    MagicMirror install on proxmox LXC Container?
    37 Posts 3 Posters 12.8k Views 3 Watching
      sdetweil @kusselin
      @kusselin but if you are running in a container
      the the mm.sh script should be running as server
      as there is no ui on a container
      npm run server
      not
      npm start
      • kusselinK Offline
        kusselin @sdetweil
        @sdetweil said in MagicMirror install on proxmox LXC Container?:
        @kusselin pm2 logs --lines=50
        not good to install under root
        Hello, thank you for the tips…o.k. under root this is nuicht so good…
        Again from the beginning…I install ubuntu 22.04 standard in a LXC container. I have also created the container by default. This has also all worked great. After that I started the container.
        So when I am on the console it is so that I log in with root and pass. But that is not so good.
        So I have now created a standard user with pass. Habs then times made as on Rasoian with user “pi” udn the default password for it. To test!
        So, now I log in with user “pi” and the default password…now I stand on the “prompt”
        login as: pi
        pi@192.168.200.74's password:
        Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.35-1-pve x86_64)
         * Documentation:  https://help.ubuntu.com
         * Management:     https://landscape.canonical.com
         * Support:        https://ubuntu.com/advantage
        Last login: Sat Oct 15 19:06:04 2022 from 192.168.1.236
        pi@MagicMirror-live:~$ ^C
        Then I take the script from you here:
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        So and if I then start your script via Console then comes the message “[sudo] password or pi”.
        pi@MagicMirror-live:~$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                \______/
        install log being saved to /home/pi/install.log
        Installing helper tools ...
        [sudo] password for pi:
        But you just said that the installation under “root” (sudo) is not good? Yes what is right now? What do I have to do now?
        Do I have to insert “su” here then??
        I don’t have a “sudo” password for pi - how do I create it?
        Do I have to log in again with “pi” and the default pass and then create a “root” pass for pi?
        and if I then take the root password from my created LXC container, it always comes “sorry try again”.
        Sorry, try again.
        What am I doing wrong here?
        This is what I do not understand and do not know. Can you please describe me this in understandable sentences briefly how I have to proceed with the installation?
        Thank you
        • kusselinK Offline
          kusselin
          so installed again under “pi”…
          Commands executed by you here the result:
          login as: pi
          Last login: Sun Oct 16 09:53:33 2022 from 192.168.1.236
          pi@MagicMirror-live:~$ cd MagicMirror
          pi@MagicMirror-live:~/MagicMirror$ pm2 start MagicMirror
          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
          [PM2] [MagicMirror](0) ✓
          [PM2] Process successfully started
          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
          │ 0  │ MagicMirror        │ fork     │ 143  │ online    │ 0%       │ 4.0kb    │
          pi@MagicMirror-live:~/MagicMirror$ pm2 status
          │ 0  │ MagicMirror        │ fork     │ 308  │ online    │ 0%       │ 3.0mb    │
          │ 0  │ MagicMirror        │ fork     │ 363  │ online    │ 0%       │ 4.0kb    │
          If I now enter the following in the browser (Mozilla) then comes network overrun :-(
          http://192.168.200.74:8080
          I don´t know whta i can do :-(
          her my config
          /* MagicMirror² Config Sample
           * By Michael Teeuw https://michaelteeuw.nl
           * MIT Licensed.
           * see https://docs.magicmirror.builders/configuration/introduction.html
           * and https://docs.magicmirror.builders/modules/configuration.html
          let config = {
          	address: "0.0.0.0", 	// Address to listen on, can be:
          	port: 8080,
          	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
          	ipWhitelist: [], 	// Set [] to allow all IP addresses
          	language: "de",
          	locale: "de-DE",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "US Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
          			module: "compliments",
          			position: "lower_third"
          			module: "weather",
          				type: "current",
          				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				apiKey: "YOUR_OPENWEATHER_API_KEY"
          			module: "weather",
          			header: "Weather Forecast",
          				type: "forecast",
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
          installed now is MagicMirror here
          /home/pi/MagicMirror
          • kusselinK Offline
            kusselin
            When everyone have proxmox…please install it and give me feedback how you installed it.
            Thanks a lot
              sdetweil @kusselin
              @kusselin
              change the script that starts mm from
              npm start
              to
              npm run server
              a container has no desktop,
              npm start tries to load the graphical UI using electron.
              npm run server
              just starts the server side, for external browsers to access
              I can’t tell what that error is, but the internet has moved to https connections by default, and many browsers warn when accessing http sites like MagicMirror is running.
              so you either have to accept the warning, or find a way in the browser to disable to message
              https setup requires a certificate, which is not free.
              • kusselinK Offline
                kusselin
                hi sdetweil, sorry my Linux knowledge is not good.
                Can you explain me how to change the script udn where in the script?
