    HELP -- MMM-calendarExt2 was not displayed
    Scheduled Pinned Locked Moved Forum
    22 Posts 4 Posters 9.2k Views 3 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @SARCux
      @SARCux Are you running MagicMirror with pm2? Or manually?
      Please run sudo netstat -lnptu to check which application is blocking 8082
        SARCux @swvalenti
        @swvalenti
        > magicmirror@2.19.0 start
        > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
        [16.04.2022 21:59.19.108] [LOG]   Starting MagicMirror: v2.19.0
        [16.04.2022 21:59.19.126] [LOG]   Loading config ...
        [16.04.2022 21:59.19.142] [LOG]   Loading module helpers ...
        [16.04.2022 21:59.19.150] [LOG]   No helper found for module: alert.
        [16.04.2022 21:59.19.204] [LOG]   Initializing new module helper ...
        [16.04.2022 21:59.19.210] [LOG]   Module helper loaded: updatenotification
        [16.04.2022 21:59.19.215] [LOG]   No helper found for module: clock.
        [16.04.2022 21:59.19.227] [LOG]   Initializing new module helper ...
        [16.04.2022 21:59.19.232] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
        [16.04.2022 21:59.19.285] [LOG]   Initializing new module helper ...
        [16.04.2022 21:59.19.289] [LOG]   Module helper loaded: MMM-bsh-tides
        [16.04.2022 21:59.19.293] [LOG]   No helper found for module: MMM-OpenmapWeather.
        [16.04.2022 21:59.19.432] [LOG]   Initializing new module helper ...
        [16.04.2022 21:59.19.434] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
        [16.04.2022 21:59.19.825] [LOG]   Initializing new module helper ...
        [16.04.2022 21:59.19.829] [LOG]   Module helper loaded: MMM-CalendarExt2
        [16.04.2022 21:59.19.833] [LOG]   All module helpers loaded.
        [16.04.2022 21:59.20.096] [LOG]   Starting server on port 8081 ...
        [16.04.2022 21:59.20.117] [WARN]  You're using a full whitelist configuration to allow for all IPs
        [16.04.2022 21:59.20.136] [LOG]   Server started ...
        [16.04.2022 21:59.20.139] [LOG]   Connecting socket for: updatenotification
        [16.04.2022 21:59.20.143] [LOG]   Starting module helper: updatenotification
        [16.04.2022 21:59.20.145] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
        [16.04.2022 21:59.20.147] [LOG]   MMM-DWD-WarnWeather helper started...
        [16.04.2022 21:59.20.149] [LOG]   Connecting socket for: MMM-bsh-tides
        [16.04.2022 21:59.20.151] [LOG]   Starting module helper: MMM-bsh-tides
        [16.04.2022 21:59.20.154] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
        [16.04.2022 21:59.20.156] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
        [16.04.2022 21:59.20.161] [LOG]   Connecting socket for: MMM-CalendarExt2
        [16.04.2022 21:59.20.163] [LOG]   Sockets connected & modules started ...
        [16.04.2022 21:59.20.629] [ERROR] Whoops! There was an uncaught exception...
        [16.04.2022 21:59.20.648] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8081
            at Server.setupListenHandle [as _listen2] (node:net:1334:16)
            at listenInCluster (node:net:1382:12)
            at GetAddrInfoReqWrap.doListen [as callback] (node:net:1520:7)
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) {
          code: 'EADDRINUSE',
          errno: -98,
          syscall: 'listen',
          address: '127.0.0.1',
          port: 8081
        swvalentiS 1 Reply Last reply Reply Quote 0
          @SARCux not too sure now, have to call in the big guns to help good luck
            you sure there is not another instance of magicmirror running somewhere?
              SARCux @swvalenti
              @swvalenti
              Server started is this correct??
              Aktive Internetverbindungen (Nur Server)
              Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      517/vncserver-x11-c
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      519/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      487/cupsd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      487/cupsd
              tcp6       0      0 :::5900                 :::*                    LISTEN      517/vncserver-x11-c
              tcp6       0      0 :::22                   :::*                    LISTEN      519/sshd: /usr/sbin
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           862/dhcpcd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           545/cups-browsed
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           368/avahi-daemon: r
              udp        0      0 0.0.0.0:51486           0.0.0.0:*                           368/avahi-daemon: r
              udp6       0      0 :::40941                :::*                                368/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                368/avahi-daemon: r
              • BKeyportB Offline
                BKeyport Module Developer @SARCux
                Let’s get all the info we can on this - strip your config of anything like passwords and private urls, and post it.
