HELP -- MMM-calendarExt2 was not displayed
Good day,
I screwed together a Raspi3 with the MagicMirror š
If I have installed all the modules I want, they are also displayed well.
The calendarExt2 was also running until yesterday
For whatever reason, this is no longer displayed.
To check, I entered the standard calendar with the URL of the calendar, itās not because of the URL.
Nothing else was changed.Does anyone have a tip where I could still look why the MMM-calendarExt2 is not displayed?
I look forward to tips. -
@SARCux open the dev window and see what errors show in the console
npm start dev -
[16.04.2022 21:43.37.262] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast] [16.04.2022 21:43.37.264] [LOG] Connecting socket for: MMM-CalendarExt2 [16.04.2022 21:43.37.268] [LOG] Sockets connected & modules started ... [16.04.2022 21:43.37.716] [ERROR] Whoops! There was an uncaught exception... [16.04.2022 21:43.37.737] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080 at Server.setupListenHandle [as _listen2] (node:net:1334:16) at listenInCluster (node:net:1382:12) at GetAddrInfoReqWrap.doListen [as callback] (node:net:1520:7) at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) { code: 'EADDRINUSE', errno: -98, syscall: 'listen', address: '127.0.0.1', port: 8080 } -
i don“t know whats wrong :worried_face:
@SARCux something on your system is already using port 8080, is there a instance of MagicMirror not closed correctly? either restart the pi or change the port in the config file
change the port in config and now this
[16.04.2022 21:49.40.284] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast] [16.04.2022 21:49.40.286] [LOG] Connecting socket for: MMM-CalendarExt2 [16.04.2022 21:49.40.290] [LOG] Sockets connected & modules started ... [16.04.2022 21:49.40.733] [ERROR] Whoops! There was an uncaught exception... [16.04.2022 21:49.40.751] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8082 at Server.setupListenHandle [as _listen2] (node:net:1334:16) at listenInCluster (node:net:1382:12) at GetAddrInfoReqWrap.doListen [as callback] (node:net:1520:7) at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) { code: 'EADDRINUSE', errno: -98, syscall: 'listen', address: '127.0.0.1', port: 8082 } -
@SARCux try address 0.0.0.0 and restart the pi
@swvalenti ```
[16.04.2022 21:53.09.202] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
[16.04.2022 21:53.09.204] [LOG] Connecting socket for: MMM-CalendarExt2
[16.04.2022 21:53.09.207] [LOG] Sockets connected & modules started ā¦
[16.04.2022 21:53.09.227] [ERROR] Whoops! There was an uncaught exceptionā¦
[16.04.2022 21:53.09.241] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8082
at doListen (node:net:1520:7)
at processTicksAndRejections (node:internal/process/task_queues:84:21) {
code: āEADDRINUSEā,
errno: -98,
syscall: ālistenā,
address: ā0.0.0.0ā,
port: 8082
@SARCux Are you running MagicMirror with pm2? Or manually?
Please run sudo netstat -lnptu to check which application is blocking 8082
> magicmirror@2.19.0 start > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev" [16.04.2022 21:59.19.108] [LOG] Starting MagicMirror: v2.19.0 [16.04.2022 21:59.19.126] [LOG] Loading config ... [16.04.2022 21:59.19.142] [LOG] Loading module helpers ... [16.04.2022 21:59.19.150] [LOG] No helper found for module: alert. [16.04.2022 21:59.19.204] [LOG] Initializing new module helper ... [16.04.2022 21:59.19.210] [LOG] Module helper loaded: updatenotification [16.04.2022 21:59.19.215] [LOG] No helper found for module: clock. [16.04.2022 21:59.19.227] [LOG] Initializing new module helper ... [16.04.2022 21:59.19.232] [LOG] Module helper loaded: MMM-DWD-WarnWeather [16.04.2022 21:59.19.285] [LOG] Initializing new module helper ... [16.04.2022 21:59.19.289] [LOG] Module helper loaded: MMM-bsh-tides [16.04.2022 21:59.19.293] [LOG] No helper found for module: MMM-OpenmapWeather. [16.04.2022 21:59.19.432] [LOG] Initializing new module helper ... [16.04.2022 21:59.19.434] [LOG] Module helper loaded: MMM-OpenWeatherForecast [16.04.2022 21:59.19.825] [LOG] Initializing new module helper ... [16.04.2022 21:59.19.829] [LOG] Module helper loaded: MMM-CalendarExt2 [16.04.2022 21:59.19.833] [LOG] All module helpers loaded. [16.04.2022 21:59.20.096] [LOG] Starting server on port 8081 ... [16.04.2022 21:59.20.117] [WARN] You're using a full whitelist configuration to allow for all IPs [16.04.2022 21:59.20.136] [LOG] Server started ... [16.04.2022 21:59.20.139] [LOG] Connecting socket for: updatenotification [16.04.2022 21:59.20.143] [LOG] Starting module helper: updatenotification [16.04.2022 21:59.20.145] [LOG] Connecting socket for: MMM-DWD-WarnWeather [16.04.2022 21:59.20.147] [LOG] MMM-DWD-WarnWeather helper started... [16.04.2022 21:59.20.149] [LOG] Connecting socket for: MMM-bsh-tides [16.04.2022 21:59.20.151] [LOG] Starting module helper: MMM-bsh-tides [16.04.2022 21:59.20.154] [LOG] Connecting socket for: MMM-OpenWeatherForecast [16.04.2022 21:59.20.156] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast] [16.04.2022 21:59.20.161] [LOG] Connecting socket for: MMM-CalendarExt2 [16.04.2022 21:59.20.163] [LOG] Sockets connected & modules started ... [16.04.2022 21:59.20.629] [ERROR] Whoops! There was an uncaught exception... [16.04.2022 21:59.20.648] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8081 at Server.setupListenHandle [as _listen2] (node:net:1334:16) at listenInCluster (node:net:1382:12) at GetAddrInfoReqWrap.doListen [as callback] (node:net:1520:7) at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) { code: 'EADDRINUSE', errno: -98, syscall: 'listen', address: '127.0.0.1', port: 8081 } -
@SARCux not too sure now, have to call in the big guns to help good luck
you sure there is not another instance of magicmirror running somewhere?
