm ERR! While resolving: mmm-mysqlquery@1.0.0
              npm ERR! Found: stylelint@8.4.0
              npm ERR! node_modules/stylelint
              npm ERR!   dev stylelint@"^8.3.0" from the root project
              npm ERR!
              npm ERR! Could not resolve dependency:
              npm ERR! peer stylelint@"14.x" from grunt-stylelint@0.18.0
              npm ERR! node_modules/grunt-stylelint
              npm ERR!   dev grunt-stylelint@"latest" from the root project
              npm ERR!
              npm ERR! Fix the upstream dependency conflict, or retry
              npm ERR! this command with --force, or --legacy-peer-deps
              npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
              npm ERR!
              npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
              npm ERR!     /home/pi/.npm/_logs/2022-04-08T13_34_50_165Z-debug.log
              we stashed a set of files that appear changed from the latest repo versions. you should review them
              see installers/stashed_files for the list
              you can use git checkout stash@{0} -- filename to extract one file from the stash
              or git stash pop to restore them all
              WARNING..
              WARNING.. either will overlay the file just installed by the update
              WARNING..
              pi@magicmirror:~ $
                Richard238
                Then did
                pm2 start all
                and now have a black screen on the Pi, and ‘Unable to connect’ on the desktop browser. :-(
                  @Richard238 not pm2 start all
                  pm2 status
                  will show u the defined apps
                  pm2 start ??
                  where ?? is the name of the number of the app
                  (usually 0)
                  pm2 stop all just is a shortcut
                  pm2 --help shows u all the things it can do.
                  but the black screen could be because of the module rebuild failure
                  pm2 logs – lines=100 might show more info
                  and then there’s this
                  my upgrade tries to handle the ones we know about
                    Richard238
                    @Richard238 said in Updating did nothing but gave fatal error warning.:
                    MMM-MysqlQuery
                    MMM-MysqlQuery seems to be the issue, I’ve commented it out of config .js,
                    Will that be ok if I try pm2 start again?
                      @Richard238 yes
                        Richard238
                        OK that’s brought MM back to life, but my custom CSS seems to have been ignored.
                        That, and I need new weather modules?!
                        • 4 / 5
