    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
      cricket @sdetweil
      Believe me I have and have looked at it at least times, I simply don’t understand how to achieve what I am asking. I have figured out the font size by what I included above. But I don’t understand how change the size of the day cell/box even if it is empty.
        sdetweil @cricket
        @cricket so, ‘simple’ way is to add more event lines to the box which will make it taller
        maxeventlines: 10 or whatever
        maxevents*lineHeight = size of box.
        lineHeight = fontsize+4 (in the default config)
        all of the important values are configurable in the module config, so you dont have to mess with css for this
        C 3 Replies Last reply Reply Quote 1
          cricket @sdetweil
          @sdetweil said in MMM-CalendarExt3:
          Thank you very much for this - I will give this a go!
            cricket @sdetweil
            Outstanding - this did exactly what I was looking for. I also a the appreciate the explanation. I am catching on slowly!
              cricket @sdetweil
              Last thing for me on this - is there a way to move the module down? My screen is portrait and it covers up some top modules. I am trying to move the module down with
              .region.middle.center {
                      top: 50px;
              I have experimented with positive and negative numbers with wild results. It pushes the calendar off the screen a the top and only shows about half LOL.
              Should I be modifying this in the module section of the config.js file or in the custom.css file as above. With the right commands of course.
                sdetweil @cricket
                @cricket awesome!
                  sdetweil @cricket
                  @cricket move,
                  put it on the bottom instead of center
                    cricket @sdetweil
                    Not sure if this is the “right” way but this worked:
                            margin-top: 150px;
                    Even a blind squirrel… :-).
                      p1lspeda
                      Hi folks,
                      it’s me again with a (probably) simple solution.
                      After I did a complete fresh install and re-added my custom.css, my Calendar looks a little odd - it triggers my OCD.
                      I guess I do not need to explain what is bothering me.
                      Why is the weather info centered on monday ?
                      How do I get CW, Weather and Current Day in 1 single line ?
                      This is my current custom.css for MMM-CalendarExt3
                      .CX3 .cw {
                              color: white;
                      .CX3 .weekend_2 {
                              color: white;
                      .CX3 .weekend_1 {
                              color: white;
                      .CX3 .event {
                              border: none;
                      .CX3 .cell {
                              border: none;
                              background-color: rgba(255,255,255,0);
                      .CX3 .cellHeader .cellDate {
                              flex-grow: 0;
                      .CX3 .cw::before {
                              content: "CW";
                              margin-right: 0px;
                      Ideas/Tips/Hints are much appreciated.
                      What I do not understand is, that this has changed after I did a fresh install but re-added my backed up custom.css :-/
                        sdetweil @p1lspeda
                        @p1lspeda said in MMM-CalendarExt3:
                        did you edit the css in the module folder??
                        this is WHY you DON’T do that…
                          sdetweil @p1lspeda
                          @p1lspeda first thing is to disable your settings in custom.css and see what the module provides
                            p1lspeda @sdetweil
                            not that I can remember as this would mess up things.
                            Luckily I found a back up my “old” (pre-fresh install) MMM-CalendarExt3.css and my “new” (post-fresh install) MMM-CalendarExt3.css.
                            And they are a match, so there is no difference.
                            Any ideas ?
                              p1lspeda @sdetweil
                              We are getting there !
                              The module - without custom.css settings - already triggers my OCD
                                sdetweil @p1lspeda
                                @p1lspeda well, that is ‘today’ style… so thats where I would look…
                                .CX3 .today .cellDate {
                                  font-weight: bold;
                                  background-color: white;
                                  color: black;
                                  border-radius: 8px;
                                  padding: 1px 8px;
                                  margin: 1px;
                                  line-height: 100%;
                                  p1lspeda @sdetweil
                                  I could narrow it down to cellWeather but I cannot find any css-styles in the module’s *.css :/
                                  This means I am lost as to where to start testing :(
                                    sdetweil @p1lspeda
                                    @p1lspeda
                                    they are there…
                                    .CX3 .cellHeader .cellWeather {
                                      color: white;
                                      margin: 2px;
                                      font-size: 100%;
                                      align-self: center;
                                    .CX3 .cellHeader .cellWeather .icon {
                                      font-size: 100%;
                                      font-weight: bold;
                                    .CX3 .cellHeader .cellWeather .maxTemp {
                                      color: white;
                                      font-weight: bold;
                                      font-size: 90%;
                                    .CX3 .cellHeader .cellWeather .minTemp {
                                      color: darkgray;
                                      font-weight: normal;
                                    .CX3 .cellHeader .cellWeather .temperature {
                                      display: var(--displayWeatherTemp);
                                      padding-left: 5px;
                                      font-size: 90%;
                                    .CX3 .cellHeader .cellWeather .maxTemp::before {
                                      content: " \25b2";
                                    .CX3 .cellHeader .cellWeather .minTemp::before {
                                      content: " \25bc";
                                    .CX3 .cellHeader .cellWeather .temperature::after {
                                      content: "° ";
                                      p1lspeda @sdetweil
                                      I am sorry :(
                                      Might need some new glasses after all
                                        sdetweil @p1lspeda
                                        @p1lspeda sometimes the class references are not standalone
                                        .cellWeather
                                        the selector says when the element (in tree) has ALL these classes… then
                                        if no spaces then if THIS element has ALL these classes
                                          p1lspeda @sdetweil
                                          I managed to figure it out.
                                          Just had to play around with the font-size and now it’s as I like it,
                                          Thanks for your patience.
                                            sdetweil @p1lspeda
                                            @p1lspeda awesome
                                            did you use the dev window?
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 33 / 35
