    Unable to start MM after updates
    2 Posts 2 Posters 672 Views 2 Watching
      Richard238
      Good news! This was OK after a reboot, but how do you restart MM manually now?
      pi@magicmirror:~ $ cd MagicMirror
      pi@magicmirror:~/MagicMirror $ pm2 stop all
      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
      [PM2] MagicMirror â
      ââââââ¬âââââââââââââââââââââ¬âââââââââââ¬âââââââ¬ââââââââââââ¬âââââââââââ¬âââââââââââ
      â id â name â mode â ⺠â status â cpu â memory â
      ââââââ¼âââââââââââââââââââââ¼âââââââââââ¼âââââââ¼ââââââââââââ¼âââââââââââ¼âââââââââââ¤
      â 0 â MagicMirror â fork â 1 â stopped â 0% â 0b â
      ââââââ´âââââââââââââââââââââ´âââââââââââ´âââââââ´ââââââââââââ´âââââââââââ´âââââââââââ
      pi@magicmirror:~/MagicMirror $ git pull && npm install
      From https://github.com/MichMich/MagicMirror
      a2d7cdcf…30d5bfe5 master -> origin/master
      • [new tag] v2.20.0 -> v2.20.0
        Updating a2d7cdcf…30d5bfe5
        Fast-forward
        .eslintrc.json | 2 ±
        .github/{FUNDING.yml => FUNDING.yaml} | 0
        .github/{codecov.yml => codecov.yaml} | 0
        .github/dependabot.yaml | 6 +
        .github/{stale.yml => stale.yaml} | 0
        …/{automated-tests.yml => automated-tests.yaml} | 7 ±
        …ov-test-suites.yml => codecov-test-suites.yaml} | 6 ±
        …nforce-changelog.yml => enforce-changelog.yaml} | 5 ±
        CHANGELOG.md | 27 ±
        fonts/package-lock.json | 28 ±
        fonts/package.json | 4 ±
        fonts/roboto.css | 19 ±
        js/defaults.js | 3 +
        js/electron.js | 2 ±
        js/fetch.js | 20 +
        js/server.js | 4 ±
        modules/default/calendar/calendar.js | 26 ±
        modules/default/calendar/calendarfetcher.js | 2 ±
        modules/default/calendar/calendarutils.js | 3 ±
        modules/default/newsfeed/newsfeedfetcher.js | 11 ±
        modules/default/weather/weather.js | 9 +
        modules/default/weather/weatherobject.js | 17 +
        package-lock.json | 5217 +++++++±----------
        package.json | 41 ±
        tests/e2e/env_spec.js | 6 ±
        tests/e2e/fonts.js | 6 ±
        tests/e2e/global-setup.js | 7 ±
        tests/e2e/ipWhitelist_spec.js | 10 ±
        tests/e2e/modules/alert_spec.js | 4 ±
        tests/e2e/modules/calendar_spec.js | 4 ±
        tests/e2e/modules/clock_es_spec.js | 4 ±
        tests/e2e/modules/clock_spec.js | 4 ±
        tests/e2e/modules/compliments_spec.js | 4 ±
        tests/e2e/modules/helloworld_spec.js | 4 ±
        tests/e2e/modules/newsfeed_spec.js | 4 ±
        tests/e2e/modules/weather_spec.js | 4 ±
        tests/e2e/modules_display_spec.js | 4 ±
        tests/e2e/modules_position_spec.js | 4 ±
        tests/e2e/port_config.js | 10 ±
        tests/e2e/vendor_spec.js | 6 ±
        tests/e2e/without_modules.js | 4 ±
        vendor/package-lock.json | 14 ±
        vendor/package.json | 2 ±
        43 files changed, 2482 insertions(+), 3082 deletions(-)
        rename .github/{FUNDING.yml => FUNDING.yaml} (100%)
        rename .github/{codecov.yml => codecov.yaml} (100%)
        create mode 100644 .github/dependabot.yaml
        rename .github/{stale.yml => stale.yaml} (100%)
        rename .github/workflows/{automated-tests.yml => automated-tests.yaml} (90%)
        rename .github/workflows/{codecov-test-suites.yml => codecov-test-suites.yaml} (84%)
        rename .github/workflows/{enforce-changelog.yml => enforce-changelog.yaml} (77%)
        create mode 100644 js/fetch.js
        npm WARN EBADENGINE Unsupported engine {
        npm WARN EBADENGINE package: ‘@jest/console@28.1.1’,
        npm WARN EBADENGINE required: { node: ‘^12.13.0 || ^14.15.0 || ^16.10.0 || >=17.0.0’ },
        npm WARN EBADENGINE current: { node: ‘v16.1.0’, npm: ‘7.11.2’ }
        npm WARN EBADENGINE }
        npm WARN EBADENGINE package: ‘@jest/core@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/environment@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/expect@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/expect-utils@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/fake-timers@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/globals@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/reporters@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/schemas@28.0.2’,
