    Cron Job Question
    22 Posts 4 Posters 8.0k Views 4 Watching
    • plainbrokeP Offline
      plainbroke @sdetweil
      @sdetweil said in Cron Job Question:
      @plainbroke autoreconfig?
      u don’t have to build motion, they have binaries (on every platform I’ve tried so far)
      my script (launched by something outside mm)
      creates an empty file in a known folder for each motion event
      detected
      ended
      my module node_helper watches for those files to be created, and then sends notification to my module side to signal sleep or wake depending on the config.
      the default folder is ‘motion’ inside the MMM-SleepWake folder
      the script locates the running mm instance, and uses it’s path to locate the module folder and this it’s motion folder
      the script assumes the path includes the username mm is running under and that username is used to set file permissions, so the module can remove them after processing the detection
      So if I send a empty file ended to the motion folder in MMM-SleepWake that triggers the timer in config.js to blank screen?
      and then in the morning send empty file detected to the same motion folder in MMM-SleepWake it should turn the modules back on.
      Have I got this correct in my head or am I still wondering at sea?
        sdetweil @plainbroke
        @plainbroke yes, but just call my script with
        ended
        (motion stopped)
        started
        (motion started)
        same as my doc says for the motion config
