    MM not loading after software update
    24 Posts 2 Posters 8.5k Views 2 Watching
      sdetweil @Redicaljk
      @Redicaljk see this topic, for missing libraries
      https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later, 1st post gives instructions
        Redicaljk @sdetweil
        @sdetweil thank you! I’ll give it a try.
          Redicaljk @Redicaljk
          @Redicaljk Looks like the original issue has been resolved, however, MM still crashes. I can’t copy the error without this post being marked as spam!!!
            sdetweil @Redicaljk
            @Redicaljk send to me in email…
            same userid at gmail
              sdetweil @Redicaljk
              @Redicaljk did some other module need a library?
                Redicaljk @sdetweil
                @sdetweil just emailed you.
                  sdetweil @Redicaljk
                  @Redicaljk looking at it
                    @Redicaljk workaround, do
                    nano package.json
                    scroll down to the line that looks like this
                    change to look like this
                    		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --no-sandbox js/electron.js",
                    ctrl-o
                    to save the changed file
                    ctrl-x to exit nano
                    then npm start to test
                      sdetweil @Redicaljk
                      @Redicaljk see my post above
                        Redicaljk @sdetweil
                        @sdetweil Success! Thank you. MM now loads and does not crash but Weather module is not loading and there’s an error in the calendar module.
                          sdetweil @Redicaljk
                          @Redicaljk show the errors, email if required
                            Redicaljk @sdetweil
                              sdetweil @Redicaljk
                              @Redicaljk k… not sure on calendar…
                              on onthisday do
                              cd ~/MagicMirror/modules/MMM-OnThisDay
                              rm -rf node_modules
                              rm package-lock.json
                              npm install --omit=dev
                              then try again , works here
                                Redicaljk @sdetweil
                                @sdetweil I really don’t know how to thank you. MM is back up and working as before including the calendar, weather and on this day.
                                Do you know what caused this issue? Was it the software update?
                                  sdetweil @Redicaljk
                                  @Redicaljk looks like the sw update updated node and messed everything up…
                                  to update MagicMirror (next release Oct 1) , see my scripts
                                  they do all this remove/npm install for the base and every module and fix the missing libs too… I will add jsdom to the list
