    calendar with recurring event
    11 Posts 2 Posters 4.9k Views 3 Watching
      jasondreher
      I see many posts where recurring events are not showing. But I cant find a solution. Has this been fixed somehow?
      I am running the default calendar module and my recurring events are not showing.
      At one point I used MMM-MyCalendar and that showed all events, but that no longer works with the current MM version.
      Any suggestions on another calendar module to use… something similar to the default one?
        sdetweil @jasondreher
        @jasondreher
        could u post on of the events from the ics file that demonstrates this?
        use the url in the cal in the browser,not will download the ics file. open it as a text file not just double click.
        BEGIN:VEVENT
        END: VEVENT
        change any personal info, don’t change anything else
          jasondreher @sdetweil
          I only changed the UID, looks like it started 9/12/22, repeats weekly till 10/12/22. (although some of that is a day off, but that is what some of the other forum items said)
          BEGIN:VEVENT
          DTSTART;TZID=America/Chicago:20220912T190000
          DTEND;TZID=America/Chicago:20220912T200000
          RRULE:FREQ=WEEKLY;WKST=SU;UNTIL=20221012T045959Z;BYDAY=MO
          DTSTAMP:20220927T001542Z
          UID:XXXXXXXXXXXXXXXXXXXX
          CREATED:20220901T144823Z
          DESCRIPTION:
          LAST-MODIFIED:20220913T001004Z
          SEQUENCE:1
          STATUS:CONFIRMED
          SUMMARY:TS Boot Camp
          TRANSP:OPAQUE
          END:VEVENT
            @jasondreher ok thx will review shortly.
            the day off bug has a fix in the next release ( Saturday), cal entries w BYDAY return junk
              @jasondreher ok, i don’t see a problem with 2.20 or upcoming 2.21 (with the byday fix) …
              do you have broadcastPastEvents:true? in the cal config?
              there is a bug there, that I introduced… it chops off maxEvents incorrectly (also fixed in 2.21, Sauturday)
              workaround is to increase maxEntries from 10 to 100 (or more) depending on how big the past years events are…
                I do not have broadcastPastEvents: true, in my config.
                I will update this weekend, add broadcastPastEvents: true, and see if that fixes anything, thanks.
                  @jasondreher don’t NEED broadcastPastEvents, it was just a bug I introduced… which fixed a regression of another problem…
                  want to run debug test…
                  edit config.js and add ,“DEBUG”
                  to the logLevel:
                  attribute at the top of config.js
                  then if using pm2, pm2 stop all
                  then
                  cd ~/MagicMirror
                  npm start >somefie.txt 2>&1
                  run til cal appears
                  ctrl-q to end
                  send the somefile.txt to my email (I don’t share info )
                  my same userid at gmail
                  turn off debug
                    Wow, I cant find your email, I am sure its fairly obvious. Anyway I narrowed down the event that is not showing…
                    It looks all right, showing “Corrected startDate: Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)”
                    [27.09.2022 09:25.50.700] [DEBUG] start: Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.700] [DEBUG] end:: Mon Sep 12 2022 20:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.701] [DEBUG] duration: 3600000
                    [27.09.2022 09:25.50.701] [DEBUG] title: TS Boot Camp
                    [27.09.2022 09:25.50.701] [DEBUG] Search for recurring events between: Tue Sep 27 2022 09:25:50 GMT-0500 (Central Daylight Time) and Tue Sep 26 2023 23:59:59 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.705] [DEBUG] Title: TS Boot Camp, with dates: [“2022-10-03T00:00:00.000Z”,“2022-10-10T00:00:00.000Z”]
                    [27.09.2022 09:25.50.705] [DEBUG] event.recurrences: undefined
                    [27.09.2022 09:25.50.706] [DEBUG] recurring date is Sun Oct 02 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 300
                    [27.09.2022 09:25.50.706] [DEBUG] recurring date is Sun Oct 02 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 5 Hour is 19
                    [27.09.2022 09:25.50.706] [DEBUG] new recurring date2 is Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.706] [DEBUG] Corrected startDate: Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.707] [DEBUG] initial tz=America/Chicago
                    [27.09.2022 09:25.50.707] [DEBUG] corrected tz=America/Chicago
                    [27.09.2022 09:25.50.707] [DEBUG] start date/time=Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.707] [DEBUG] start offset=-300
                    [27.09.2022 09:25.50.707] [DEBUG] start date/time w tz =Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.708] [DEBUG] event date=Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.708] [DEBUG] event offset=-300 hour=19 event date=Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.708] [DEBUG] adjustHours=0
                    [27.09.2022 09:25.50.708] [DEBUG] duration: 3600000
                    [27.09.2022 09:25.50.708] [DEBUG] saving event: false
                    [27.09.2022 09:25.50.709] [DEBUG] recurring date is Sun Oct 09 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 300
                    [27.09.2022 09:25.50.709] [DEBUG] recurring date is Sun Oct 09 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 5 Hour is 19
                    [27.09.2022 09:25.50.709] [DEBUG] new recurring date2 is Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.709] [DEBUG] Corrected startDate: Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.709] [DEBUG] initial tz=America/Chicago
                    [27.09.2022 09:25.50.710] [DEBUG] corrected tz=America/Chicago
                    [27.09.2022 09:25.50.710] [DEBUG] start date/time=Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.710] [DEBUG] start offset=-300
                    [27.09.2022 09:25.50.710] [DEBUG] start date/time w tz =Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.711] [DEBUG] event date=Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.711] [DEBUG] event offset=-300 hour=19 event date=Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
                    [27.09.2022 09:25.50.711] [DEBUG] adjustHours=0
                    [27.09.2022 09:25.50.711] [DEBUG] duration: 3600000
                    [27.09.2022 09:25.50.711] [DEBUG] saving event: false
                    [27.09.2022 09:25.50.712] [DEBUG] Processing entry…
                    [27.09.2022 09:25.50.712] [DEBUG] Event:
                      @jasondreher
                      my id here
                      sdetweil
                      at gmail
                        @jasondreher and what shows on the calendar?
                        the 3rd should show, maybe 10th it is 2 weeks away.
                          I plan on updating this weekend and seeing what shows when this event comes up next, your help is greatly appreciated!!!
