    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • A
      alfi153
      Hello.
      Is it possible that with the Calender-ext3 in the weekly display the calendar entries are displayed in two or three lines?
      • CyruS1337C
        CyruS1337 Project Sponsor
        Hello everyone
        I hope you can help me. I’m trying to get the calendar to display in Calendar Ext3.
        This is what my configuration looks like
                                    broadcastPastEvents: true, // <= IMPORTANT to see past events
                                        url: "https://calendar.google.com/calendar/ical/....................ics",
                                        name: "Andreas", // <= RECOMMENDED to assign name
                                        color: "red" // <= RECOMMENDED to assign color
                                  module: "MMM-CalendarExt3",
                                  position: "bottom_bar",
                                   title: "",
                                    mode: "month",
                                    instanceId: "basicCalendar",
                                    locale: 'de-CH',
                                    maxEventLines: 5,
                                    firstDayOfWeek: 1,
                                    calendarSet: ['Andreas'],
          sdetweil @CyruS1337
          @CyruS1337 did you install the fix?
          https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
          CyruS1337C 2 Replies Last reply Reply Quote 1
          • CyruS1337C
            CyruS1337 Project Sponsor @sdetweil
            Great, it worked. I have one more question.
            Do I have to use the “calendar” module from MagicMirror, or would the MMM-MyCalendar module also work?
            			module: "MMM-MyCalendar",
            			position: "bottom_right",	// This can be any of the regions. Best results in left or right regions.
            			header: 'Kalender Andreas',
            			colored: true,
            			maxTitleLength: 30,
            			maximumEntries: 4,
            			displayRepeatingCountTitle: true,
            			timeFormat: "HH:mm",
            			dateFormat: "DD:MM:YYYY",
            			joiningWord: "um",
            				url: 'https://calendar.google.com/calendar/ical/................./basic.ics',
            				color: "#5b53d4",
            				symbol: 'calendar',
            				auth: {
            					user: 'username',
            					pass: 'superstrongpassword',
            					method: 'basic'
            			header: 'Kalender Daniela & Andreas',
            			colored: true,
            			maxTitleLength: 30,
            			maximumEntries: 4,
            			joiningWord: "um",
            				color: "#f05db0",
            				symbol: 'calendar',
            				auth: {
            					user: 'username',
            					method: 'basic'
              sdetweil @CyruS1337
              @CyruS1337 MAYBE it will work, but it is a clone of the default cal from 3 years ago, with the broken repeating schedule code…
              which I just fixed in the latest release 2.30.0, Jan 1…
              • CyruS1337C
                @sdetweil thanks a lot. It works
                  p1lspeda
                  CSS is driving my crazy.
                  As you can see in the above screenshot, today (Tuesday) the top (weather, today’s Date & Month) take up the entire width.
                  This is fine.
                  The “problem” was yesterday with the additional “CW13” which led to overlapping.
                  I was wondering; if I could minimize the padding around the current date (the red area in the screenshot), theoretically the space should be big enough for all info to be next to each other
                  I tried adjusting the css
                  .CX3 .today .cellDate {
                    padding: 1px 8px;
                  but unfortunately, that did not have any effect.
                  Can somebody point me in the right direction ?
                    sdetweil @p1lspeda
                    @p1lspeda I do not know , but you can use the developers window to fiddle with css changes live
                    see the second link in my signature below
                    also see this topic where we discussed css and the dev window just a couple days ago
                    https://forum.magicmirror.builders/topic/19559/css-modifications-on-a-module-which-has-no-own-css-styles
                    • BKeyportB
                      BKeyport Module Developer @p1lspeda
                      @p1lspeda
                      I think you’ll find that it’s because of the .cellDate property - it’s set to flex-grow: 3
                      Almost everything on that line is also connected to .cellHeader.
                      I disable the CW line manually (from habit, don’t know if it’s an option to do in config) along with a few other modifications (including eliminating weather through config):
                      .CX3 .cellHeader {
                        text-align: right;
                        height: var(--cellheaderheight);
                        padding: 2px;
                        display: flex;
                        flex-direction: row;
                        justify-content: space-between;
                        font-size: 100%;
                      /* Disable CW date */
                      .CX3 .cw {
                      	display: none;
                      This results in the header taking up the entire space.
