    Few modules stuck in loading
    2 Posts 2 Posters 1.0k Views 2 Watching
      sceletus
      I have 2 modules (MMM-NetworkConnection and MMM-Jeedom) suck in “loading”.
      As I have 2 of them, I think the problem is not the modules but sonething with my Magic Mirror.
      I’m running a RPI4 with latest bulleye, latest MM all modules are up-to-date.
      First lines of my config.js
      var config = {
              port: 8080,
              address: "0.0.0.0",
              ipWhitelist: [], // Set [] to allow all IP addresses.
              language: "fr",
              timeFormat: 24,
              units: "metric",code_text
      Is there anything I can check to debug this? a debug mode generating logs?
      Thanks in advance for help.
      Patrice
        sdetweil @sceletus
        @sceletus you can check the messages where u start MagicMirror…
        either by
        npm start
        or
        pm2
        if pm2, then the command
        pm2 logs --lines=50
        will display the captured output
        AND
        in the developers window, ctrl-shift-i, and select the console tab and scroll up to see any error messages, usually red text
