    MMM-Calendar Ext2 google calendar colors
    6 Posts 5 Posters 2.6k Views 5 Watching
    • F Offline
      fedale
      Is it possible to have the same color as set in my google calendar in MMM-Calendar Ext2.
      As of now it´s all showing the same color for an event. Even when i change the color in my google calendar still doesn´t change in mm.
      Or could i have words that would prompt another color in my calendar depending on the word in the calendar?
      example:
      Work would always show as blue
      Holiday would show as yellow.
      Or names.
      Without creating extra calendars. Today i have a family calendar that i would like to have the different colors that we are using or the words showing up as differnt colors.
        MMRIZE @fedale
        @fedale
        1. Impossible to inherit Google’s colour setting (The event itself has no information about how it shows in Google calendar)
        2. You can transform your event to get a different CSS className by the condition of events.
          See the Sort, Filter, Transform parts of MMM-CalendarExt2 documents.
        • F Offline
          fedale @MMRIZE
          @MMRIZE thanks i try that.
          • F Offline
            fedale
            @MMRIZE thanks for helping me in the right direction. This worked for me
            In config.js
            Under views:
            transform: function(event) {
            			if (event.title.search("Holiday") > -1) {
            			event.className = "Holiday";
              		       else if(event.title.search("Work") > -1) {
            		       event.className = "Work"
            			return event;
            In the custom.css
             .CX2 .Holiday.fullday {
                background-color:rgba(0,0,255);
                color:#000;
             .CX2 .Work.fullday {
                background-color:rgba(0,128,128);
                color:#000;
            S F 2 Replies Last reply Reply Quote 0
              sdetweil @fedale
              @fedale always put your code or config or css entries in a code wrapper
              paste, select the text you just pasted
              and hit the </> button above the edit window
              fixed for u this time
              • F Offline
                fedale @fedale
                @sdetweil Sorry about that, thank you