                      Look for the .cellHeader properties in the main CSS file, and copy them over to your custom.css to mess with them all you want and see what happens.
                      Pay special attention to justify-content in .cellHeader in combination with the flex-grow in .cellDate
                        sdetweil @BKeyport
                        @BKeyport you can override in dev window, no need to copy
                        • BKeyportB
                          @sdetweil right, but once you have the changes you want, you have to figure out how to implement them, and I’ve noticed with CX3 and some other modules, sometimes the dev window flat out lies where to stuff the CSS for final.
                            sdetweil @BKeyport
                            @BKeyport you copy/paste from the top right to custom.css
                            with the selected selector from right of bottom left pane w the modulename class prefix
                            will post images later, in car now
                              @BKeyport never seen it lie
                                p1lspeda
                                Thanks folks,
                                much appreciated that you invest your free-time to help simpletons like me.
                                My custom.css now includes
                                .CX3 .cellHeader .cellDate {
                                        flex-grow: 0;
                                .CX3 .cw::before {
                                        content: "CW";
                                        margin-right: 0px;
                                which seems to achieve what I was/am looking for.
                                  sdetweil @BKeyport
                                  @BKeyport here is my dev window steps
                                  the background area for the today highlight is smaller than the font size (set with the cx3-… properties)
                                  now w the element selected
                                  can’t copy/paste the selector list bottom,
                                  so copy the element it self
                                  and paste into editor on custom.css
                                  now keep/remove the text to match the bottom selector row
                                  div .cell.today.thisMonth.thisYear.year_2025.month_3.date_25.weekday_2 div.cellHeader div.cellDate
                                  add the module name in front
                                  .CX3 div .cell.today.thisMonth.thisYear.year_2025.month_3.date_25.weekday_2 div.cellHeader div.cellDate {
                                  then copy the change in the dev window
                                  and paste into custom.css inside the braces of the thing you just added
                                   height: 1em;
                                  text-align: left;
                                  now. you MIGHT know (or not) that we ONLY need to target the ‘today’ and ‘celldate’ classes , not JUST this ACTUAL date (mar 25)
                                  so we should shorten the selector… so it also works tomorrow
                                  .CX3 div .cell.today div.cellDate {
                                   height: 1em;
                                  every module it different, so it takes some thinking about what you are seeing
                                    cricket
                                    Hi - I have struggled with this for the past 24 hours and I cannot figure it. If someone can provide me ELI5 instructions I would appreciate it as CSS is not my strong suit. I am changing things in the custom.css file - perhaps what I want to do cannot be changed there.
                                    I would like to change the width and height of the calendar boxes, regardless of the data in them. I have figured out how to increase font size, but the cell/box size does not grow dynamically as thought it would. Any help appreciated.
                                    .CX3 {
                                      font-size: 20px;
                                      sdetweil @cricket
                                      @cricket you need to change the – variables he has defined… see the README.md file
                                      https://github.com/MMRIZE/MMM-CalendarExt3?tab=readme-ov-file#styling-with-css
                                      from configuration means
                                      fontSize	'18px'	Default font size of this module.
                                      eventHeight	'22px'	The height of each event.
                                        cricket @sdetweil
                                        Believe me I have and have looked at it at least times, I simply don’t understand how to achieve what I am asking. I have figured out the font size by what I included above. But I don’t understand how change the size of the day cell/box even if it is empty.
                                          sdetweil @cricket
                                          @cricket so, ‘simple’ way is to add more event lines to the box which will make it taller
                                          maxeventlines: 10 or whatever
                                          maxevents*lineHeight = size of box.
                                          lineHeight = fontsize+4 (in the default config)
                                          all of the important values are configurable in the module config, so you dont have to mess with css for this
                                          C 3 Replies Last reply Reply Quote 1
                                            cricket @sdetweil
                                            @sdetweil said in MMM-CalendarExt3:
                                            Thank you very much for this - I will give this a go!
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 32 / 35
