    MM boot splash rotation
    6 Posts 2 Posters 1.7k Views 2 Watching
      andyyy
      I am setting up a new MM from scratch because my current image got pretty buggy over the last years.
      I just installed the MM using the automated installation from @sdetweil. With that you can replace the default splash screen with the MM splash picture. It works.
      But I would like to have MM splash picture rotated. I tried to modify the magicmirror.script file but it didn’t work out so far. Can anyone explain how to do it?
      Thanks!
        sdetweil @andyyy
        @andyyy ok, I had to edit the image and rotate it to match
        /usr/share/plymouth/themes/MagicMirror/splash.png
        need to use sudo with the editor to save it
          sdetweil @andyyy
          @andyyy can u explain? it should rotate when the screen rotates… (assuming u use the system rotation and not the css rotation)
            andyyy @sdetweil
            In the config.txt I did set display_rotate=3 and/or display_hdmi_rotate=3. It shows no effect.
            On the desktop I can rotate screen without any issue but the splash stays in the default orientation.
              sdetweil @andyyy
                andyyy @sdetweil
                That was my first idea as well. But I was locking for a smarter solution. :)
                I discovered a strange conflict in raspian 64x. Before I did always use the 32x variant.
                I did some research and testing why the display_hdmi_rotate command in the config.txt apparently didn’t work. It seems there is a conflict with DRM VC4 V3D driver (which is enabled by default). Just un-commenting the line #dtoverlay=vc4-kms-v3d the screen rotates (even the splash picture) as expected. The driver obviously overwrites the display_hdmi_rotate command.
                Now the MM and splash have the right orientation. Only the default weather app says loading, but it will be replaced by another module anyhow.
                Thanks, andyyy
                  sdetweil @andyyy
                  @andyyy all the modules need ali keys now.
                  we are steering clear of 64 bit for a while
