    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
      sdetweil @chriskar
      @chriskar correct
      mode:week
      weeksInView:3
      weekIndex:0 //first week to see, -1 is last week, default
      etc
      • C Offline
        chriskar
        ok thanks, this worked fine!
        what about the overlaping issue? css code is mostly AI generated so it probably has a lot of junk in
          sdetweil @chriskar
          @chriskar i do not know on css
          he provides lots of control, but wrap seems difficult
          • P Online
            p1lspeda
            I updated to MM 2.32 this morning and ever since then, I have noticed that the CW entry in my MMM-CalendarExt3 is stuck at “CW1”:
            I assume the newest changes have something to do with it
            Any idea if I can solve this or do I need to wait for a module update ?
              sdetweil @p1lspeda
              @p1lspeda I see the same bug, but not sure where it is
              a temp fix is to add this line to the CX3 config section
                        minimalDaysOfNewYear:1,  // week number of 1st week in your country (should be 0 or 1)
              there was an open issue on this inthe CX3 repo
              https://github.com/MMRIZE/MMM-CalendarExt3/issues/215
              I posted this workaround there too
              • P Online
                p1lspeda @sdetweil
                Great.
                Thanks for help (again!)
                • K Offline
                  kribbitykrab
                  Hi folks,
                  Trying to get MMM-CalendarExt3 working on my Pi Zero W running MM v2.30.0 and running into an issue where the calendar is blank. Relevant config.js below:
                        broadcastPastEvents: true,
                        maximumEntries: 10000,
                        colored: true,
                                 fetchInterval: 1* 60 * 1000,
                                 symbol: "calendar-check",
                                 color: "rgba(255, 0, 0, 1)",
                                 url: "..."
                                 color: "rgba(0, 0, 255, 1)",
                                 url: "..."
                     module: "MMM-CaendarExt3",
                     position: "bottom_bar",
                     title: "family dashboard",
                        mode: "month"
                        instanceID: "basicCalendar",
                        locale: 'en-US'
                        maxEventLines: 5,
                        firstDayOfWeek: 1,
                        calendarSet: ["p_and_b", "cal2"]
                  Can anyone help me understand why my monthly calendar is coming up blank and a workaround?
                    sdetweil @kribbitykrab
                    @kribbitykrab ok, this is worse on pi 0w
                    Ext3 gets the calendar events from the default calendar
                    the calendar module fetches each url separately and broadcasts the events to other modules if they want to use them
                    but EXT3 doesn’t want to flash redraw the cal each time a block of events show up
                    so it also has a
                    refreshInterval
                    take whatever events have arrived since last time and display ( default 30 minutes)
                    now there is another tuning thing
                    if it drew immediately on startup it would be empty, cause startup is faster than fetch. but EXT3 doesn’t know how many cal urls might supply events.
                    so there is the
                    waitFetch
                    config parm (default 5 seconds)
                    wait that long after startup before displaying any events
                    then next will be updateinterval
                    pi0w is SOOOOOOO slow ,no events arrive before waitFetch
                    so next time is updateInterval time
                    so you can adjust these some
                    you are probably
                    impacted by this bug too, timeout on the connection between front and back ends
                    see https://forum.magicmirror.builders/post/127456
                    • K Offline
                      kribbitykrab @sdetweil
                      @sdetweil As always, thank you for the response!
                      I added the pingInterval and pingTimeout lines to both MagicMirror/js/server.js and MagicMirror/js/socketclient.js as described in your link.
                      I have also moved my fetchInterval into the config portion of my calendar module as you requested, and increased it to 10minutes. I added a waitFetch of 10sec into my MMM-CalendarExt3 module config, along with a refreshInterval of 10minutes.
                      When I run MM now however, I am unable to reach localhost. I get an error on Midori booth that says Could not connect: Connection refused. Potentially something to do with the server.js and socketclient.js fiddling? Appreciate further guidance!
                        @kribbitykrab i think you made a typo
                        do
                        npm run server
                        • T Offline
                          thegooroo
                          Default CW display shows on desktop Firefox but not on Chrome/Electron when using the rpi as a display. It only show “CW 1” for each week.
                          Firefox shows the correct week number “CW 32” in this weeks case. My search-fu is not finding a fix for this.
                            sdetweil @thegooroo
                            @thegooroo see
                            https://forum.magicmirror.builders/post/127160
                            • T Offline
                              thegooroo @sdetweil
                              @sdetweil Awesome! Many thanks!
