    Issue with default Weather module
    2 Posts 2 Posters 507 Views 2 Watching
    • K
      kevmang
      Hi There
      I’m getting an error wiith the default weather module after updating to the latest version of MM. I tested my API key manually and it works.
      This is the error message, any suggestions?
      [15.10.2022 22:06.59.726] [LOG]   Sockets connected & modules started ...
      [15.10.2022 22:06.59.805] [LOG]   Launching application.
      [15.10.2022 22:07.00.313] [ERROR] ERROR! Could not validate main module js file.
      [15.10.2022 22:07.00.315] [ERROR] /home/pi/MagicMirror/modules/default/weather/weather.js:159
                              currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,
      SyntaxError: Unexpected token .
          at Module._compile (internal/modules/cjs/loader.js:722:23)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
      This is what my config looks like (API key removed):
      			"module": "weather",
      			"disabled": true,
      			"header": "Weather In Doncaster, AU",
      			"position": "top_right",
      			"config": {
      				"apiKey": "XXXXXXXXX",
      				"weatherEndpoint": "/weather",
      				"locationID": "2168607",
      				"location": "Melbourne,Australia",
      				"weatherProvider": "openweathermap",
      				"type": "current",
      				"degreeLabel": true,
      				"onlyTemp": false,
      				"showHumidity": true
      			"disabled": true,
      			"header": "Forecast In",
      			"config": {
      				"apiKey": "XXXXX",
      				"weatherEndpoint": "/forecast",
      				"type": "forecast",
      				"onlyTemp": false,
      				"showHumidity": false,
      				roundTemp: true,
      				showPrecipitationAmount: true,
      				colored: false,
      				tableClass: "small",
      				maxNumberOfDays: 5
        sdetweil @kevmang
        @kevmang you also need to upgrade your node js version
        my upgrade script will install version 16
