    Black Screen "Electron" after updating MM
    17 Posts 2 Posters 5.3k Views 2 Watching
      RIKKO14
      Hello,
      by doing an einth update my Magic Mirror is again in black screen “Electron”, how to do an Electron rebuild ?
        sdetweil @RIKKO14
        @RIKKO14 how did u update?
        is this a pir module needing rebuild?
          RIKKO14 @sdetweil
          @sdetweil Quite often I have a logo at the top of my Magic Mirror
          and I had for several days on te top of my MM the MMM-Jast to update and MMM-NowPlayingOnSpotify and MMM-DHT-Sensor had not worked. So first I updapte my MM and second uninstall MMM-Jast, MMM-NowPlayingOnSpotify and MMM-DHT-Sensor
          cd ~/MagicMirror
          rm -rf modules/module_to_delete
          and reinstall them
          This is where Electron appeared…
            sdetweil @RIKKO14
            @RIKKO14 ok,seen this before… MOST times this works
            stop MagicMirror
            cd ~
            rm -rf .config/Electron
            note the dot in front of config
            restart MagicMirror
              RIKKO14 @sdetweil
              I use PM2,
              how to do ?
                sdetweil @RIKKO14
                @RIKKO14 pm2 --help will give you the pm2 commands
                but
                pm2 stop all
                  RIKKO14
                  I do this :
                  but nothing…
                    sdetweil @RIKKO14
                    @RIKKO14 correct… in linux most commands return nothing if successful…
                    so that is good… you asked to erase a folder
                    and it did that
                    now restart MagicMirror
                    pm2 start MagicMirror
                      RIKKO14 @sdetweil
                        sdetweil @RIKKO14
                        @RIKKO14 fun… try this
                        we need to edit a js file
                        cd ~/MagicMirror/js
                        nano electron.js
                        scroll down to
                        	let address = (config.address === void 0) | (config.address === "") ? (config.address = "localhost") : config.address;
                        add a bank line after
                        on the blank line, copy/paste these lines
                        	mainWindow.webContents.on("new-window", function(event, url) {
                              event.preventDefault();
                              // This will open a new Electron window to load the url.
                              shell.openExternal(url);
                        so it looks like this when you are done
                        	mainWindow.loadURL(`${prefix}${address}:${config.port}`);
                        ctrl-o to save the file
                        ctrl-x to exit nano
                        cd …
                        then
                        pm2 restart MagicMirror
                          RIKKO14
                          @sdetweil after doing this :
                          cd ~.MagicMirror/js
                          nano electron.js
                          I have this :
                          So I can’t scroll anywhere…
                            sdetweil @RIKKO14
                            @RIKKO14 sorry typo, try again
                              RIKKO14
                              I tryed 2 times with space and with not space before
                              mainWindow.webContents.on (...)
                              https://zupimages.net/viewer.php?id=22/34/77nw.jpg
                              but style the same…
                                sdetweil @RIKKO14
                                @RIKKO14 can’t see the image. u can just upload here, 3 icon from right in editor
                                tabs don’t matter
                                  sdetweil @RIKKO14
                                  @RIKKO14 do u have a real display on pi?
                                  or using vnc all the time?
                                    RIKKO14
                                    I use VNC to tape the commands but I have the same screen on my Pi MagicMirror
                                      sdetweil @RIKKO14
                                      @RIKKO14 can u open the advert tab and see what it is? there shouldn’t be any advert showing from MM content