                  SARCux @BKeyport
                  @BKeyport
                  let config = {
                          address: "localhost",   // Address to listen on, can be:
                          port: 8081,
                          basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],  // Set [] to allow all IP addresses
                          useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
                          httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                          httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                          language: "de",
                          locale: "de-DE",
                          timeFormat: 24,
                          units: "metric",
                                          module: "alert",
                                          module: "updatenotification",
                                          position: "top_bar"
                                          module: "clock",
                                          position: "top_right"
                                          module: "MMM-DWD-WarnWeather",
                                                  warnCellID: "803455020",
                                                  changeColor: true,
        minutes: false,
        displayRegionName: true,
        displayInnerHeader: true,
        interval: 5 * 60 * 1000, // every 5 minutes
        loadingText: "Warnungen werden geladen...",
        noWarningText: "Keine Warnungen",
        severityThreshold: 1
        module: "MMM-bsh-tides",
        header: "*********",
        filename: "*********", // file from https://tableau.bsh.de/views/Gezeitenvorausberechnung_V02/Download-Bereich
        todayLabel: "Heute",
        tomorrowLabel: "Morgen",
        highTide: "Hochwasser",
        lowTide: "Niedrigwasser",
        showIcons: false, // Hide or show arrow icons
        updateInterval: 60 * 60 * 1000, // 1 hour
        module: "MMM-OpenmapWeather",
        position: "top_left",   // This can be any of the regions. Best results in left or right regions.
        header: "Current Weather", //Location is the default value if header is empty or not defined.
        locationID: "***********", //Location ID from http://openweathermap.org/help/city_list.txt
        appid: "***************",  //openweathermap.org API key
        colorIcon: true
        module: "MMM-OpenWeatherForecast",
        header: "Wettervorhersage Hooksiel",
        language: "de",
        apikey: "*****************", //only string here
        latitude: 53.640873,            //number works here
        longitude: 8.093848,          //so does a string
        units: "metric",
        iconset: "5c",
        colored: true,
        concise: true,
        requestDelay: "2000",
        showFeelsLikeTemp: true,
        showCurrentConditions: false,
        showSummary: false,
        showExtraCurrentConditions: true,
                                                  extraCurrentConditions: {
                                                          highLowTemp: true,
                                                          precipitation: true,
                                                          sunrise: true,
                                                          sunset: true,
                                                          wind: true,
                                                          barometricPressure: true,
                                                          humidity: true,
                                                          dewPoint: false,
                                                          uvIndex: true,
                                                          visibility: true
                                          module: "MMM-CalendarExt2",
                                          calendars : [
                                                  url: "***********",
                                                  scanInterval: 7200000, //(already tried: 1000*60*60*2, 2*60*60*1000, )
                                          views: [
                                                  mode: "week",
                                                  calendars: ["******"],
                                                  hideOverflow: false,
                                                  position: "top_bar",
                                                  slotCount: 3,
                                                  filterPassedEvent: true,
                                                  locale: "de-DE",
                                                  mode: "upcoming",
                                                  position: "top_center",
                                                  maxItems: 5,
                                                  maxDays: 7,
                                                  locale: "de-DE",
                                          scenes: [
                    sdetweil @SARCux
                    @SARCux how did you install MagicMirror?
                    did u do the manual install, git clone and npm install
                    or use my script?
                    looks like manual install
                    u set auto start at boot. can’t start it again unless u shutdown the other instance
                      SARCux @sdetweil
                      tomorrow i would like to install all new (sdcard)
                      after that i install MM
                      where can i find your script for install it?
                          sdetweil @swvalenti
                          @swvalenti as referenced in the doc, under alternative installation methods
                            SARCux @sdetweil
                            install all new with script.
                            MMM-CalendarExt2 don´t displayed.
                            Altenativ Standard Calendar runs
                            Other options??
                            S S 2 Replies Last reply Reply Quote 0
                              SARCux @SARCux
                              I think it´s a problem with CalenderExt2
                                sdetweil @SARCux
                                @SARCux
                                see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/35
