    MMM-CalendarExt3
    679 Posts 82 Posters 2.7m Views 86 Watching
    • P Offline
      pastormingle @MMRIZE
      @MMRIZE When i put in for 3 calendar it’s only displaying the one for google1 account.
      	header: "calendar source",
      	position: "top_left", // <-- Remove this line to hide this module.
      		broadcastPastEvents: true,
      		maximumNumberOfDays: 45,
      				symbol: "calendar-check",
      				url:"outlook",
      				color: "red",
      				symbol: "car-side",
      				url:"google1",
      				color: "orange",
      				symbol: "recycle",
      				url:"google2",
      				color: "green",
      	module: "MMM-CalendarExt3",
      	position: "bottom_bar",
      	header: "My Calendar for 3 weeks",
      		mode: 'week',
      M P 2 Replies Last reply Reply Quote 0
        MMRIZE @pastormingle
        @pastormingle
        Did you test with my example URL or yours?
        I need the real URL of calendar feeds to diagnose. send URLs to my email. (eouia0819@gmail.com)
        • P Offline
          @MMRIZE should be in your email box… thanks.
            @pastormingle replied. From now on, let’s discuss this with email. I’ll leave the summary here later.
            • P Offline
              pastormingle @pastormingle
              @pastormingle Seems that when i loaded the outlook.ics it takes it about 10 min loaded when add addiational calendars. I have not errors in the log but it just slow to load when you restart if you have other calendars. What could it be? Do you have a fix for this?
                @pastormingle
                Is fetching slow? Or is drawing slow? Different reason, different solution.
                If fetching is slow; That is not my bad. Adjust interval of fetching calendar in calendar module.
                If drawing is slow(after fetched normally); Adjust waitFetch and refreshInterval. This thing is not “FIX”, just “configuration”
                However more frequent Fetching would give the ics host server more traffic.
                10mins late change, I think it’s sufficiently affordable. Your mirror is not the train time signboard of the station.
                • P Offline
                  @MMRIZE Not sure which is just doesn’t work till after 10 min passes… If i only put the outlook calendar in it’s instentances. where do you abjust the fetch?
                  • W Offline
                    whimsicality @MMRIZE
                    @MMRIZE thank you so much for this! I successfully hid the times with the CSS you gave. But when I input the eventtransformer code, it causes NaN:NaN to show before all the events. Do you have any insight?
                      MMRIZE @whimsicality
                      @whimsicality
                      Show me what you did.
                      • W Offline
                        @MMRIZE
                        • 30
                        • 31
                        • 32
                        • 33
                        • 34
                        • 67
                        • 68
                        • 32 / 68
