    MMM-PoemOfTheDay show standard, but no german language!
    8 Posts 2 Posters 1.7k Views 2 Watching
    • lolobyteL Offline
      lolobyte
      When trying to switch to German “de” language, pm log say’s:
      There was an error filteringByLanguage, returning all poems
      Any ideas?
        sdetweil @lolobyte
        @lolobyte the doc says you need another API key
        lolobyteL 1 Reply Last reply Reply Quote 0
        • lolobyteL Offline
          lolobyte @sdetweil
          Thank you for your quick response.
          Here is a part of my config…
          I have already inserted the api-key.
                                  module: "MMM-PoemOfTheDay",
                                  position: "lower_third",
                                          textLimit: 1000,
                                          lineLimit: 10,
                                          detectLanguageApiKey: "{xxxxxxxxxxxxxxxx}",
                                          languageSet: ["de"],    //["en", "es"]
                                          updateInterval: 120000,
            sdetweil @lolobyte
            @lolobyte I don’t believe the apiKey should be in braces. that is usually used to indicate replacement from a variable
            • lolobyteL Offline
              lolobyte @sdetweil
              ok, you’re right.
              The braces.
              Resolved.
              Thanks a lot.
                sdetweil @lolobyte
                @lolobyte I opened this issue on the module GitHub page
                https://github.com/Steven-Gassert/MMM-PoemOfTheDay/issues/13
                • lolobyteL Offline
                  lolobyte @sdetweil
                  Good idea.
                  I made it like the example on the github page.
                    detectLanguageApiKey: "{API_KEY}",
                    sdetweil @lolobyte
                    @lolobyte I know, but that is incorrect…
                    my open issue asks to change the doc
