    Black Screen "Electron" after updating MM
    17 Posts 2 Posters 4.5k Views 2 Watching
      sdetweil @RIKKO14
      @RIKKO14 ok,seen this before… MOST times this works
      stop MagicMirror
      cd ~
      rm -rf .config/Electron
      note the dot in front of config
      restart MagicMirror
        RIKKO14 @sdetweil
        I use PM2,
        how to do ?
          sdetweil @RIKKO14
          @RIKKO14 pm2 --help will give you the pm2 commands
          but
          pm2 stop all
            RIKKO14
            I do this :
            but nothing…
              sdetweil @RIKKO14
              @RIKKO14 correct… in linux most commands return nothing if successful…
              so that is good… you asked to erase a folder
              and it did that
              now restart MagicMirror
              pm2 start MagicMirror
                RIKKO14 @sdetweil
                  sdetweil @RIKKO14
                  @RIKKO14 fun… try this
                  we need to edit a js file
                  cd ~/MagicMirror/js
                  nano electron.js
                  scroll down to
                  	let address = (config.address === void 0) | (config.address === "") ? (config.address = "localhost") : config.address;
                  add a bank line after
                  on the blank line, copy/paste these lines
                  	mainWindow.webContents.on("new-window", function(event, url) {
                        event.preventDefault();
                        // This will open a new Electron window to load the url.
                        shell.openExternal(url);
                  so it looks like this when you are done
                  	mainWindow.loadURL(`${prefix}${address}:${config.port}`);
                  ctrl-o to save the file
                  ctrl-x to exit nano
                  cd …
                  then
                  pm2 restart MagicMirror
                    RIKKO14
                    @sdetweil after doing this :
                    cd ~.MagicMirror/js
                    nano electron.js
                    I have this :
                    So I can’t scroll anywhere…
                      sdetweil @RIKKO14
                      @RIKKO14 sorry typo, try again
                        RIKKO14
                        I tryed 2 times with space and with not space before
                        mainWindow.webContents.on (...)
                        https://zupimages.net/viewer.php?id=22/34/77nw.jpg
                        but style the same…
