    MMM-CalendarExt3
    689 Posts 82 Posters 2.8m Views 86 Watching
      chriskar @sdetweil
      @sdetweil said in MMM-CalendarExt3:
      @chriskar views and scenes were config options in calendarExt2, but are not used in Ext3
      so i remove views and scenes and use only the config part?
        sdetweil @chriskar
        @chriskar correct
        mode:week
        weeksInView:3
        weekIndex:0 //first week to see, -1 is last week, default
        etc
          chriskar
          ok thanks, this worked fine!
          what about the overlaping issue? css code is mostly AI generated so it probably has a lot of junk in
            sdetweil @chriskar
            @chriskar i do not know on css
            he provides lots of control, but wrap seems difficult
              p1lspeda
              I updated to MM 2.32 this morning and ever since then, I have noticed that the CW entry in my MMM-CalendarExt3 is stuck at “CW1”:
              I assume the newest changes have something to do with it
              Any idea if I can solve this or do I need to wait for a module update ?
                sdetweil @p1lspeda
                @p1lspeda I see the same bug, but not sure where it is
                a temp fix is to add this line to the CX3 config section
                          minimalDaysOfNewYear:1,  // week number of 1st week in your country (should be 0 or 1)
                there was an open issue on this inthe CX3 repo
                https://github.com/MMRIZE/MMM-CalendarExt3/issues/215
                I posted this workaround there too
                  p1lspeda @sdetweil
                  Great.
                  Thanks for help (again!)
                  • K Offline
                    kribbitykrab
                    Hi folks,
                    Trying to get MMM-CalendarExt3 working on my Pi Zero W running MM v2.30.0 and running into an issue where the calendar is blank. Relevant config.js below:
                          broadcastPastEvents: true,
                          maximumEntries: 10000,
                          colored: true,
                                   fetchInterval: 1* 60 * 1000,
                                   symbol: "calendar-check",
                                   color: "rgba(255, 0, 0, 1)",
                                   url: "..."
                                   color: "rgba(0, 0, 255, 1)",
                                   url: "..."
                       module: "MMM-CaendarExt3",
                       position: "bottom_bar",
                       title: "family dashboard",
                          mode: "month"
                          instanceID: "basicCalendar",
                          locale: 'en-US'
                          maxEventLines: 5,
                          firstDayOfWeek: 1,
                          calendarSet: ["p_and_b", "cal2"]
                    Can anyone help me understand why my monthly calendar is coming up blank and a workaround?
                      sdetweil @kribbitykrab
                      @kribbitykrab ok, this is worse on pi 0w
                      Ext3 gets the calendar events from the default calendar
                      the calendar module fetches each url separately and broadcasts the events to other modules if they want to use them
                      but EXT3 doesn’t want to flash redraw the cal each time a block of events show up
                      so it also has a
                      refreshInterval
                      take whatever events have arrived since last time and display ( default 30 minutes)
                      now there is another tuning thing
                      if it drew immediately on startup it would be empty, cause startup is faster than fetch. but EXT3 doesn’t know how many cal urls might supply events.
                      so there is the
                      waitFetch
                      config parm (default 5 seconds)
                      wait that long after startup before displaying any events
                      then next will be updateinterval
                      pi0w is SOOOOOOO slow ,no events arrive before waitFetch
                      so next time is updateInterval time
                      so you can adjust these some
                      you are probably
                      impacted by this bug too, timeout on the connection between front and back ends
                      see https://forum.magicmirror.builders/post/127456
                      • K Offline
                        kribbitykrab @sdetweil
                        @sdetweil As always, thank you for the response!
                        I added the pingInterval and pingTimeout lines to both MagicMirror/js/server.js and MagicMirror/js/socketclient.js as described in your link.
                        I have also moved my fetchInterval into the config portion of my calendar module as you requested, and increased it to 10minutes. I added a waitFetch of 10sec into my MMM-CalendarExt3 module config, along with a refreshInterval of 10minutes.
                        When I run MM now however, I am unable to reach localhost. I get an error on Midori booth that says Could not connect: Connection refused. Potentially something to do with the server.js and socketclient.js fiddling? Appreciate further guidance!
                          @kribbitykrab i think you made a typo
                          do
                          npm run server
                          • T Offline
                            thegooroo
                            Default CW display shows on desktop Firefox but not on Chrome/Electron when using the rpi as a display. It only show “CW 1” for each week.
                            Firefox shows the correct week number “CW 32” in this weeks case. My search-fu is not finding a fix for this.
                              sdetweil @thegooroo
                              @thegooroo see
                              https://forum.magicmirror.builders/post/127160
                              • T Offline
                                thegooroo @sdetweil
                                @sdetweil Awesome! Many thanks!
                                  almightyyoshi
                                  Is there a way to remove the space where a symbol would be only for calendars not using a symbol?
                                    sdetweil @almightyyoshi
                                    @almightyyoshi yes
                                    add
                                    classes:"........ some_arbitrary_string "
                                    //like this
                                    classes:"foo",
                                    after the module: line
                                    to the instance you dont want the symbols to show
                                    then use
                                    .arbitrary_string .symbol {
                                         display:none;
                                    /*like this */
                                    .foo .symbol {
                                         display:none;
                                      I think you can add the caledar_name selector too
                                      from the ext3 doc
                                      .event` : Every event has this selector. Each event could have these class names together by its condition.
                                        - `.continueFromPreviousWeek`, `.continueToNextWeek`
                                        - `.calendar_{calendarName}`    <-------
                                        S374n
                                        Is it possible to scroll this calendar with a button on GPIO, next month or prev month? Where can i find more details on this please, found some ideas but not this specific calendar.
                                        Thank you.
                                          sdetweil @S374n
                                          @S374n you can use mmm-pages, create three pages
                                          Three instances of ext3. One on each page,
                                          mode:“month”
                                          monthIndex: 0/1/2. For this month, next month and month after that (-1 for month before current)
                                          Mmm-page-indicator creates buttons you can customize look w css, and will let you Move between pages on demand , pages also rotates
                                            S374n @sdetweil
                                            @sdetweil Thank you for the idea. I’ll look into it.
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
