    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      sdetweil @gonzonia
      @gonzonia if you installed MagicMirror 2.30
      did you also install the fix?
      https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events?page=7
      • G
        gonzonia @sdetweil
        @sdetweil No. I had not seen that. Installing now. Thanks!
          redink
          Would it be possible to combine the calendar color indicator at the time using just CSS?
          Right now, it’s a colored circle and the time next to it and I was wondering if it would somehow be possible to have the time be inside the circle, or have the time be a different background color.
          My display is quite small, and saving a few extra pixels would be nice.
          • A
            alfi153
            Hello.
            Is it possible that with the Calender-ext3 in the weekly display the calendar entries are displayed in two or three lines?
            • CyruS1337C
              CyruS1337 Project Sponsor
              Hello everyone
              I hope you can help me. I’m trying to get the calendar to display in Calendar Ext3.
              This is what my configuration looks like
                                          broadcastPastEvents: true, // <= IMPORTANT to see past events
                                              url: "https://calendar.google.com/calendar/ical/....................ics",
                                              name: "Andreas", // <= RECOMMENDED to assign name
                                              color: "red" // <= RECOMMENDED to assign color
                                        module: "MMM-CalendarExt3",
                                        position: "bottom_bar",
                                         title: "",
                                          mode: "month",
                                          instanceId: "basicCalendar",
                                          locale: 'de-CH',
                                          maxEventLines: 5,
                                          firstDayOfWeek: 1,
                                          calendarSet: ['Andreas'],
                sdetweil @CyruS1337
                @CyruS1337 did you install the fix?
                CyruS1337C 2 Replies Last reply Reply Quote 1
                • CyruS1337C
                  CyruS1337 Project Sponsor @sdetweil
                  Great, it worked. I have one more question.
                  Do I have to use the “calendar” module from MagicMirror, or would the MMM-MyCalendar module also work?
                  			module: "MMM-MyCalendar",
                  			position: "bottom_right",	// This can be any of the regions. Best results in left or right regions.
                  			header: 'Kalender Andreas',
                  			colored: true,
                  			maxTitleLength: 30,
                  			maximumEntries: 4,
                  			displayRepeatingCountTitle: true,
                  			timeFormat: "HH:mm",
                  			dateFormat: "DD:MM:YYYY",
                  			joiningWord: "um",
                  				url: 'https://calendar.google.com/calendar/ical/................./basic.ics',
                  				color: "#5b53d4",
                  				symbol: 'calendar',
                  				auth: {
                  					user: 'username',
                  					pass: 'superstrongpassword',
                  					method: 'basic'
                  			header: 'Kalender Daniela & Andreas',
                  			colored: true,
                  			maxTitleLength: 30,
                  			maximumEntries: 4,
                  			joiningWord: "um",
                  				color: "#f05db0",
                  				symbol: 'calendar',
                  				auth: {
                  					user: 'username',
                  					method: 'basic'
                    sdetweil @CyruS1337
                    @CyruS1337 MAYBE it will work, but it is a clone of the default cal from 3 years ago, with the broken repeating schedule code…
                    which I just fixed in the latest release 2.30.0, Jan 1…
                    • CyruS1337C
                      @sdetweil thanks a lot. It works
                        p1lspeda
                        CSS is driving my crazy.
                        As you can see in the above screenshot, today (Tuesday) the top (weather, today’s Date & Month) take up the entire width.
                        This is fine.
                        The “problem” was yesterday with the additional “CW13” which led to overlapping.
                        I was wondering; if I could minimize the padding around the current date (the red area in the screenshot), theoretically the space should be big enough for all info to be next to each other
                        I tried adjusting the css
                        .CX3 .today .cellDate {
                          padding: 1px 8px;
                        but unfortunately, that did not have any effect.
                        Can somebody point me in the right direction ?
