    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      cricket
      Hi - I have struggled with this for the past 24 hours and I cannot figure it. If someone can provide me ELI5 instructions I would appreciate it as CSS is not my strong suit. I am changing things in the custom.css file - perhaps what I want to do cannot be changed there.
      I would like to change the width and height of the calendar boxes, regardless of the data in them. I have figured out how to increase font size, but the cell/box size does not grow dynamically as thought it would. Any help appreciated.
      .CX3 {
        font-size: 20px;
        sdetweil @cricket
        @cricket you need to change the – variables he has defined… see the README.md file
        https://github.com/MMRIZE/MMM-CalendarExt3?tab=readme-ov-file#styling-with-css
        from configuration means
        fontSize	'18px'	Default font size of this module.
        eventHeight	'22px'	The height of each event.
        C 1 Reply Last reply
          cricket @sdetweil
          Believe me I have and have looked at it at least times, I simply don’t understand how to achieve what I am asking. I have figured out the font size by what I included above. But I don’t understand how change the size of the day cell/box even if it is empty.
            sdetweil @cricket
            @cricket so, ‘simple’ way is to add more event lines to the box which will make it taller
            maxeventlines: 10 or whatever
            maxevents*lineHeight = size of box.
            lineHeight = fontsize+4 (in the default config)
            all of the important values are configurable in the module config, so you dont have to mess with css for this
            C 3 Replies Last reply
              cricket @sdetweil
              @sdetweil said in MMM-CalendarExt3:
              Thank you very much for this - I will give this a go!
                cricket @sdetweil
                Outstanding - this did exactly what I was looking for. I also a the appreciate the explanation. I am catching on slowly!
                  cricket @sdetweil
                  Last thing for me on this - is there a way to move the module down? My screen is portrait and it covers up some top modules. I am trying to move the module down with
                  .region.middle.center {
                          top: 50px;
                  I have experimented with positive and negative numbers with wild results. It pushes the calendar off the screen a the top and only shows about half LOL.
                  Should I be modifying this in the module section of the config.js file or in the custom.css file as above. With the right commands of course.
                    sdetweil @cricket
                    @cricket awesome!
                      sdetweil @cricket
                      @cricket move,
                      put it on the bottom instead of center
                        cricket @sdetweil
                        Not sure if this is the “right” way but this worked:
                                margin-top: 150px;
                        Even a blind squirrel… :-).
                          p1lspeda
                          Hi folks,
                          it’s me again with a (probably) simple solution.
                          After I did a complete fresh install and re-added my custom.css, my Calendar looks a little odd - it triggers my OCD.
                          I guess I do not need to explain what is bothering me.
                          Why is the weather info centered on monday ?
                          How do I get CW, Weather and Current Day in 1 single line ?
                          This is my current custom.css for MMM-CalendarExt3
                          .CX3 .cw {
                                  color: white;
                          .CX3 .weekend_2 {
                                  color: white;
                          .CX3 .weekend_1 {
                                  color: white;
                          .CX3 .event {
                                  border: none;
                          .CX3 .cell {
                                  border: none;
                                  background-color: rgba(255,255,255,0);
                          .CX3 .cellHeader .cellDate {
                                  flex-grow: 0;
                          .CX3 .cw::before {
                                  content: "CW";
                                  margin-right: 0px;
                          Ideas/Tips/Hints are much appreciated.
                          What I do not understand is, that this has changed after I did a fresh install but re-added my backed up custom.css :-/
                          S 2 Replies Last reply
                            sdetweil @p1lspeda
                            @p1lspeda said in MMM-CalendarExt3:
                            did you edit the css in the module folder??
                            this is WHY you DON’T do that…
                            P 1 Reply Last reply
                              sdetweil @p1lspeda
                              @p1lspeda first thing is to disable your settings in custom.css and see what the module provides
                                p1lspeda @sdetweil
                                not that I can remember as this would mess up things.
                                Luckily I found a back up my “old” (pre-fresh install) MMM-CalendarExt3.css and my “new” (post-fresh install) MMM-CalendarExt3.css.
                                And they are a match, so there is no difference.
                                Any ideas ?
                                  p1lspeda @sdetweil
                                  We are getting there !
                                  The module - without custom.css settings - already triggers my OCD
                                    sdetweil @p1lspeda
                                    @p1lspeda well, that is ‘today’ style… so thats where I would look…
                                    .CX3 .today .cellDate {
                                      font-weight: bold;
                                      background-color: white;
                                      color: black;
                                      border-radius: 8px;
                                      padding: 1px 8px;
                                      margin: 1px;
                                      line-height: 100%;
                                      p1lspeda @sdetweil
                                      I could narrow it down to cellWeather but I cannot find any css-styles in the module’s *.css :/
                                      This means I am lost as to where to start testing :(
                                        sdetweil @p1lspeda
                                        @p1lspeda
                                        they are there…
                                        .CX3 .cellHeader .cellWeather {
                                          color: white;
                                          margin: 2px;
                                          font-size: 100%;
                                          align-self: center;
                                        .CX3 .cellHeader .cellWeather .icon {
                                          font-size: 100%;
                                          font-weight: bold;
                                        .CX3 .cellHeader .cellWeather .maxTemp {
                                          color: white;
                                          font-weight: bold;
                                          font-size: 90%;
                                        .CX3 .cellHeader .cellWeather .minTemp {
                                          color: darkgray;
                                          font-weight: normal;
                                        .CX3 .cellHeader .cellWeather .temperature {
                                          display: var(--displayWeatherTemp);
                                          padding-left: 5px;
                                          font-size: 90%;
                                        .CX3 .cellHeader .cellWeather .maxTemp::before {
                                          content: " \25b2";
                                        .CX3 .cellHeader .cellWeather .minTemp::before {
                                          content: " \25bc";
                                        .CX3 .cellHeader .cellWeather .temperature::after {
                                          content: "° ";
                                          p1lspeda @sdetweil
                                          I am sorry :(
                                          Might need some new glasses after all
                                            sdetweil @p1lspeda
                                            @p1lspeda sometimes the class references are not standalone
                                            .cellWeather
                                            the selector says when the element (in tree) has ALL these classes… then
                                            if no spaces then if THIS element has ALL these classes
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 33 / 35
