    HELP -- MMM-calendarExt2 was not displayed
    Scheduled Pinned Locked Moved Forum
    22 Posts 4 Posters 7.8k Views 3 Watching
      SARCux
      Good day,
      I screwed together a Raspi3 with the MagicMirror 😉
      If I have installed all the modules I want, they are also displayed well.
      The calendarExt2 was also running until yesterday
      For whatever reason, this is no longer displayed.
      To check, I entered the standard calendar with the URL of the calendar, it’s not because of the URL.
      Nothing else was changed.
      Does anyone have a tip where I could still look why the MMM-calendarExt2 is not displayed?
      I look forward to tips.
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @SARCux
        @SARCux open the dev window and see what errors show in the console
        npm start dev
          SARCux @swvalenti
          @swvalenti
          [16.04.2022 21:43.37.262] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
          [16.04.2022 21:43.37.264] [LOG]   Connecting socket for: MMM-CalendarExt2
          [16.04.2022 21:43.37.268] [LOG]   Sockets connected & modules started ...
          [16.04.2022 21:43.37.716] [ERROR] Whoops! There was an uncaught exception...
          [16.04.2022 21:43.37.737] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
              at Server.setupListenHandle [as _listen2] (node:net:1334:16)
              at listenInCluster (node:net:1382:12)
              at GetAddrInfoReqWrap.doListen [as callback] (node:net:1520:7)
              at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) {
            code: 'EADDRINUSE',
            errno: -98,
            syscall: 'listen',
            address: '127.0.0.1',
            port: 8080
            SARCux @swvalenti
            @swvalenti
            i don´t know whats wrong :worried_face:
              @SARCux something on your system is already using port 8080, is there a instance of MagicMirror not closed correctly? either restart the pi or change the port in the config file
                SARCux @swvalenti
                @swvalenti
                change the port in config and now this
                [16.04.2022 21:49.40.284] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                [16.04.2022 21:49.40.286] [LOG]   Connecting socket for: MMM-CalendarExt2
                [16.04.2022 21:49.40.290] [LOG]   Sockets connected & modules started ...
                [16.04.2022 21:49.40.733] [ERROR] Whoops! There was an uncaught exception...
                [16.04.2022 21:49.40.751] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8082
                  code: 'EADDRINUSE',
                  errno: -98,
                  syscall: 'listen',
                  port: 8082
                  @SARCux try address 0.0.0.0 and restart the pi
                    SARCux @swvalenti
                    @swvalenti ```
                    [16.04.2022 21:53.09.202] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                    [16.04.2022 21:53.09.204] [LOG] Connecting socket for: MMM-CalendarExt2
                    [16.04.2022 21:53.09.207] [LOG] Sockets connected & modules started …
                    [16.04.2022 21:53.09.227] [ERROR] Whoops! There was an uncaught exception…
                    [16.04.2022 21:53.09.241] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8082
                    at doListen (node:net:1520:7)
                    at processTicksAndRejections (node:internal/process/task_queues:84:21) {
                    code: ‘EADDRINUSE’,
                    errno: -98,
                    syscall: ‘listen’,
                    address: ‘0.0.0.0’,
                    port: 8082
                      @SARCux Are you running MagicMirror with pm2? Or manually?
                      Please run sudo netstat -lnptu to check which application is blocking 8082
                        SARCux @swvalenti
                        @swvalenti
                        > magicmirror@2.19.0 start
                        > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                        [16.04.2022 21:59.19.108] [LOG]   Starting MagicMirror: v2.19.0
                        [16.04.2022 21:59.19.126] [LOG]   Loading config ...
                        [16.04.2022 21:59.19.142] [LOG]   Loading module helpers ...
                        [16.04.2022 21:59.19.150] [LOG]   No helper found for module: alert.
                        [16.04.2022 21:59.19.204] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.210] [LOG]   Module helper loaded: updatenotification
                        [16.04.2022 21:59.19.215] [LOG]   No helper found for module: clock.
                        [16.04.2022 21:59.19.227] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.232] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
                        [16.04.2022 21:59.19.285] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.289] [LOG]   Module helper loaded: MMM-bsh-tides
                        [16.04.2022 21:59.19.293] [LOG]   No helper found for module: MMM-OpenmapWeather.
                        [16.04.2022 21:59.19.432] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.434] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                        [16.04.2022 21:59.19.825] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.829] [LOG]   Module helper loaded: MMM-CalendarExt2
                        [16.04.2022 21:59.19.833] [LOG]   All module helpers loaded.
                        [16.04.2022 21:59.20.096] [LOG]   Starting server on port 8081 ...
                        [16.04.2022 21:59.20.117] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [16.04.2022 21:59.20.136] [LOG]   Server started ...
                        [16.04.2022 21:59.20.139] [LOG]   Connecting socket for: updatenotification
                        [16.04.2022 21:59.20.143] [LOG]   Starting module helper: updatenotification
                        [16.04.2022 21:59.20.145] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
                        [16.04.2022 21:59.20.147] [LOG]   MMM-DWD-WarnWeather helper started...