                          sdetweil @p1lspeda
                          @p1lspeda I do not know , but you can use the developers window to fiddle with css changes live
                          see the second link in my signature below
                          also see this topic where we discussed css and the dev window just a couple days ago
                          https://forum.magicmirror.builders/topic/19559/css-modifications-on-a-module-which-has-no-own-css-styles
                          • BKeyportB
                            BKeyport Module Developer @p1lspeda
                            @p1lspeda
                            I think you’ll find that it’s because of the .cellDate property - it’s set to flex-grow: 3
                            Almost everything on that line is also connected to .cellHeader.
                            I disable the CW line manually (from habit, don’t know if it’s an option to do in config) along with a few other modifications (including eliminating weather through config):
                            .CX3 .cellHeader {
                              text-align: right;
                              height: var(--cellheaderheight);
                              padding: 2px;
                              display: flex;
                              flex-direction: row;
                              justify-content: space-between;
                              font-size: 100%;
                            /* Disable CW date */
                            .CX3 .cw {
                            	display: none;
                            This results in the header taking up the entire space.
                            Look for the .cellHeader properties in the main CSS file, and copy them over to your custom.css to mess with them all you want and see what happens.
                            Pay special attention to justify-content in .cellHeader in combination with the flex-grow in .cellDate
                              sdetweil @BKeyport
                              @BKeyport you can override in dev window, no need to copy
                              • BKeyportB
                                @sdetweil right, but once you have the changes you want, you have to figure out how to implement them, and I’ve noticed with CX3 and some other modules, sometimes the dev window flat out lies where to stuff the CSS for final.
                                  sdetweil @BKeyport
                                  @BKeyport you copy/paste from the top right to custom.css
                                  with the selected selector from right of bottom left pane w the modulename class prefix
                                  will post images later, in car now
                                    @BKeyport never seen it lie
                                      p1lspeda
                                      Thanks folks,
                                      much appreciated that you invest your free-time to help simpletons like me.
                                      My custom.css now includes
                                      .CX3 .cellHeader .cellDate {
                                              flex-grow: 0;
                                      .CX3 .cw::before {
                                              content: "CW";
                                              margin-right: 0px;
                                      which seems to achieve what I was/am looking for.
                                        sdetweil @BKeyport
                                        @BKeyport here is my dev window steps
                                        the background area for the today highlight is smaller than the font size (set with the cx3-… properties)
                                        now w the element selected
                                        can’t copy/paste the selector list bottom,
                                        so copy the element it self
                                        and paste into editor on custom.css
                                        now keep/remove the text to match the bottom selector row
                                        div .cell.today.thisMonth.thisYear.year_2025.month_3.date_25.weekday_2 div.cellHeader div.cellDate
                                        add the module name in front
                                        .CX3 div .cell.today.thisMonth.thisYear.year_2025.month_3.date_25.weekday_2 div.cellHeader div.cellDate {
                                        then copy the change in the dev window
                                        and paste into custom.css inside the braces of the thing you just added
                                         height: 1em;
                                        text-align: left;
                                        now. you MIGHT know (or not) that we ONLY need to target the ‘today’ and ‘celldate’ classes , not JUST this ACTUAL date (mar 25)
                                        so we should shorten the selector… so it also works tomorrow
                                        .CX3 div .cell.today div.cellDate {
                                         height: 1em;
                                        every module it different, so it takes some thinking about what you are seeing
                                          cricket
                                          Hi - I have struggled with this for the past 24 hours and I cannot figure it. If someone can provide me ELI5 instructions I would appreciate it as CSS is not my strong suit. I am changing things in the custom.css file - perhaps what I want to do cannot be changed there.
                                          I would like to change the width and height of the calendar boxes, regardless of the data in them. I have figured out how to increase font size, but the cell/box size does not grow dynamically as thought it would. Any help appreciated.
                                          .CX3 {
                                            font-size: 20px;
                                            sdetweil @cricket
                                            @cricket you need to change the – variables he has defined… see the README.md file
                                            https://github.com/MMRIZE/MMM-CalendarExt3?tab=readme-ov-file#styling-with-css
                                            from configuration means
                                            fontSize	'18px'	Default font size of this module.
                                            eventHeight	'22px'	The height of each event.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 32 / 35