Server started is this correct??
Aktive Internetverbindungen (Nur Server) Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 517/vncserver-x11-c tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 519/sshd: /usr/sbin tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 487/cupsd tcp6 0 0 ::1:631 :::* LISTEN 487/cupsd tcp6 0 0 :::5900 :::* LISTEN 517/vncserver-x11-c tcp6 0 0 :::22 :::* LISTEN 519/sshd: /usr/sbin udp 0 0 0.0.0.0:68 0.0.0.0:* 862/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 545/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 368/avahi-daemon: r udp 0 0 0.0.0.0:51486 0.0.0.0:* 368/avahi-daemon: r udp6 0 0 :::40941 :::* 368/avahi-daemon: r udp6 0 0 :::5353 :::* 368/avahi-daemon: r -
Letās get all the info we can on this - strip your config of anything like passwords and private urls, and post it.
let config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "0.0.0.0", "::" to listen on any interface // Default, when address config is left out or empty, is "localhost" port: 8081, basePath: "/", // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy // you must set the sub path here. basePath must end with a / ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "de", locale: "de-DE", logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging timeFormat: 24, units: "metric", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_right" }, { module: "MMM-DWD-WarnWeather", position: "top_right", config: { warnCellID: "803455020", changeColor: true, minutes: false, displayRegionName: true, displayInnerHeader: true, interval: 5 * 60 * 1000, // every 5 minutes loadingText: "Warnungen werden geladen...", noWarningText: "Keine Warnungen", severityThreshold: 1 } }, { module: "MMM-bsh-tides", position: "top_right", header: "*********", config: { filename: "*********", // file from https://tableau.bsh.de/views/Gezeitenvorausberechnung_V02/Download-Bereich todayLabel: "Heute", tomorrowLabel: "Morgen", highTide: "Hochwasser", lowTide: "Niedrigwasser", showIcons: false, // Hide or show arrow icons updateInterval: 60 * 60 * 1000, // 1 hour } }, { module: "MMM-OpenmapWeather", position: "top_left", // This can be any of the regions. Best results in left or right regions. header: "Current Weather", //Location is the default value if header is empty or not defined. config: { // See 'Configuration options' for more information. location: "*******", locationID: "***********", //Location ID from http://openweathermap.org/help/city_list.txt appid: "***************", //openweathermap.org API key colorIcon: true } }, { module: "MMM-OpenWeatherForecast", position: "top_left", header: "Wettervorhersage Hooksiel", language: "de", config: { apikey: "*****************", //only string here latitude: 53.640873, //number works here longitude: 8.093848, //so does a string units: "metric", iconset: "5c", colored: true, concise: true, requestDelay: "2000", showFeelsLikeTemp: true, showCurrentConditions: false, showSummary: false, showExtraCurrentConditions: true, extraCurrentConditions: { highLowTemp: true, precipitation: true, sunrise: true, sunset: true, wind: true, barometricPressure: true, humidity: true, dewPoint: false, uvIndex: true, visibility: true }, } }, { module: "MMM-CalendarExt2", config: { calendars : [ { name: "******", url: "***********", scanInterval: 7200000, //(already tried: 1000*60*60*2, 2*60*60*1000, ) }, ], views: [ { name: "view1", mode: "week", calendars: ["******"], hideOverflow: false, position: "top_bar", slotCount: 3, filterPassedEvent: true, locale: "de-DE", }, { name: "upcoming", mode: "upcoming", position: "top_center", maxItems: 5, maxDays: 7, locale: "de-DE", hideOverflow: false, filterPassedEvent: true, }, ], scenes: [ { name: "DEFAULT", }, ], }, }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
@SARCux how did you install MagicMirror?
did u do the manual install, git clone and npm install
or use my script?
looks like manual install
u set auto start at boot. canāt start it again unless u shutdown the other instance
tomorrow i would like to install all new (sdcard)
after that i install MM
where can i find your script for install it? -
@swvalenti as referenced in the doc, under alternative installation methods
install all new with script.
MMM-CalendarExt2 don“t displayed.
Altenativ Standard Calendar runsOther options??
With your input, this post could be even better š
