    RPi 3B+ with 'Bullseye' can't rotate screen?
    19 Posts 9 Posters 7.4k Views 9 Watching
      sdetweil @fribse
      @fribse I do not know. maybe a bad HDMI cable or a bad adapter if using HDMI to DVI, or a bad monitor?
      all my monitors and TV’s work in any orientation.
      • AssassinsA Offline
        Assassins @fribse
        @fribse and is work on rpi3 to 😉
        • BKeyportB Online
          BKeyport Module Developer @fribse
          @fribse I don’t actually have a 3 with Bullseye, however, My next step would be to try the other GL drivers through raspiconfig.
          • F Offline
            fribse @sdetweil
            @sdetweil That would be odd, as it works with previous versions of Raspberry Pi OS?
            • F Offline
              fribse @BKeyport
              @BKeyport That is worth a try, didn’t think of that!
              • F Offline
                fribse @fribse
                @fribse Hmm, can’t make this work. I can get it to work on a RPi4, but not on a RPi3 with the ‘Screenconfiguration’ app.
                It’s really annoying, I would like to have screencast and remote-control modules enabled, so that Home Assistant can integrate to it, through the remote-control module, but that doesn’t work on Buster (the integration fails to set up), it fails because of some weird problem in the integration combined with the screencast, which the author can’t reproduce, which is very odd, as I can show it every time.
                I can get the integration to work on Bullseye together with the remote-control module and the screencast, but not on a RPi3, only on a RPi4, and even rotate the screen, but I don’t want to place a very hot and overly powerfull RPi4 behind the magicmirror.
                Damned if I do, and damned if I don’t.
                • F Offline
                  fribse @fribse
                  @fribse Ok, so now I’ve gotten a second RPi3b+. Apparently the monitor doesn’t like the way that Bullseye rotate the screen (by using the ‘Screen orientation’ in the GUI).
                  So how do I rotate the screen in ‘the old way’ which works fine on the monitor.
                  My guess is that it’s modifying the refresh rate beyond the capabilities of the monitor.
                  It’s usually running on 60Hz, and I tried changing it to 50Hz, but that didn’t change anything.
                  So what do I do now? I would really like to use the bullseye, as I can’t get Home Assistant to control the mirror if I have screencast installed on the mirror under Buster.
                  N6NGN 1 Reply Last reply Reply Quote 0
                  • N6NGN Offline
                    N6NG @fribse
                    @fribse I use a RPi3 B+ and Bullseye and I do the rotate in the boot/config.txt and it works ok for me.
                    karsten13K F 2 Replies Last reply Reply Quote 0
                    • karsten13K Offline
                      karsten13 @N6NG
                      @fribse
                      I have no solution for your problem but if you use the WebUI to change screen settings in bullseye the changes are made here:
                      pi@pi4:~ $ cat /usr/share/dispsetup.sh
                      #!/bin/sh
                      if ! grep -q 'Raspberry Pi' /proc/device-tree/model || (grep -q okay /proc/device-tree/soc/v3d@7ec00000/status 2> /dev/null || grep -q okay /proc/device-tree/soc/firmwarekms@7e600000/status 2> /dev/null || grep -q okay /proc/device-tree/v3dbus/v3d@7ec04000/status 2> /dev/null) ; then
                      if xrandr --output HDMI-1 --primary --mode 1920x1080 --rate 60.000 --pos 0x0 --rotate normal --output HDMI-2 --off --dryrun ; then
                      fi
                      fi
                      if [ -e /usr/share/tssetup.sh ] ; then
                      . /usr/share/tssetup.sh
                      fi
                      exit 0
                      So you could play with the xrandr command, may this helps …
                      • F Offline
                        fribse @N6NG
                        @N6NG Ok, and what are you writing in the config for it to work? That would be a big help for me :-)
                        kayakbabeK 1 Reply Last reply Reply Quote 0
