    Issues with pm2 in old mirror
    4 Posts 2 Posters 1.3k Views 2 Watching
      rmeskill
      Hello all! I’ve an old mirror setup that’s been running stably for about 3 years now, but it stopped working a little while ago. Since I last installed it via the auto-install script and isn’t an option anymore, I thought to start from scratch. I upgraded npm and node to the most current versions, but pm2 is erroring out when trying to launch:
      pi@raspberrypi:~ $ pm2 status
      (node:10537) Warning: Accessing non-existent property 'cat' of module exports inside circular dependency
      (Use `node --trace-warnings ...` to show where the warning was created)
      (node:10537) Warning: Accessing non-existent property 'cd' of module exports inside circular dependency
      (node:10537) Warning: Accessing non-existent property 'chmod' of module exports inside circular dependency
      (node:10537) Warning: Accessing non-existent property 'cp' of module exports inside circular dependency
      It looks to me like the node install is broken somehow, but I’ve no idea what might be broken:
      pi@raspberrypi:~ $ node -v
      v16.17.0
      pi@raspberrypi:~ $ npm -v
      8.19.2
      Any thoughts?
        sdetweil @rmeskill
        @rmeskill u probably need to upgrade pm2 as well
        pm2 --help for the syntax, but I think it’s pm2 upgrade
          rmeskill
          @sdetweil said in Issues with pm2 in old mirror:
          pm2 upgrade
          That succeeded but didn’t fix the problem:
          [PM2] Saving current process list...
          [PM2] Stopping PM2...
          [PM2][WARN] No process found
          [PM2] All processes have been stopped and deleted
          [PM2] PM2 stopped
          [PM2] Spawning PM2 daemon with pm2_home=/root/.pm2
          [PM2] Restoring processes located in /root/.pm2/dump.pm2
          >>>>>>>>>> PM2 updated
          │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ user │ watching │
           Use `pm2 show <id|name>` to get more details about an app
          pi@raspberrypi:~/MagicMirror $ pm2 status
          (node:5424) Warning: Accessing non-existent property 'cat' of module exports inside circular dependency
          (node:5424) Warning: Accessing non-existent property 'cd' of module exports inside circular dependency
          (node:5424) Warning: Accessing non-existent property 'chmod' of module exports inside circular dependency
          (node:5424) Warning: Accessing non-existent property 'cp' of module exports inside circular dependency
          (node:5424) Warning: Accessing non-existent property 'dirs' of module exports inside circular dependency
            sdetweil @rmeskill
            @rmeskill hm… so, next guess is u uninstall pm2 and reinstall
            I think the command is
            pm2 u startup
            which will return the command to execute
            then to install again u can use my fixuppm2 script
            see
