    Need to npm install valid-url everytime I deploy MM
    3 Posts 2 Posters 627 Views 2 Watching
    • G Offline
      gggg1981gggg
      Hi there.
      I love MM but I have a problem where everytime before deploying the container I have to edit the config and set the module calendar to disabled
      { disabled: true,
            header: "Cal",
            position: "bottom_right",
                  symbol: "calendar-check",
      	    url: "mycal"
      then after starting the container I go into the container
      then I get prompt and need to
      npm audit fix
      After all that I edit the config again and set the module calendar to enabled and everything works fine
      { disabled: false,
            header: "Cal",
      	    url: "mycal"
      Without doing that the container won’t work.
      How can I fix that?
      • G Offline
        gggg1981gggg @sdetweil
        calendar hasn’t used valid-url for almost a year.(2.16).
        That would make sense as I had this problem for quite a while everytime I was moving docker volumes between devices but I decided to ask for help just today.
        I removed
        /modules/default
        added dns entry to docker-compose as my calendar module could’t reach google and it is working now.
        Thank you
          sdetweil @gggg1981gggg
          @gggg1981gggg audit fix is unnecessary. nothing we can do about libs using libs using libs.etc that have old code. fix usually caused more problems than it fixes.
          • G Offline
            I removed
            /modules/default
            Thank you