        npm WARN EBADENGINE package: ‘@jest/source-map@28.0.2’,
        npm WARN EBADENGINE package: ‘@jest/test-result@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/test-sequencer@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/transform@28.1.1’,
        npm WARN EBADENGINE package: ‘@jest/types@28.1.1’,
        npm WARN EBADENGINE package: ‘babel-jest@28.1.1’,
        npm WARN EBADENGINE package: ‘babel-plugin-jest-hoist@28.1.1’,
        npm WARN EBADENGINE package: ‘babel-preset-jest@28.1.1’,
        npm WARN EBADENGINE package: ‘diff-sequences@28.1.1’,
        npm WARN EBADENGINE package: ‘expect@28.1.1’,
        npm WARN EBADENGINE package: ‘jest@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-changed-files@28.0.2’,
        npm WARN EBADENGINE package: ‘jest-circus@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-cli@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-config@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-diff@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-docblock@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-each@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-environment-node@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-get-type@28.0.2’,
        npm WARN EBADENGINE package: ‘jest-haste-map@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-leak-detector@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-matcher-utils@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-message-util@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-mock@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-regex-util@28.0.2’,
        npm WARN EBADENGINE package: ‘jest-resolve@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-resolve-dependencies@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-runner@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-runtime@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-snapshot@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-util@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-validate@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-watcher@28.1.1’,
        npm WARN EBADENGINE package: ‘jest-worker@28.1.1’,
        npm WARN EBADENGINE package: ‘pretty-format@28.1.1’,
      magicmirror@2.20.0 install
      echo "Installing vendor files …
      " && cd vendor && npm install --loglevel=error
      changed 1 package, and audited 10 packages in 8s
      found 0 vulnerabilities
      magicmirror@2.20.0 postinstall
      npm run install-fonts && echo "MagicMirror² installation finished successfully!
      magicmirror@2.20.0 install-fonts
      echo "Installing fonts …
      " && cd fonts && npm install --loglevel=error
      Installing fonts …
      changed 2 packages, and audited 3 packages in 6s
      magicmirror@2.20.0 prepare
      [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
      husky - Git hooks installed
      added 467 packages, removed 2 packages, changed 96 packages, and audited 731 packages in 9m
      82 packages are looking for funding
      run npm fund for details
      3 moderate severity vulnerabilities
      To address all issues (including breaking changes), run:
      npm audit fix --force
      Run npm audit for details.
      npm notice
      npm notice New major version of npm available! 7.11.2 -> 8.13.2
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.13.2
      npm notice Run npm install -g npm@8.13.2 to update!
      npm notice
      pi@magicmirror:~/MagicMirror $ pm2 start mm
      [PM2][ERROR] Script not found: /home/pi/MagicMirror/mm
      pi@magicmirror:~/MagicMirror $ pm2 restart mm
      Use --update-env to update environment variables
      [PM2][ERROR] Process or Namespace mm not found
      pi@magicmirror:~/MagicMirror $ pm2 start mm.sh
      [PM2][ERROR] Script not found: /home/pi/MagicMirror/mm.sh
        sdetweil @Richard238
        @Richard238 pm2 status will show u the defined apps to monitor
        if you used my script to install the name is MagicMirror.
        u can also use the row number
        pm2 start 0
        or if more than one app is define, pm2 start all
        your status from above says
        0 | MagicMirror | fork | 1 | stopped |  0%
