    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      chriskar
      ok thanks, this worked fine!
      what about the overlaping issue? css code is mostly AI generated so it probably has a lot of junk in
        sdetweil @chriskar
        @chriskar i do not know on css
        he provides lots of control, but wrap seems difficult
          p1lspeda
          I updated to MM 2.32 this morning and ever since then, I have noticed that the CW entry in my MMM-CalendarExt3 is stuck at “CW1”:
          I assume the newest changes have something to do with it
          Any idea if I can solve this or do I need to wait for a module update ?
            sdetweil @p1lspeda
            @p1lspeda I see the same bug, but not sure where it is
            a temp fix is to add this line to the CX3 config section
                      minimalDaysOfNewYear:1,  // week number of 1st week in your country (should be 0 or 1)
            there was an open issue on this inthe CX3 repo
            https://github.com/MMRIZE/MMM-CalendarExt3/issues/215
            I posted this workaround there too
              p1lspeda @sdetweil
              Great.
              Thanks for help (again!)
              • K
                kribbitykrab
                Hi folks,
                Trying to get MMM-CalendarExt3 working on my Pi Zero W running MM v2.30.0 and running into an issue where the calendar is blank. Relevant config.js below:
                      broadcastPastEvents: true,
                      maximumEntries: 10000,
                      colored: true,
                               fetchInterval: 1* 60 * 1000,
                               symbol: "calendar-check",
                               color: "rgba(255, 0, 0, 1)",
                               url: "..."
                               color: "rgba(0, 0, 255, 1)",
                               url: "..."
                   module: "MMM-CaendarExt3",
                   position: "bottom_bar",
                   title: "family dashboard",
                      mode: "month"
                      instanceID: "basicCalendar",
                      locale: 'en-US'
                      maxEventLines: 5,
                      firstDayOfWeek: 1,
                      calendarSet: ["p_and_b", "cal2"]
                Can anyone help me understand why my monthly calendar is coming up blank and a workaround?
                  sdetweil @kribbitykrab
                  @kribbitykrab ok, this is worse on pi 0w
                  Ext3 gets the calendar events from the default calendar
                  the calendar module fetches each url separately and broadcasts the events to other modules if they want to use them
                  but EXT3 doesn’t want to flash redraw the cal each time a block of events show up
                  so it also has a
                  refreshInterval
                  take whatever events have arrived since last time and display ( default 30 minutes)
                  now there is another tuning thing
                  if it drew immediately on startup it would be empty, cause startup is faster than fetch. but EXT3 doesn’t know how many cal urls might supply events.
                  so there is the
                  waitFetch
                  config parm (default 5 seconds)
                  wait that long after startup before displaying any events
                  then next will be updateinterval
                  pi0w is SOOOOOOO slow ,no events arrive before waitFetch
                  so next time is updateInterval time
                  so you can adjust these some
                  you are probably
                  impacted by this bug too, timeout on the connection between front and back ends
                  see https://forum.magicmirror.builders/post/127456
                  • K
                    kribbitykrab @sdetweil
                    @sdetweil As always, thank you for the response!
                    I added the pingInterval and pingTimeout lines to both MagicMirror/js/server.js and MagicMirror/js/socketclient.js as described in your link.
                    I have also moved my fetchInterval into the config portion of my calendar module as you requested, and increased it to 10minutes. I added a waitFetch of 10sec into my MMM-CalendarExt3 module config, along with a refreshInterval of 10minutes.
                    When I run MM now however, I am unable to reach localhost. I get an error on Midori booth that says Could not connect: Connection refused. Potentially something to do with the server.js and socketclient.js fiddling? Appreciate further guidance!
                      @kribbitykrab i think you made a typo
                      do
                      npm run server
                      • T
                        thegooroo
                        Default CW display shows on desktop Firefox but not on Chrome/Electron when using the rpi as a display. It only show “CW 1” for each week.
                        Firefox shows the correct week number “CW 32” in this weeks case. My search-fu is not finding a fix for this.
                          sdetweil @thegooroo
                          @thegooroo see
                          https://forum.magicmirror.builders/post/127160
                          • T
                            thegooroo @sdetweil
                            @sdetweil Awesome! Many thanks!
                            • A
                              almightyyoshi
                              Is there a way to remove the space where a symbol would be only for calendars not using a symbol?
