    MM not loading after software update
    24 Posts 2 Posters 11.9k Views 2 Watching
    • R
      Redicaljk
      Not sure if the recent software update has anything to do with MM not loading.
      This is/are the error(s);
      19.08.2022 22:52.46.248] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/node_modules/jsdom/lib/jsdom/browser/parser/html.js:170
      after._pushedOnStackOfOpenElements?.();
      SyntaxError: Unexpected token .
      at Module._compile (internal/modules/cjs/loader.js:722:23)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
      at Module.load (internal/modules/cjs/loader.js:645:32)
      at Function.Module._load (internal/modules/cjs/loader.js:560:12)
      at Module.require (internal/modules/cjs/loader.js:685:19)
      at require (internal/modules/cjs/helpers.js:16:16)
      at Object. (/home/pi/MagicMirror/node_modules/jsdom/lib/jsdom/browser/parser/index.js:4:20)
      at Module._compile (internal/modules/cjs/loader.js:786:30)
      [19.08.2022 22:52.46.249] [LOG] Loading module helpers …
      [19.08.2022 22:52.46.250] [LOG] No helper found for module: alert.
      [19.08.2022 22:52.46.250] [LOG] Initializing new module helper …
      [19.08.2022 22:52.46.251] [LOG] Module helper loaded: MMM-AlexaControl
      [19.08.2022 22:52.46.251] [LOG] Initializing new module helper …
      [19.08.2022 22:52.46.252] [LOG] Module helper loaded: updatenotification
      [19.08.2022 22:52.46.253] [LOG] No helper found for module: clock.
      [19.08.2022 22:52.46.253] [LOG] Initializing new module helper …
      [19.08.2022 22:52.46.254] [LOG] Module helper loaded: calendar
      [19.08.2022 22:52.46.254] [LOG] No helper found for module: calendar_monthly.
      [19.08.2022 22:52.46.255] [LOG] No helper found for module: weather.
      [19.08.2022 22:52.46.270] [ERROR] App threw an error during load
      [19.08.2022 22:52.46.270] [ERROR] /home/pi/MagicMirror/node_modules/jsdom/lib/jsdom/browser/parser/html.js:170
      Any help would be greatly appreciated.
        sdetweil @Redicaljk
        @Redicaljk k… not sure on calendar…
        on onthisday do
        cd ~/MagicMirror/modules/MMM-OnThisDay
        rm -rf node_modules
        rm package-lock.json
        npm install --omit=dev
        then try again , works here
        R 1 Reply Last reply
          sdetweil @Redicaljk
          @Redicaljk how did you update?
          • R
            Redicaljk @sdetweil
            @sdetweil I clicked on Install Updates from the notification in the Task Bar.
              sdetweil @Redicaljk
              @Redicaljk MagicMirror does not update that way, only system stuff.
              but maybe node/npm changed
              .can u show results of
              node -v
              npm -v
              • R
                Redicaljk @sdetweil
                @sdetweil sorry, I am a complete newbie. I tried entering node-v and npm-v in the terminal and I get “command not found”.
                  sdetweil @Redicaljk
                  @Redicaljk there is a space between node and -v
                  • R
                    Redicaljk @sdetweil
                    @sdetweil thank you!
                    pi@rpi4:~ $ node -v
                    v16.17.0
                    pi@rpi4:~ $ npm -v
                    8.15.0
                    pi@rpi4:~ $
                      sdetweil @Redicaljk
                      @Redicaljk ok, lets redo the npm install for MagicMirror
                      cd ~/MagicMirror
                      rm -rf node_modules
                      • R
                        Redicaljk @sdetweil
                        @sdetweil done. Still having an issue:
                        magicmirror@2.20.0 start
                        DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                        [20.08.2022 09:12.14.860] [LOG] Starting MagicMirror: v2.20.0
                        [20.08.2022 09:12.14.865] [LOG] Loading config …
                        [20.08.2022 09:12.14.871] [LOG] Loading module helpers …
                        [20.08.2022 09:12.14.873] [LOG] No helper found for module: alert.
                        [20.08.2022 09:12.15.181] [LOG] Initializing new module helper …
                        [20.08.2022 09:12.15.182] [LOG] Module helper loaded: MMM-AlexaControl
                        [20.08.2022 09:12.15.185] [LOG] Initializing new module helper …
                        [20.08.2022 09:12.15.186] [LOG] Module helper loaded: updatenotification
                        [20.08.2022 09:12.15.186] [LOG] No helper found for module: clock.
                        [20.08.2022 09:12.15.403] [LOG] Initializing new module helper …
                        [20.08.2022 09:12.15.404] [LOG] Module helper loaded: calendar
                        [20.08.2022 09:12.15.404] [LOG] No helper found for module: calendar_monthly.
                        [20.08.2022 09:12.15.405] [LOG] No helper found for module: weather.
                        [20.08.2022 09:12.15.408] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘jsdom’
                        Require stack:
                        • /home/pi/MagicMirror/modules/MMM-OnThisDay/node_helper.js
                        • /home/pi/MagicMirror/js/app.js
                        • /home/pi/MagicMirror/js/electron.js
                        • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                          sdetweil @Redicaljk
                          @Redicaljk see this topic, for missing libraries
                          https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later, 1st post gives instructions
                          • R
                            Redicaljk @sdetweil
                            @sdetweil thank you! I’ll give it a try.
                            • R
                              Redicaljk @Redicaljk
                              @Redicaljk Looks like the original issue has been resolved, however, MM still crashes. I can’t copy the error without this post being marked as spam!!!
                              S 2 Replies Last reply
                                sdetweil @Redicaljk
                                @Redicaljk send to me in email…
                                same userid at gmail
                                  sdetweil @Redicaljk
                                  @Redicaljk did some other module need a library?
                                  • R
                                    Redicaljk @sdetweil
                                    @sdetweil just emailed you.
                                      sdetweil @Redicaljk
                                      @Redicaljk looking at it
                                        @Redicaljk workaround, do
                                        cd ~/MagicMirror
                                        nano package.json
                                        scroll down to the line that looks like this
                                        		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                                        change to look like this
                                        		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --no-sandbox js/electron.js",
                                        ctrl-o
                                        to save the changed file
                                        ctrl-x to exit nano
                                        then npm start to test
                                          sdetweil @Redicaljk
                                          @Redicaljk see my post above
                                          • R
                                            Redicaljk @sdetweil
                                            @sdetweil Success! Thank you. MM now loads and does not crash but Weather module is not loading and there’s an error in the calendar module.
                                              sdetweil @Redicaljk
                                              @Redicaljk show the errors, email if required
