    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      @BKeyport never seen it lie
        p1lspeda
        Thanks folks,
        much appreciated that you invest your free-time to help simpletons like me.
        My custom.css now includes
        .CX3 .cellHeader .cellDate {
                flex-grow: 0;
        .CX3 .cw::before {
                content: "CW";
                margin-right: 0px;
        which seems to achieve what I was/am looking for.
          sdetweil @BKeyport
          @BKeyport here is my dev window steps
          the background area for the today highlight is smaller than the font size (set with the cx3-… properties)
          now w the element selected
          can’t copy/paste the selector list bottom,
          so copy the element it self
          and paste into editor on custom.css
          now keep/remove the text to match the bottom selector row
          div .cell.today.thisMonth.thisYear.year_2025.month_3.date_25.weekday_2 div.cellHeader div.cellDate
          add the module name in front
          .CX3 div .cell.today.thisMonth.thisYear.year_2025.month_3.date_25.weekday_2 div.cellHeader div.cellDate {
          then copy the change in the dev window
          and paste into custom.css inside the braces of the thing you just added
           height: 1em;
          text-align: left;
          now. you MIGHT know (or not) that we ONLY need to target the ‘today’ and ‘celldate’ classes , not JUST this ACTUAL date (mar 25)
          so we should shorten the selector… so it also works tomorrow
          .CX3 div .cell.today div.cellDate {
           height: 1em;
          every module it different, so it takes some thinking about what you are seeing
            cricket
            Hi - I have struggled with this for the past 24 hours and I cannot figure it. If someone can provide me ELI5 instructions I would appreciate it as CSS is not my strong suit. I am changing things in the custom.css file - perhaps what I want to do cannot be changed there.
            I would like to change the width and height of the calendar boxes, regardless of the data in them. I have figured out how to increase font size, but the cell/box size does not grow dynamically as thought it would. Any help appreciated.
            .CX3 {
              font-size: 20px;
              sdetweil @cricket
              @cricket you need to change the – variables he has defined… see the README.md file
              https://github.com/MMRIZE/MMM-CalendarExt3?tab=readme-ov-file#styling-with-css
              from configuration means
              fontSize	'18px'	Default font size of this module.
              eventHeight	'22px'	The height of each event.
                cricket @sdetweil
                Believe me I have and have looked at it at least times, I simply don’t understand how to achieve what I am asking. I have figured out the font size by what I included above. But I don’t understand how change the size of the day cell/box even if it is empty.
                  sdetweil @cricket
                  @cricket so, ‘simple’ way is to add more event lines to the box which will make it taller
                  maxeventlines: 10 or whatever
                  maxevents*lineHeight = size of box.
                  lineHeight = fontsize+4 (in the default config)
                  all of the important values are configurable in the module config, so you dont have to mess with css for this
                  C 3 Replies Last reply Reply Quote 1
                    cricket @sdetweil
                    @sdetweil said in MMM-CalendarExt3:
                    Thank you very much for this - I will give this a go!
                      cricket @sdetweil
                      Outstanding - this did exactly what I was looking for. I also a the appreciate the explanation. I am catching on slowly!
                        cricket @sdetweil
                        Last thing for me on this - is there a way to move the module down? My screen is portrait and it covers up some top modules. I am trying to move the module down with
                        .region.middle.center {
                                top: 50px;
                        I have experimented with positive and negative numbers with wild results. It pushes the calendar off the screen a the top and only shows about half LOL.
                        Should I be modifying this in the module section of the config.js file or in the custom.css file as above. With the right commands of course.
                          sdetweil @cricket
                          @cricket awesome!
                            sdetweil @cricket
                            @cricket move,
                            put it on the bottom instead of center
                              cricket @sdetweil
                              Not sure if this is the “right” way but this worked:
                                      margin-top: 150px;
                              Even a blind squirrel… :-).
                                p1lspeda
                                Hi folks,
                                it’s me again with a (probably) simple solution.
                                After I did a complete fresh install and re-added my custom.css, my Calendar looks a little odd - it triggers my OCD.
                                I guess I do not need to explain what is bothering me.
                                Why is the weather info centered on monday ?
                                How do I get CW, Weather and Current Day in 1 single line ?
                                This is my current custom.css for MMM-CalendarExt3
                                .CX3 .cw {
                                        color: white;
                                .CX3 .weekend_2 {
                                        color: white;
                                .CX3 .weekend_1 {
                                        color: white;
                                .CX3 .event {
                                        border: none;
                                .CX3 .cell {
                                        border: none;
                                        background-color: rgba(255,255,255,0);
                                        flex-grow: 0;
                                .CX3 .cw::before {
                                        content: "CW";
                                        margin-right: 0px;
                                Ideas/Tips/Hints are much appreciated.
                                What I do not understand is, that this has changed after I did a fresh install but re-added my backed up custom.css :-/
                                  sdetweil @p1lspeda
                                  @p1lspeda said in MMM-CalendarExt3:
                                  did you edit the css in the module folder??
                                  this is WHY you DON’T do that…
                                    sdetweil @p1lspeda
                                    @p1lspeda first thing is to disable your settings in custom.css and see what the module provides
                                      p1lspeda @sdetweil
                                      not that I can remember as this would mess up things.
                                      Luckily I found a back up my “old” (pre-fresh install) MMM-CalendarExt3.css and my “new” (post-fresh install) MMM-CalendarExt3.css.
                                      And they are a match, so there is no difference.
                                      Any ideas ?
                                        p1lspeda @sdetweil
                                        We are getting there !
                                        The module - without custom.css settings - already triggers my OCD
                                          sdetweil @p1lspeda
                                          @p1lspeda well, that is ‘today’ style… so thats where I would look…
                                          .CX3 .today .cellDate {
                                            font-weight: bold;
                                            background-color: white;
                                            color: black;
                                            border-radius: 8px;
                                            padding: 1px 8px;
                                            margin: 1px;
                                            line-height: 100%;
                                            p1lspeda @sdetweil
                                            I could narrow it down to cellWeather but I cannot find any css-styles in the module’s *.css :/
                                            This means I am lost as to where to start testing :(
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 32 / 35
