    Trouble playing audio file
    15 Posts 3 Posters 3.8k Views 3 Watching
      mZuil
      Hello everybody, I am currently having some issues playing an mp3 or wav file.
      So far I have tried the following packages in the node_helper but none seem to work:
      play
      a-play
      play-sound
      sound-play
      play-audio
      node-aplay
      child-proccess executing cvlc command
      Some of them give errors and the others do not produce any sound.
      I am asking for help over here since I have been working the last couple of days and I could really use some help.
      Thank you in advance! :D
        sdetweil @mZuil
        @mZuil if u bring up YouTube do you get audio?
        my Ubuntu has lost access to my sound device
        . haven’t figured that out yet
          mZuil @sdetweil
          @sdetweil Yeah, the monitor I use has speakers and I have tried to reproduce YouTube and even this mp3 o wav file without the Magic Mirror started and it works, but when I call some functions to execute the audio with the Magic Mirror it doesn’t work. I am generating this audio with gtts and I don’t know if the problem is because those two actions are executed at the same time:
          const gTTS = require('gtts');
          var play = require('play').Play();
          var gtts = new gTTS('text to speak', 'es-es');
          gtts.save('/tmp/hello.wav', function (err, result) {
            if(err) { throw new Error(err) }
            console.log('Success! Open file /tmp/hello.mp3 to hear result.');
          play.sound('/tmp/hello.wav');
          The code below is one of the many attempts I have tried :(
          Thanks for the response!
            sdetweil @mZuil
            @mZuil can u run this piece of code from a terminal window?
            put the code in xxx.js
            then
            node xxx.js
            does it work?
              mZuil @sdetweil
              @sdetweil Sorry, I couldn’t try it before.
              It doesn’t work :( I am a beginner and I don’t understand well what is happening, could you help me, please? :crying_face:
                sdetweil @mZuil
                @mZuil what does the play() library say about sound output configuration?
                https://github.com/Marak/play.js#readme
                requirements:
                One of the CLI based audio player
                CLI means Command Line Interface
                I think you should have seen this error
                      console.log('No suitable audio player could be found - exiting.'.red);
                  sdetweil @mZuil
                  @mZuil none of the players listed in his code and doc are installed on raspberry pi os by default.
                  bugsounetB 1 Reply Last reply Reply Quote 0
                  • bugsounetB Offline
                    bugsounet Banned @sdetweil
                    @sdetweil the problem is not there…
                    The problem is you can’t play a file when it’s not fully created!
                    2 solutions:
                    Make a promise
                    Or play the file when the file is created
                      sdetweil @bugsounet
                      @bugsounet ah yes good catch. I jumped to play()…
                      move the play() inside the callback on save()
                      players will be the next problem
                      bugsounetB 1 Reply Last reply Reply Quote 1
                        just because sometime i'm kind... (my favorite sentence!)
                        Try this:
                        var player = require('play-sound')(
                          opts = {
                            player: "mpg123" // use only `mpg123` for playing sounds
                        // main file player
                        function playing (file) {
                          player.play(file, (err) => {
                            if (err) throw new Error(err)
                        gtts.save('/tmp/hello.wav', (err, result) => {
                          console.log('Success! start playing result.');
                          // right ! sound file is created let's play it !
                          playing("/tmp/hello.wav");
                        Notes:
                        • You need to install mpg123 app with sudo apt-get install mpg123
                        • I replace your play library by play-sound for better compatibility
                          Don’t forget to install this library npm install play-sound
                        • You can see manual of play-sound library there
