    Install package.json
    5 Posts 2 Posters 1.5k Views 2 Watching
    • N6NGN
      N6NG
      Re: fix for black screen in 2.16 and later
      I did the npm install package.json and it installed it ok and is listed in the directory MMM-CalendarWeek
      then I did git checkout package.json and got the message error: pathspec ‘package.json’ did not match any files(s) known to git.
      So I did npm install package.json and it said it was up to date. so I did the checkout again and got the same message.
      Any words of wisdon o-guru- of the Magic Mirror (eg Sam)
      Dennis
        sdetweil @N6NG
        @N6NG not npm install package.json
        let’s go thru the instructions again
        you got a full blank screen after installing and configuring a module
        yes
        you got the cannot find module ‘???’ message
        yes
        does the module HAVE a package.json file? NO
        no, create one by typing
         npm init -y
        in the module folder
        yes , continue on
        get the name of the missing module from the message in step 1
        in the module folder do
        npm install ?????
        where ??? is the name of the missing g module, you got in the prior step
        N6NGN 1 Reply Last reply
        • N6NGN
          N6NG @sdetweil
          @sdetweil said in Install package.json:
          yes
          yes
          npm init -y
          yes , continue on
          Correct up to here… I did do install package.json
          I looked and there was a package.json in the MMM-CalendarWeek module
          At this point I did the git checkout package.json ****************
          ****** That’s where I get the message error: pathspec ‘package.json’ did not match any files known to git
          This is as far as I could get**
          npm install ???
          S 2 Replies Last reply
            sdetweil @N6NG
            @N6NG said in Install package.json:
            ****** That’s where I get the message error: pathspec ‘package.json’ did not match any files known to git**
            but why did you do that? that is not what the instructions said to do…
            npm init -y
              sdetweil @N6NG
              @N6NG further the instructions said
              NEVER EVER do this (npm init ) in the MagicMirror folder
              if you do/did, then do
              to restore the package.json file
              I guess I need to add more words
              if you DID do npm init -y IN THE MagicMirror folder
              then you need to fix this. do
              cd ~/MagicMirror
              git checkout pakckage.json
              then go back to the module folder
              cd -
              an resume the fix instructions
              then go
