    MMM-CalendarExt3
    678 Posts 82 Posters 2.7m Views 86 Watching
      sdetweil @Rakutsi
      @Rakutsi no… the stuff shown on the screen isn’t broadcast to the other modules…
      but you could add an ext3 eventTransformer to add it back on (if you know bd, and some pattern in the event subject)
        Rakutsi @sdetweil
        @sdetweil thanks then i know.
        well i dont know how to use the eventFilter for that, is there any example then i could try?
        I am not the best at those kind of things. Mostly copy paste and trial and error.
          sdetweil @Rakutsi
          @Rakutsi see the doc and the ext3 wiki (at the module github page)
            Rakutsi @sdetweil
            this was the solution i came up with.
            eventTransformer: (event) => {
                const currentYear = new Date().getFullYear();
                const age = currentYear - event.firstYear;
                event.title = `${event.title} (${age} year)`;
                return event;
            Chatgpt is my friend.
              sdetweil @Rakutsi
              @Rakutsi awesome!
                MMRIZE @czabel
                @czabel said in MMM-CalendarExt3:
                Do you have any insight as to how to change my CSS to get the icons to show up for every event? As I mentioned, my current setup makes my non-fullday events colored in, but this deletes the icon. The icon is still there for the real fullday events. I’d like to keep the icon, if at all possible. Thank you!
                Sorry for the late reply. I was on vacation.
                Append these codes to your custom.css
                /* custom.css */
                .CX3 .event.singleday .headline.useSymbol .symbol {
                  color: var(--oppositeColor);
                • C Offline
                  czabel @MMRIZE
                  @MMRIZE said in MMM-CalendarExt3:
                  … Sorry for the late reply…
                  No problem at all, I appreciate the time you spend helping on here.
                  With that CSS adjustment, the events in the calendar look perfect now, thank you.
                  But I have a new problem that seems to have just shown up: the volleyball icon that I’m using in the eventTransformer is now being applied to the Legend somehow:
                  You can see the events are great (volleyball has the icon, other events are the default)
                  This is especially odd because in the base calendar config, I specify useSymbol: false for the “Dad” calendar, but this element is somehow getting the .useSymbol class.
                  Oh, I just found in a search another user that has this issue, link here
                    MMRIZE @czabel
                    @czabel
                    Well, that is not the bug, however you might be uncomfortable.
                    It is designed to get the symbol from the first(internally structured) event of the calendar group.
                    Because the default calendar module will broadcast only the events themselves, not the meta-information from the calendar to which the event belonged, So there is no easy way to distinguish the default symbol of the specific calendar.
                    To be honest, getting the default symbol from config of ONLY the default calendar module might be easy, but this module is designed to take events from any other possible modules, so I cannot assume all the user will get the events from the default calendar module only.
                    Not so easy. Has somebody any idea?
                    • C Offline
                      czabel @MMRIZE
                      @MMRIZE
                      I probably don’t understand enough about how this system works to help much, but isn’t every calendar entry a separate event, which is why the eventTransformer works to change the individual icons? How is it that this icon spills over into the Legend entry, and not just the specific calendar entries?
                      In any case, what about adding a new config option to hideLegendIcons that forcibly removes the CSS tag, or something like that?
                        MMRIZE @czabel
                        @czabel
                        You can simply append this code to your css/custom.css
                        .CX3 .legend.useSymbol .symbol {
                          display: none;
                        • 55
                        • 56
                        • 57
                        • 58
                        • 59
                        • 67
                        • 68
                        • 57 / 68
