rotating the screen doesn't work
4 Posts 3 Posters 1.1k Views 3 Watching
    AnduriI
    Hey there,
    it’s been quite a while since I installed my MM.
    Now there was the time for an upgrade of the monitor and I decided to do it with a freshly installed pi to start fresh. That worked fine and I got it running very soon. Only problem is the rotation of the screen:
    As far as I know the old methom with boot/config.txt doesn’t work anymore, but I have to use xrandr.
    I can use DISPLAY=:0 xrandr --output HDMI-1 --rotate right in console to rotate, but when using @xrandr --output HDMI-1 --rotate right in /etc/xdg/lxsession/LXDE-pi/autostart it has no effect.
    What is to now correct way of doing it?
    Thanks a lot in advance,
    Anduril
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    K A 2 Replies Last reply Sep 13, 2023, 7:22 PM Reply Quote 0
      AnduriI
      well the problem was I think about privileges to issue the xrandr command from a shell. I got it worked out with xhost + and it works fine now. Thanks a lot for your help.
      • K Offline
        karsten13 @AnduriI
        @AnduriI
        you can change this in the raspian os gui somewhere in the menu.
        See also https://forum.magicmirror.builders/topic/16795/rpi-3b-with-bullseye-can-t-rotate-screen/13
          ankonaskiff17 @AnduriI
          @AnduriI is your @xrandr a copy/paste that @ symbol should not be there I don’t think
          You might want to read this which comes from the official Raspberry Pi site.
          Screenshot is of the Rotating your Screen function from my MM
          Rotating your Display
            AnduriI