                Is my basic installation but with user “pi” so correct
                  sdetweil @kusselin
                  @kusselin my pm2 setup uses
                  ~/MagicMirror/installers/mm.sh
                  kusselinK 1 Reply Last reply Reply Quote 0
                  • kusselinK Offline
                    kusselin @sdetweil
                    this standing in my mm.sh
                    cd ~/MagicMirror
                    DISPLAY=:0 npm start
                    an now i must put this into than looks like this
                    cd ~/MagicMirror
                    npm run server
                    so o.k.?
                      sdetweil @kusselin
                      @kusselin said in MagicMirror install on proxmox LXC Container?:
                      cd ~/MagicMirror
                      npm run server
                      no
                      cd ~/MagicMirror
                      npm run server
                      • kusselinK Offline
                        kusselin
                        o.k…next try to step and hope i can start the MM
                        look…
                        curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                        ## Installing the NodeSource Node.js 18.x repo...
                        ## Populating apt-get cache...
                        + apt-get update
                        Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                        Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                        Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                        Fetched 224 kB in 2s (105 kB/s)
                        Reading package lists... Done
                        ## Confirming "jammy" is supported...
                        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
                        ## Adding the NodeSource signing key to your keyring...
                        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                        ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                        + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
                        + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
                        ## Running `apt-get update` for you...
                        + apt-get update
                        Get:1 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
                        Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                        Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                        Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [775 B]
                        Fetched 5338 B in 2s (2387 B/s)
                        ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                        ## You may also need development tools to build native addons:
                             sudo apt-get install gcc g++ make
                        ## To install the Yarn package manager, run:
                             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                             echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                             sudo apt-get update && sudo apt-get install yarn
                        pi@MagicMirror-live:~$ sudo apt-get update && sudo apt-get install yarn
                        Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
                        Building dependency tree... Done
                        Reading state information... Done
                        Note, selecting 'cmdtest' instead of 'yarn'
                        The following additional packages will be installed:
                          python3-cliapp python3-importlib-metadata python3-markdown
                          python3-more-itertools python3-pygments python3-ttystatus python3-zipp
                        Suggested packages:
                          python3-xdg python-markdown-doc python-pygments-doc ttf-bitstream-vera
                        The following NEW packages will be installed:
                          cmdtest python3-cliapp python3-importlib-metadata python3-markdown
                        0 upgraded, 8 newly installed, 0 to remove and 1 not upgraded.
                        Need to get 969 kB of archives.
                        After this operation, 5201 kB of additional disk space will be used.
                        Do you want to continue? [Y/n] Y
                        Get:1 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-cliapp all 1.20180812.1-4 [44.5 kB]
                        Get:2 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-more-itertools all 8.10.0-2 [47.9 kB]
                        Get:3 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-zipp all 1.0.0-3 [5440 B]
                        Get:4 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-importlib-metadata all 4.6.4-1 [16.2 kB]
                        Get:5 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-markdown all 3.3.6-1 [68.5 kB]
                        Get:6 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-ttystatus all 0.38-4 [14.7 kB]
                        Get:7 http://archive.ubuntu.com/ubuntu jammy/universe amd64 cmdtest all 0.32.14.gcdfe14e-2 [21.9 kB]
                        Get:8 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-pygments all 2.11.2+dfsg-2 [750 kB]
                        Fetched 969 kB in 1s (911 kB/s)
                        Selecting previously unselected package python3-cliapp.
                        (Reading database ... 29455 files and directories currently installed.)
                        Preparing to unpack .../0-python3-cliapp_1.20180812.1-4_all.deb ...
                        Unpacking python3-cliapp (1.20180812.1-4) ...
                        Selecting previously unselected package python3-more-itertools.
                        Preparing to unpack .../1-python3-more-itertools_8.10.0-2_all.deb ...
                        Unpacking python3-more-itertools (8.10.0-2) ...
                        Selecting previously unselected package python3-zipp.
                        Preparing to unpack .../2-python3-zipp_1.0.0-3_all.deb ...
                        Unpacking python3-zipp (1.0.0-3) ...
                        Selecting previously unselected package python3-importlib-metadata.
                        Preparing to unpack .../3-python3-importlib-metadata_4.6.4-1_all.deb ...
                        Unpacking python3-importlib-metadata (4.6.4-1) ...
                        Selecting previously unselected package python3-markdown.
                        Preparing to unpack .../4-python3-markdown_3.3.6-1_all.deb ...
                        Unpacking python3-markdown (3.3.6-1) ...
                        Selecting previously unselected package python3-ttystatus.
                        Preparing to unpack .../5-python3-ttystatus_0.38-4_all.deb ...
                        Unpacking python3-ttystatus (0.38-4) ...
                        Selecting previously unselected package cmdtest.
                        Preparing to unpack .../6-cmdtest_0.32.14.gcdfe14e-2_all.deb ...
                        Unpacking cmdtest (0.32.14.gcdfe14e-2) ...
                        Selecting previously unselected package python3-pygments.
                        Preparing to unpack .../7-python3-pygments_2.11.2+dfsg-2_all.deb ...
                        Unpacking python3-pygments (2.11.2+dfsg-2) ...