                        [16.04.2022 21:59.20.149] [LOG]   Connecting socket for: MMM-bsh-tides
                        [16.04.2022 21:59.20.151] [LOG]   Starting module helper: MMM-bsh-tides
                        [16.04.2022 21:59.20.154] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
                        [16.04.2022 21:59.20.156] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                        [16.04.2022 21:59.20.161] [LOG]   Connecting socket for: MMM-CalendarExt2
                        [16.04.2022 21:59.20.163] [LOG]   Sockets connected & modules started ...
                        [16.04.2022 21:59.20.629] [ERROR] Whoops! There was an uncaught exception...
                        [16.04.2022 21:59.20.648] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8081
                          code: 'EADDRINUSE',
                          errno: -98,
                          syscall: 'listen',
                          port: 8081
                          @SARCux not too sure now, have to call in the big guns to help good luck
                            you sure there is not another instance of magicmirror running somewhere?
                              SARCux @swvalenti
                              @swvalenti
                              Server started is this correct??
                              Aktive Internetverbindungen (Nur Server)
                              Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      517/vncserver-x11-c
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      519/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      487/cupsd
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      487/cupsd
                              tcp6       0      0 :::5900                 :::*                    LISTEN      517/vncserver-x11-c
                              tcp6       0      0 :::22                   :::*                    LISTEN      519/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           862/dhcpcd
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           545/cups-browsed
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           368/avahi-daemon: r
                              udp        0      0 0.0.0.0:51486           0.0.0.0:*                           368/avahi-daemon: r
                              udp6       0      0 :::40941                :::*                                368/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                368/avahi-daemon: r
                              • BKeyportB Offline
                                BKeyport Module Developer @SARCux
                                Let’s get all the info we can on this - strip your config of anything like passwords and private urls, and post it.
                                  SARCux @BKeyport
                                  @BKeyport
                                  let config = {
                                          address: "localhost",   // Address to listen on, can be:
                                          port: 8081,
                                          basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],  // Set [] to allow all IP addresses
                                          useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
                                          httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                                          httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                                          language: "de",
                                          locale: "de-DE",
                                          timeFormat: 24,
                                          units: "metric",
                                                          module: "alert",
                                                          module: "updatenotification",
                                                          position: "top_bar"
                                                          module: "clock",
                                                          position: "top_right"
                                                          module: "MMM-DWD-WarnWeather",
        warnCellID: "803455020",
        changeColor: true,
        minutes: false,
        displayRegionName: true,
        displayInnerHeader: true,
        interval: 5 * 60 * 1000, // every 5 minutes
        loadingText: "Warnungen werden geladen...",
        noWarningText: "Keine Warnungen",
        severityThreshold: 1
        module: "MMM-bsh-tides",
        header: "*********",
        filename: "*********", // file from https://tableau.bsh.de/views/Gezeitenvorausberechnung_V02/Download-Bereich
        todayLabel: "Heute",
        tomorrowLabel: "Morgen",
        highTide: "Hochwasser",
        lowTide: "Niedrigwasser",
        showIcons: false, // Hide or show arrow icons
        updateInterval: 60 * 60 * 1000, // 1 hour
        module: "MMM-OpenmapWeather",
        position: "top_left",   // This can be any of the regions. Best results in left or right regions.
        header: "Current Weather", //Location is the default value if header is empty or not defined.
        locationID: "***********", //Location ID from http://openweathermap.org/help/city_list.txt
        appid: "***************",  //openweathermap.org API key
        colorIcon: true
        module: "MMM-OpenWeatherForecast",
        header: "Wettervorhersage Hooksiel",
        language: "de",
        apikey: "*****************", //only string here
        latitude: 53.640873,            //number works here
        longitude: 8.093848,          //so does a string
        units: "metric",
        iconset: "5c",
        colored: true,
        concise: true,
        requestDelay: "2000",
        showFeelsLikeTemp: true,
        showCurrentConditions: false,
        showSummary: false,
        showExtraCurrentConditions: true,
        extraCurrentConditions: {
        highLowTemp: true,
        precipitation: true,
        sunrise: true,
        sunset: true,
        wind: true,
        barometricPressure: true,
        humidity: true,
        dewPoint: false,
        uvIndex: true,
        visibility: true
                                                          module: "MMM-CalendarExt2",
                                                          calendars : [
        url: "***********",
        scanInterval: 7200000, //(already tried: 1000*60*60*2, 2*60*60*1000, )
                                                          views: [
        mode: "week",
        calendars: ["******"],
        hideOverflow: false,
        position: "top_bar",
        slotCount: 3,
        filterPassedEvent: true,
        locale: "de-DE",
        mode: "upcoming",
        position: "top_center",
        maxItems: 5,
        maxDays: 7,
        locale: "de-DE",
                                                          scenes: [
                                    sdetweil @SARCux
                                    @SARCux how did you install MagicMirror?
                                    did u do the manual install, git clone and npm install
                                    or use my script?
                                    looks like manual install
                                    u set auto start at boot. can’t start it again unless u shutdown the other instance
                                      SARCux @sdetweil
                                      tomorrow i would like to install all new (sdcard)
                                      after that i install MM
                                      where can i find your script for install it?
                                          sdetweil @swvalenti
                                          @swvalenti as referenced in the doc, under alternative installation methods
                                            SARCux @sdetweil
                                            install all new with script.
                                            MMM-CalendarExt2 don´t displayed.
                                            Altenativ Standard Calendar runs
                                            Other options??
                                            S S 2 Replies Last reply Reply Quote 0
