    Installing MMM-PIR-Sensor
    2 Posts 2 Posters 716 Views 2 Watching
    • N6NGN
      N6NG
      Tried to install MMM_PIR-Sensor and this is what I got:
      So I updated node-abi and it didn’t change anything.
      node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
      ⠋ Searching dependency tree
      An unhandled error occurred inside electron-rebuild
      Could not detect abi for version 17.2.0 and runtime electron. Updating “node-abi” might help solve this issue if it is a new release of electron
      Error: Could not detect abi for version 17.2.0 and runtime electron. Updating “node-abi” might help solve this issue if it is a new release of electron
      at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:36:9)
      at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:126:48)
      at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:404:23)
      at Object.doRebuild [as rebuild] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:427:16)
      at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:124:33
      at Generator.next ()
      at fulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:6:58)
      npm ERR! code 255
      npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor
      npm ERR! command failed
      npm ERR! command sh -c node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
      npm ERR! /home/pi/.npm/_logs/2022-06-07T18_39_56_149Z-debug-0.log
      pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm update node-abi
      Any suggestions?
      Dennis
        sdetweil @N6NG
        @N6NG really old code, archived. maybe this will help
        https://forum.magicmirror.builders/topic/16681/mmm-moduletogglebutton-install-error/2?_=1654646189462
