    When clock module is displayed it shifts other modules
    5 Posts 2 Posters 764 Views 2 Watching
    • T Offline
      Tavros
      Hi, when the original clock module is shown (top bar) it pushes all other modules down. Can this be changed in the css? if yes how? Then I still have the following problem: if the module Openmap-weather is active and the module Globe disappears the module Weather after 1 sek. Can it be helped?
        sdetweil @Tavros
        @Tavros each area is a stack.
        1st in position in config.js will be at the top of that position
        next at that position will be below the 1st …
        etc
        T 2 Replies Last reply Reply Quote 0
        • T Offline
          Tavros @sdetweil
          @sdetweil ok i will try. Unfortunately I can’t post any pictures as I’m writing from a cell phone. Try tomorrow
          • T Offline
            Tavros @sdetweil
            @sdetweil ![a.jpg]
            • T Offline
              Tavros @Tavros
              Irgendwie können hier Bilder nicht hochgeladen werden. Habe die Anordnung in der config geändert aber wenn das Modul “Zeit” eingeblendet wird verschieben sich alle restlichen Module nach unten.
