    HELP -- MMM-calendarExt2 was not displayed
    Scheduled Pinned Locked Moved Forum
    22 Posts 4 Posters 7.4k Views 3 Watching
      SARCux
      Good day,
      I screwed together a Raspi3 with the MagicMirror 😉
      If I have installed all the modules I want, they are also displayed well.
      The calendarExt2 was also running until yesterday
      For whatever reason, this is no longer displayed.
      To check, I entered the standard calendar with the URL of the calendar, it’s not because of the URL.
      Nothing else was changed.
      Does anyone have a tip where I could still look why the MMM-calendarExt2 is not displayed?
      I look forward to tips.
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @SARCux
        @SARCux open the dev window and see what errors show in the console
        npm start dev
          SARCux @swvalenti
          @swvalenti
          [16.04.2022 21:43.37.262] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
          [16.04.2022 21:43.37.264] [LOG]   Connecting socket for: MMM-CalendarExt2
          [16.04.2022 21:43.37.268] [LOG]   Sockets connected & modules started ...
          [16.04.2022 21:43.37.716] [ERROR] Whoops! There was an uncaught exception...
          [16.04.2022 21:43.37.737] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
              at Server.setupListenHandle [as _listen2] (node:net:1334:16)
              at listenInCluster (node:net:1382:12)
              at GetAddrInfoReqWrap.doListen [as callback] (node:net:1520:7)
              at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) {
            code: 'EADDRINUSE',
            errno: -98,
            syscall: 'listen',
            address: '127.0.0.1',
            port: 8080
            SARCux @swvalenti
            @swvalenti
            i don´t know whats wrong :worried_face:
              @SARCux something on your system is already using port 8080, is there a instance of MagicMirror not closed correctly? either restart the pi or change the port in the config file
                SARCux @swvalenti
                @swvalenti
                change the port in config and now this
                [16.04.2022 21:49.40.284] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                [16.04.2022 21:49.40.286] [LOG]   Connecting socket for: MMM-CalendarExt2
                [16.04.2022 21:49.40.290] [LOG]   Sockets connected & modules started ...
                [16.04.2022 21:49.40.733] [ERROR] Whoops! There was an uncaught exception...
                [16.04.2022 21:49.40.751] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8082
                  code: 'EADDRINUSE',
                  errno: -98,
                  syscall: 'listen',
                  port: 8082
                  @SARCux try address 0.0.0.0 and restart the pi
                    SARCux @swvalenti
                    @swvalenti ```
                    [16.04.2022 21:53.09.202] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                    [16.04.2022 21:53.09.204] [LOG] Connecting socket for: MMM-CalendarExt2
                    [16.04.2022 21:53.09.207] [LOG] Sockets connected & modules started …
                    [16.04.2022 21:53.09.227] [ERROR] Whoops! There was an uncaught exception…
                    [16.04.2022 21:53.09.241] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8082
                    at doListen (node:net:1520:7)
                    at processTicksAndRejections (node:internal/process/task_queues:84:21) {
                    code: ‘EADDRINUSE’,
                    errno: -98,
                    syscall: ‘listen’,
                    address: ‘0.0.0.0’,
                    port: 8082
                      @SARCux Are you running MagicMirror with pm2? Or manually?
                      Please run sudo netstat -lnptu to check which application is blocking 8082
                        SARCux @swvalenti
                        @swvalenti
                        > magicmirror@2.19.0 start
                        > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                        [16.04.2022 21:59.19.108] [LOG]   Starting MagicMirror: v2.19.0
                        [16.04.2022 21:59.19.126] [LOG]   Loading config ...
                        [16.04.2022 21:59.19.142] [LOG]   Loading module helpers ...
                        [16.04.2022 21:59.19.150] [LOG]   No helper found for module: alert.
                        [16.04.2022 21:59.19.204] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.210] [LOG]   Module helper loaded: updatenotification
                        [16.04.2022 21:59.19.215] [LOG]   No helper found for module: clock.
                        [16.04.2022 21:59.19.227] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.232] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
                        [16.04.2022 21:59.19.285] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.289] [LOG]   Module helper loaded: MMM-bsh-tides
                        [16.04.2022 21:59.19.293] [LOG]   No helper found for module: MMM-OpenmapWeather.
                        [16.04.2022 21:59.19.432] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.434] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                        [16.04.2022 21:59.19.825] [LOG]   Initializing new module helper ...
                        [16.04.2022 21:59.19.829] [LOG]   Module helper loaded: MMM-CalendarExt2
                        [16.04.2022 21:59.19.833] [LOG]   All module helpers loaded.
                        [16.04.2022 21:59.20.096] [LOG]   Starting server on port 8081 ...
                        [16.04.2022 21:59.20.117] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [16.04.2022 21:59.20.136] [LOG]   Server started ...
                        [16.04.2022 21:59.20.139] [LOG]   Connecting socket for: updatenotification
                        [16.04.2022 21:59.20.143] [LOG]   Starting module helper: updatenotification
                        [16.04.2022 21:59.20.145] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
                        [16.04.2022 21:59.20.147] [LOG]   MMM-DWD-WarnWeather helper started...
                        [16.04.2022 21:59.20.149] [LOG]   Connecting socket for: MMM-bsh-tides
                        [16.04.2022 21:59.20.151] [LOG]   Starting module helper: MMM-bsh-tides
                        [16.04.2022 21:59.20.154] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
                        [16.04.2022 21:59.20.156] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                        [16.04.2022 21:59.20.161] [LOG]   Connecting socket for: MMM-CalendarExt2
                        [16.04.2022 21:59.20.163] [LOG]   Sockets connected & modules started ...
                        [16.04.2022 21:59.20.629] [ERROR] Whoops! There was an uncaught exception...
                        [16.04.2022 21:59.20.648] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8081
                          code: 'EADDRINUSE',
                          errno: -98,
                          syscall: 'listen',
                          port: 8081