                                sdetweil @almightyyoshi
                                @almightyyoshi yes
                                add
                                classes:"........ some_arbitrary_string "
                                //like this
                                classes:"foo",
                                after the module: line
                                to the instance you dont want the symbols to show
                                then use
                                .arbitrary_string .symbol {
                                     display:none;
                                /*like this */
                                .foo .symbol {
                                     display:none;
                                  I think you can add the caledar_name selector too
                                  from the ext3 doc
                                  .event` : Every event has this selector. Each event could have these class names together by its condition.
                                    - `.continueFromPreviousWeek`, `.continueToNextWeek`
                                    - `.calendar_{calendarName}`    <-------
                                    S374n
                                    Is it possible to scroll this calendar with a button on GPIO, next month or prev month? Where can i find more details on this please, found some ideas but not this specific calendar.
                                    Thank you.
                                      sdetweil @S374n
                                      @S374n you can use mmm-pages, create three pages
                                      Three instances of ext3. One on each page,
                                      mode:“month”
                                      monthIndex: 0/1/2. For this month, next month and month after that (-1 for month before current)
                                      Mmm-page-indicator creates buttons you can customize look w css, and will let you Move between pages on demand , pages also rotates
                                        S374n @sdetweil
                                        @sdetweil Thank you for the idea. I’ll look into it.
                                          bicolorbore586 @MMRIZE
                                          My MagicMirror has been out of action for a few months now, mainly due to a kitchen renovation, but am looking at getting it back up and running.
                                          I’d previously had MMM-CalendarExt3 working with a few different calendars, notably a birthday calendar, where it would show an icon in the cell header.
                                          However since updating the MagicMirror software it no longer seems possible to do. Below is the module extract from config.js, and is what has been previously used. Now upon starting MM with this in place I’m told [ERROR] Your configuration file contains syntax errors :( ‘document’ is not defined.
                                          Anyone able to assist with what the issue is and how to resolve it?
                                          		module: "MMM-CalendarExt3", //https://github.com/MMRIZE/MMM-CalendarExt3
                                          		position: "lower_third",
                                          		//header: "FamCal",
                                          			mode: "month",
                                          			useWeather: false,
                                          			weekIndex: 0,
                                          			weeksInView: 5,
                                          			instanceId: "basicCalendar",
                                          			locale: "en-GB",
                                          			maxEventLines: 6,
                                          			firstDayOfWeek: 1,
                                          			headerWeekDayOptions: {weekday: "short"},
                                          			refreshInterval: 60 * 10 * 1000, // 3600000, // every hour // 60 * 10 * 1000, // too frequent refresh. 10 minutes is enough.
                                          			calendarSet: ["Family Calendar", "UK Holidays", "Birthday",],
                                          			manipulateDateCell: (cellDom, events) => {
                                          				if (Array.isArray(events) && events.some(e => e.calendarName === 'Birthday')) {
                                          					let dateIcon = document.createElement ('span')
                                          					dateIcon.classList.add ('fa', 'fa-fas', 'fa-fw', 'fa-gift')
                                          					dateIcon.style.color = 'cornflowerblue'
                                          					let header = cellDom.querySelector ('.cellHeader')
                                          					let celldate = header.querySelector ('.cellDate')
                                          					header.insertBefore (dateIcon, celldate)
                                          			eventTransformer: (ev) => 	{
                                          				if (ev.calendarName === 'Birthday') ev.skip = true
                                          				else if (ev.title.search("B -") > -1) ev.color = "brown"
                                          				else if (ev.title.search("C -") > -1) ev.color = "hotpink"
                                          				else if (ev.title.search("E -") > -1) ev.color = "orange"
                                          				else if (ev.title.search("I -") > -1) ev.color = "green"
                                          				else if (ev.title.search("G") > -1) ev.color = "white"
                                          				else if (ev.title.search("Bday") > -1) ev.title = ""
                                          				return ev
                                          			eventPayload: (payload) => {
                                          				for (let ev of payload) {
                                          					if (ev.fullDayEvent) {
                                          						let gap = +ev.endDate - +ev.startDate
                                          						if (gap % (1000 * 60 * 60 * 24) === 0) {
                                          							ev.startDate = new Date(+ev.startDate).setHours(0, 0, 0, 0)
                                          							ev.endDate = new Date(+ev.startDate + gap).setMilliseconds(-1)
                                          				return payload
                                            sdetweil @bicolorbore586
                                            @bicolorbore586 can you do
                                            npm run config:check
                                            does it produce the same error?
                                            also do
                                            node -c config/config.js
                                            if it returns and displays nothing, then node did not detect any syntax errors.
                                            edit: I can reproduce this
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
