    SmartMirror with 50“ Samsung 4K TV Power Consumption
    power-savingpowerenergy savingsmart tvmagicmirror2raspberry pi
    2 Posts 2 Posters 1.4k Views 2 Watching
      anthem212
      Hello there,
      My old TV broke. It is Not really good for watching TV anymore but it would still work as a SmartMirror.
      So I wanna build one out of it, this will be my second. My first is a old Tablet.
      I wanna hang in on a Wall with a wooden frame and a Raspery behind it which is doing all the work. Maybe also Touchscreen and voicecommands.
      But I have one question because of the Energieusage.
      I want the TV something like “off” when nobody is walking in front of it or turning it on.
      But when you really turn off a Tv and want to start again it is booting this todays for a while, something like 30 seconds.
      I want this mirror always be ready to show something within one or two seconds when I press a button or walk in front of it. Without booting the TV every time. I also want the screen to go off after 30 seconds with no movement detection or when I press a button.
      So the raspery needs to be running al the time in the background yes but how do I do that with the tv?
      Is there something like a mode between off and on like a black screen or a energy saver which can be turned on and off controlled by the raspery?
      I really don’t want the tv always on showing black Color and burning tons of energy.
      Thank you,
      Best wishes,
      Anthem
        sdetweil @anthem212
        @anthem212 well there are three commands to turn off the output
        vcgencmd
        dpms
        these two turn off the HDMI port, NOT the monitor/tv
        and cec-client
        this turns off the monitor/tv
        IF it supports the cec command(correctly)
        and then you would need a people sensor,
        most use use infrared, as it’s ‘easy’.
        there are modules that put all this together.
        search here for MMM-PIR
        Now to get your speed requirements will be a little harder. I use TV’s for my two main mirror systems. 43 and 55 in.
        one supports cec, the other doesn’t.
        when I turn off the HDMI port on both, they put up a big NO INPUT screen , and power off after 15 minutes.
        that is energy star compliant.
        but you can’t turn them on via software
        if it supports cec, then maybe you can turn off/on via software. mine is inconsistent. always can turn on, but not off
        on is the same as pushing the button, takes 15 seconds, displays the product logo and all that.
        I gave up, and just hide the mm content and leave the TV’s on. the one in the hall I call the nightlight!
        I also use a webcam for motion detection, instead of pir, cause that’s what I had at the time
        as yours is a 4k tv, I’m guessing it supports cec
        install the cec-utils package on pi
        sudo apt install cec-utils
        this also only works on my pi 4. not pi3.
