    MM not loading after software update
    24 Posts 2 Posters 11.5k Views 2 Watching
      sdetweil @Redicaljk
      @Redicaljk ok, lets redo the npm install for MagicMirror
      rm -rf node_modules
      rm package-lock.json
      npm install --omit=dev
      R 1 Reply Last reply
        Redicaljk @sdetweil
        @sdetweil done. Still having an issue:
        magicmirror@2.20.0 start
        [20.08.2022 09:12.14.860] [LOG] Starting MagicMirror: v2.20.0
        [20.08.2022 09:12.14.865] [LOG] Loading config …
        [20.08.2022 09:12.14.871] [LOG] Loading module helpers …
        [20.08.2022 09:12.14.873] [LOG] No helper found for module: alert.
        [20.08.2022 09:12.15.181] [LOG] Initializing new module helper …
        [20.08.2022 09:12.15.182] [LOG] Module helper loaded: MMM-AlexaControl
        [20.08.2022 09:12.15.185] [LOG] Initializing new module helper …
        [20.08.2022 09:12.15.186] [LOG] Module helper loaded: updatenotification
        [20.08.2022 09:12.15.186] [LOG] No helper found for module: clock.
        [20.08.2022 09:12.15.403] [LOG] Initializing new module helper …
        [20.08.2022 09:12.15.404] [LOG] Module helper loaded: calendar
        [20.08.2022 09:12.15.404] [LOG] No helper found for module: calendar_monthly.
        [20.08.2022 09:12.15.405] [LOG] No helper found for module: weather.
        [20.08.2022 09:12.15.408] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘jsdom’
        Require stack:
        • /home/pi/MagicMirror/modules/MMM-OnThisDay/node_helper.js
          sdetweil @Redicaljk
          @Redicaljk see this topic, for missing libraries
          https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later, 1st post gives instructions
            Redicaljk @sdetweil
            @sdetweil thank you! I’ll give it a try.
              Redicaljk @Redicaljk
              @Redicaljk Looks like the original issue has been resolved, however, MM still crashes. I can’t copy the error without this post being marked as spam!!!
              S 2 Replies Last reply
                sdetweil @Redicaljk
                @Redicaljk send to me in email…
                same userid at gmail
                  sdetweil @Redicaljk
                  @Redicaljk did some other module need a library?
                    Redicaljk @sdetweil
                    @sdetweil just emailed you.
                      sdetweil @Redicaljk
                      @Redicaljk looking at it
                        @Redicaljk workaround, do
                        nano package.json
                        scroll down to the line that looks like this
                        change to look like this
                        		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --no-sandbox js/electron.js",
                        ctrl-o
                        to save the changed file
                        ctrl-x to exit nano
                        then npm start to test
                          sdetweil @Redicaljk
                          @Redicaljk see my post above
                            Redicaljk @sdetweil
                            @sdetweil Success! Thank you. MM now loads and does not crash but Weather module is not loading and there’s an error in the calendar module.
                              sdetweil @Redicaljk
                              @Redicaljk show the errors, email if required
                                Redicaljk @sdetweil
                                  sdetweil @Redicaljk
                                  @Redicaljk k… not sure on calendar…
                                  on onthisday do
                                  cd ~/MagicMirror/modules/MMM-OnThisDay
                                  rm -rf node_modules
                                  then try again , works here
                                    Redicaljk @sdetweil
                                    @sdetweil I really don’t know how to thank you. MM is back up and working as before including the calendar, weather and on this day.
                                    Do you know what caused this issue? Was it the software update?
                                      sdetweil @Redicaljk
                                      @Redicaljk looks like the sw update updated node and messed everything up…
                                      to update MagicMirror (next release Oct 1) , see my scripts
                                      they do all this remove/npm install for the base and every module and fix the missing libs too… I will add jsdom to the list
