    Calendar Heading Changes
    22 Posts 5 Posters 15.6k Views 4 Watching
    • O Offline
      onetwankyfive
      couldn’t you use different font awesome symbols when you put the calendar in the config
      ooom416354O 1 Reply Last reply Reply Quote 0
      • ooom416354O Offline
        ooom416354 @onetwankyfive
        @onetwankyfive I could but the idea is having some sort of legend as well. So you have the color coded symbols next to the events in the list but there is no way to tell who’s color is who’s (and with a bunch of really little kids, color is important)
        • brobergB Offline
          broberg Project Sponsor @ooom416354
          @ooom416354 if all names will be listed over ONE combined calendar you could just add it as static text.
            ooom416354 @broberg
            @broberg said in Calendar Heading Changes:
            Yep exactly, that would be the idea. Where would that static text be added, would it be in the config.js or would I have to create something for the custom.css?
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @ooom416354
              @ooom416354 you could use the helloworld module for it
                ooom416354 @strawberry 3.141
                @strawberry-3.141 so add the hello world module under the clock in the config.js and code it up to add the color coded “legend”, right?
                  @ooom416354 put it right above the calendar module in the config with the same position
                          module: 'helloworld',
                          position: 'top_left',
                              text: '<div>John</div><div>Jane</div>'
                  EDIT it wont let me do adding styling add style=“color: blue;” for John example behind the open div tag
                  ooom416354O B 3 Replies Last reply Reply Quote 0
                    @strawberry-3.141 perfect, I will do that. thanks again!
                      @strawberry-3.141 I see that, is it possible to just add 5 separate helloworld modules each stacked on top of each other, each with a different color?
                      strawberry 3.141S brobergB 2 Replies Last reply Reply Quote 0
                        @ooom416354 you could do that but each module has a margin around which takes up more space than adding all in one
                        • 3 / 3
