    turning Postman query into getJSONP()? (BTC node query)
    6 Posts 2 Posters 1.8k Views 2 Watching
    • FlatPepsiF Offline
      FlatPepsi
      I may be doing this all wrong, so feel free to point out where I’m off.
      I want to send an RCP call to my own BTC node, and I can do it in Postman. I’ve tried using a “getjsonp()” call, but I’m not even sure if that’s the right method.
      If there’s a good example module out there that already calls the BTC Code API, I’d love to play with it.
      Any advice?
        sdetweil @FlatPepsi
        @FlatPepsi so. this gets fun
        you can do this in two places in a MagicMirror module
        in the browser (modulename.js)
        see
        https://dmitripavlutin.com/fetch-with-json/
        or in the node_helper, using some library
        like this
        https://www.npmjs.com/package/get-json
        I don’t know what BTC is…
        if it’s Bitcoin, there is a library u could use from the node_helper,
        see
        https://www.npmjs.com/package/bitcoin
          sdetweil @FlatPepsi
          @FlatPepsi also you could do Google search for
          “github magicmirror bitcoin”
          I get 5 different modules
          FlatPepsiF 1 Reply Last reply Reply Quote 0
            FlatPepsi @sdetweil
            @sdetweil Every search I’ve done only pulls up modules to display bitcoin price from 3rd parties. I’m looking for a way to pull data from my own bitcoin node & blockchain data - which I’ve yet to see anyone do with a module.
            If you run across one, I’d love to see it.
              sdetweil @FlatPepsi
              @FlatPepsi but if u have an API to your server, then build a module around it
                sdetweil @FlatPepsi
                @FlatPepsi also, something like this might help
                https://github.com/amcolash/MMM-json-feed
                put in your url, display data
