    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
    • K Offline
      kribbitykrab @sdetweil
      @sdetweil As always, thank you for the response!
      I added the pingInterval and pingTimeout lines to both MagicMirror/js/server.js and MagicMirror/js/socketclient.js as described in your link.
      I have also moved my fetchInterval into the config portion of my calendar module as you requested, and increased it to 10minutes. I added a waitFetch of 10sec into my MMM-CalendarExt3 module config, along with a refreshInterval of 10minutes.
      When I run MM now however, I am unable to reach localhost. I get an error on Midori booth that says Could not connect: Connection refused. Potentially something to do with the server.js and socketclient.js fiddling? Appreciate further guidance!
        sdetweil @kribbitykrab
        @kribbitykrab i think you made a typo
        do
        npm run server
        • T Offline
          thegooroo
          Default CW display shows on desktop Firefox but not on Chrome/Electron when using the rpi as a display. It only show “CW 1” for each week.
          Firefox shows the correct week number “CW 32” in this weeks case. My search-fu is not finding a fix for this.
            sdetweil @thegooroo
            @thegooroo see
            https://forum.magicmirror.builders/post/127160
            • T Offline
              thegooroo @sdetweil
              @sdetweil Awesome! Many thanks!
                almightyyoshi
                Is there a way to remove the space where a symbol would be only for calendars not using a symbol?
                  sdetweil @almightyyoshi
                  @almightyyoshi yes
                  add
                  classes:"........ some_arbitrary_string "
                  //like this
                  classes:"foo",
                  after the module: line
                  to the instance you dont want the symbols to show
                  then use
                  .arbitrary_string .symbol {
                       display:none;
                  /*like this */
                  .foo .symbol {
                       display:none;
                    I think you can add the caledar_name selector too
                    from the ext3 doc
                    .event` : Every event has this selector. Each event could have these class names together by its condition.
                      - `.continueFromPreviousWeek`, `.continueToNextWeek`
                      - `.calendar_{calendarName}`    <-------
                      S374n
                      Is it possible to scroll this calendar with a button on GPIO, next month or prev month? Where can i find more details on this please, found some ideas but not this specific calendar.
                      Thank you.
                        sdetweil @S374n
                        @S374n you can use mmm-pages, create three pages
                        Three instances of ext3. One on each page,
                        mode:“month”
                        monthIndex: 0/1/2. For this month, next month and month after that (-1 for month before current)
                        Mmm-page-indicator creates buttons you can customize look w css, and will let you Move between pages on demand , pages also rotates
                          S374n @sdetweil
                          @sdetweil Thank you for the idea. I’ll look into it.
                            bicolorbore586 @MMRIZE
                            My MagicMirror has been out of action for a few months now, mainly due to a kitchen renovation, but am looking at getting it back up and running.
                            I’d previously had MMM-CalendarExt3 working with a few different calendars, notably a birthday calendar, where it would show an icon in the cell header.
                            However since updating the MagicMirror software it no longer seems possible to do. Below is the module extract from config.js, and is what has been previously used. Now upon starting MM with this in place I’m told [ERROR] Your configuration file contains syntax errors :( ‘document’ is not defined.
                            Anyone able to assist with what the issue is and how to resolve it?
                            		module: "MMM-CalendarExt3", //https://github.com/MMRIZE/MMM-CalendarExt3
                            		position: "lower_third",
                            		//header: "FamCal",
                            			mode: "month",
                            			useWeather: false,
                            			weekIndex: 0,
                            			weeksInView: 5,
                            			instanceId: "basicCalendar",
                            			locale: "en-GB",
                            			maxEventLines: 6,
                            			firstDayOfWeek: 1,
                            			headerWeekDayOptions: {weekday: "short"},
                            			refreshInterval: 60 * 10 * 1000, // 3600000, // every hour // 60 * 10 * 1000, // too frequent refresh. 10 minutes is enough.
                            			calendarSet: ["Family Calendar", "UK Holidays", "Birthday",],
                            			manipulateDateCell: (cellDom, events) => {
                            				if (Array.isArray(events) && events.some(e => e.calendarName === 'Birthday')) {
                            					let dateIcon = document.createElement ('span')
                            					dateIcon.classList.add ('fa', 'fa-fas', 'fa-fw', 'fa-gift')
                            					dateIcon.style.color = 'cornflowerblue'
                            					let header = cellDom.querySelector ('.cellHeader')
                            					let celldate = header.querySelector ('.cellDate')
                            					header.insertBefore (dateIcon, celldate)
                            			eventTransformer: (ev) => 	{
                            				if (ev.calendarName === 'Birthday') ev.skip = true
                            				else if (ev.title.search("B -") > -1) ev.color = "brown"
                            				else if (ev.title.search("C -") > -1) ev.color = "hotpink"
                            				else if (ev.title.search("E -") > -1) ev.color = "orange"
                            				else if (ev.title.search("I -") > -1) ev.color = "green"
                            				else if (ev.title.search("G") > -1) ev.color = "white"
                            				else if (ev.title.search("Bday") > -1) ev.title = ""
                            				return ev
                            			eventPayload: (payload) => {
                            				for (let ev of payload) {
                            					if (ev.fullDayEvent) {
                            						let gap = +ev.endDate - +ev.startDate
                            						if (gap % (1000 * 60 * 60 * 24) === 0) {
                            							ev.startDate = new Date(+ev.startDate).setHours(0, 0, 0, 0)
                            							ev.endDate = new Date(+ev.startDate + gap).setMilliseconds(-1)
                            				return payload
                              sdetweil @bicolorbore586
                              @bicolorbore586 can you do
                              npm run config:check
                              does it produce the same error?
                              also do
                              node -c config/config.js
                              if it returns and displays nothing, then node did not detect any syntax errors.
                              edit: I can reproduce this
                                @bicolorbore586 add this to the top of config.js, very first line
                                var document;
                                I’ll open a bug report
                                I opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3990
                                  bicolorbore586 @sdetweil
                                  @sdetweil config:check returns the same error
                                  The node one doesn’t produce anything
                                  Adding var document; to the config.js gives parsing error unexpected keyword ‘var’
                                    @bicolorbore586 very first line
                                    Right?
                                      @sdetweil it wasn’t. Does it need to be before let config = { or the fist line after that?
                                        @bicolorbore586 very first line of the file, all by itself
                                        Before any comments
                                          @sdetweil that appears to have worked. Out of interest. What does that do?
                                            @bicolorbore586 the module code you have used the global variable document to examine the web page contents
                                            The syntax checker found the use, but didn’t know that this code (config.js is a JavaScript file) was loaded in a browser
                                            So it reported use of an undeclared variable
                                            The fix was to declare the variable as a global so the checker will be happy
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