                                almightyyoshi
                                Is there a way to remove the space where a symbol would be only for calendars not using a symbol?
                                  sdetweil @almightyyoshi
                                  @almightyyoshi yes
                                  add
                                  classes:"........ some_arbitrary_string "
                                  //like this
                                  classes:"foo",
                                  after the module: line
                                  to the instance you dont want the symbols to show
                                  then use
                                  .arbitrary_string .symbol {
                                       display:none;
                                  /*like this */
                                  .foo .symbol {
                                       display:none;
                                    I think you can add the caledar_name selector too
                                    from the ext3 doc
                                    .event` : Every event has this selector. Each event could have these class names together by its condition.
                                      - `.continueFromPreviousWeek`, `.continueToNextWeek`
                                      - `.calendar_{calendarName}`    <-------
                                      S374n
                                      Hello,
                                      Is it possible to scroll this calendar with a button on GPIO, next month or prev month? Where can i find more details on this please, found some ideas but not this specific calendar.
                                      Thank you.
                                        sdetweil @S374n
                                        @S374n you can use mmm-pages, create three pages
                                        Three instances of ext3. One on each page,
                                        mode:“month”
                                        monthIndex: 0/1/2. For this month, next month and month after that (-1 for month before current)
                                        Mmm-page-indicator creates buttons you can customize look w css, and will let you Move between pages on demand , pages also rotates
                                          S374n @sdetweil
                                          @sdetweil Thank you for the idea. I’ll look into it.
                                            bicolorbore586 @MMRIZE
                                            My MagicMirror has been out of action for a few months now, mainly due to a kitchen renovation, but am looking at getting it back up and running.
                                            I’d previously had MMM-CalendarExt3 working with a few different calendars, notably a birthday calendar, where it would show an icon in the cell header.
                                            However since updating the MagicMirror software it no longer seems possible to do. Below is the module extract from config.js, and is what has been previously used. Now upon starting MM with this in place I’m told [ERROR] Your configuration file contains syntax errors :( ‘document’ is not defined.
                                            Anyone able to assist with what the issue is and how to resolve it?
                                            		module: "MMM-CalendarExt3", //https://github.com/MMRIZE/MMM-CalendarExt3
                                            		position: "lower_third",
                                            		//header: "FamCal",
                                            			mode: "month",
                                            			useWeather: false,
                                            			weekIndex: 0,
                                            			weeksInView: 5,
                                            			instanceId: "basicCalendar",
                                            			locale: "en-GB",
                                            			maxEventLines: 6,
                                            			firstDayOfWeek: 1,
                                            			headerWeekDayOptions: {weekday: "short"},
                                            			refreshInterval: 60 * 10 * 1000, // 3600000, // every hour // 60 * 10 * 1000, // too frequent refresh. 10 minutes is enough.
                                            			calendarSet: ["Family Calendar", "UK Holidays", "Birthday",],
                                            			manipulateDateCell: (cellDom, events) => {
                                            				if (Array.isArray(events) && events.some(e => e.calendarName === 'Birthday')) {
                                            					let dateIcon = document.createElement ('span')
                                            					dateIcon.classList.add ('fa', 'fa-fas', 'fa-fw', 'fa-gift')
                                            					dateIcon.style.color = 'cornflowerblue'
                                            					let header = cellDom.querySelector ('.cellHeader')
                                            					let celldate = header.querySelector ('.cellDate')
                                            					header.insertBefore (dateIcon, celldate)
                                            			eventTransformer: (ev) => 	{
                                            				if (ev.calendarName === 'Birthday') ev.skip = true
                                            				else if (ev.title.search("B -") > -1) ev.color = "brown"
                                            				else if (ev.title.search("C -") > -1) ev.color = "hotpink"
                                            				else if (ev.title.search("E -") > -1) ev.color = "orange"
                                            				else if (ev.title.search("I -") > -1) ev.color = "green"
                                            				else if (ev.title.search("G") > -1) ev.color = "white"
                                            				else if (ev.title.search("Bday") > -1) ev.title = ""
                                            				return ev
                                            			eventPayload: (payload) => {
                                            				for (let ev of payload) {
                                            					if (ev.fullDayEvent) {
                                            						let gap = +ev.endDate - +ev.startDate
                                            						if (gap % (1000 * 60 * 60 * 24) === 0) {
                                            							ev.startDate = new Date(+ev.startDate).setHours(0, 0, 0, 0)
                                            							ev.endDate = new Date(+ev.startDate + gap).setMilliseconds(-1)
                                            				return payload
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