                        Setting up python3-ttystatus (0.38-4) ...
                        Setting up python3-more-itertools (8.10.0-2) ...
                        Setting up python3-zipp (1.0.0-3) ...
                        Setting up python3-cliapp (1.20180812.1-4) ...
                        Setting up python3-pygments (2.11.2+dfsg-2) ...
                        Setting up python3-importlib-metadata (4.6.4-1) ...
                        Setting up python3-markdown (3.3.6-1) ...
                        Setting up cmdtest (0.32.14.gcdfe14e-2) ...
                        Processing triggers for man-db (2.10.2-1) ...
                        pi@MagicMirror-live:~$ sudo apt install -y nodejs
                        The following packages will be upgraded:
                          nodejs
                        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 28.5 MB of archives.
                        After this operation, 52.4 MB of additional disk space will be used.
                        Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.11.0-deb-1nodesource1 [28.5 MB]
                        Fetched 28.5 MB in 1s (22.4 MB/s)
                        (Reading database ... 29937 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.11.0-deb-1nodesource1_amd64.deb ...
                        Unpacking nodejs (18.11.0-deb-1nodesource1) over (16.17.1-deb-1nodesource1) ...
                        Setting up nodejs (18.11.0-deb-1nodesource1) ...
                        pi@MagicMirror-live:~$ git clone https://github.com/MichMich/MagicMirror
                        Cloning into 'MagicMirror'...
                        remote: Enumerating objects: 23768, done.
                        remote: Counting objects: 100% (1/1), done.
                        remote: Total 23768 (delta 0), reused 1 (delta 0), pack-reused 23767
                        Receiving objects: 100% (23768/23768), 19.76 MiB | 12.35 MiB/s, done.
                        Resolving deltas: 100% (14649/14649), done.
                        pi@MagicMirror-live:~$ cd MagicMirror/
                        pi@MagicMirror-live:~/MagicMirror$ npm run install-mm
                        > magicmirror@2.21.0 install-mm
                        > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                        npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                        > magicmirror@2.21.0 postinstall
                        > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                        > magicmirror@2.21.0 install-vendor
                        > echo "Installing vendor files ...
                        > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                        added 9 packages in 5s
                        > magicmirror@2.21.0 install-fonts
                        > echo "Installing fonts ...
                        > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                        added 2 packages in 1s
                        > magicmirror@2.21.0 prepare
                        > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                        no husky installed.
                        added 300 packages in 36s
                        pi@MagicMirror-live:~/MagicMirror$ cp config/config.js.sample config/config.js
                        pi@MagicMirror-live:~/MagicMirror$ npm run server
                        > magicmirror@2.21.0 server
                        > node ./serveronly
                        [16.10.2022 13:16.02.218] [LOG]   Starting MagicMirror: v2.21.0
                        [16.10.2022 13:16.02.225] [LOG]   Loading config ...
                        [16.10.2022 13:16.02.235] [LOG]   Loading module helpers ...
                        [16.10.2022 13:16.02.236] [LOG]   No helper found for module: alert.
                        [16.10.2022 13:16.02.252] [LOG]   Initializing new module helper ...
                        [16.10.2022 13:16.02.254] [LOG]   Module helper loaded: updatenotification
                        [16.10.2022 13:16.02.254] [LOG]   No helper found for module: clock.
                        [16.10.2022 13:16.02.513] [LOG]   Initializing new module helper ...
                        [16.10.2022 13:16.02.514] [LOG]   Module helper loaded: calendar
                        [16.10.2022 13:16.02.515] [LOG]   No helper found for module: compliments.
                        [16.10.2022 13:16.02.516] [LOG]   No helper found for module: weather.
                        [16.10.2022 13:16.02.536] [LOG]   Initializing new module helper ...
                        [16.10.2022 13:16.02.536] [LOG]   Module helper loaded: newsfeed
                        [16.10.2022 13:16.02.536] [LOG]   All module helpers loaded.
                        [16.10.2022 13:16.02.679] [LOG]   Starting server on port 8080 ...
                        [16.10.2022 13:16.02.695] [LOG]   Server started ...
                        [16.10.2022 13:16.02.696] [LOG]   Connecting socket for: updatenotification
                        [16.10.2022 13:16.02.696] [LOG]   Starting module helper: updatenotification
                        [16.10.2022 13:16.02.697] [LOG]   Connecting socket for: calendar
                        [16.10.2022 13:16.02.697] [LOG]   Starting node helper for: calendar
                        [16.10.2022 13:16.02.697] [LOG]   Connecting socket for: newsfeed
                        [16.10.2022 13:16.02.698] [LOG]   Starting node helper for: newsfeed
                        [16.10.2022 13:16.02.698] [LOG]   Sockets connected & modules started ...
                        Ready to go! Please point your browser to: http://localhost:8080
                        is this now right abd is the info “no helper module” O.K.?
                        best regards
                        P.S. when i put “http://localhost:8080” in the browser linie - it´s not going :-(
                        • 3 / 4
