    Calendar module just stopped working
    2 Posts 1 Posters 548 Views 1 Watching
      david_jonesy
      I did an upgrade on MM to the latest version 2.22.0
      After reboot, calendar no longer was displaying.
      I have since made sure npm,node and electron are updated. I moved my MM directory and did a fresh install, restored the config.js file and still no go. Everything else on the system displays. I have tried different calendar links even, both public and private. I see in the log it gets the data:
      [19.07.2022 09:37.58.217] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/NONE%40gmail.com/private-5a102537c39f35/basic.ics - Interval: 600000
      [19.07.2022 09:37.58.662] [INFO]  Checking git for module: MMM-MonthlyCalendar
      [19.07.2022 09:37.58.699] [INFO]  Checking git for module: MMM-OpenWeatherForecast
      [19.07.2022 09:37.58.739] [INFO]  Checking git for module: default
      [19.07.2022 09:38.00.886] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
      [19.07.2022 09:38.10.776] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
      Here is my config section, I did obfuscate the links:
            module: 'MMM-MonthlyCalendar',
            position: 'bottom_bar',
              mode: 'fourWeeks'
            module: 'calendar',
            header: 'Agenda',
            position: 'top_left',
              fade: false,
              colored: true,
              wrapevents: true,
                      maximumEntries: 10,
                      broadcastPastEvents: true,
              maxTitleLength: 35,
                      sliceMultiDayEvents: true,
                      fetchInterval: 600000,
                  symbol: 'chevron-circle-right',
                  color: '#4285f4',
                  url: 'https://calendar.google.com/calendar/ical/NONE%40gmail.com/private-655602d48f444d95a102537c39f35/basic.ics'
                  symbol: 'football-ball',
                              color: '#009688',
                  url: 'https://calendar.google.com/calendar/ical/NONE%40gmail.com/private-9555cf33931a454fa/basic.ics'
      After about 3 hours, I decided I would try reaching out to you experts. Cheers
        david_jonesy @david_jonesy
        I solved this by going 1 line at a time. This // fixed my issue.
        //		broadcastPastEvents: true,
