    CORS, MotionEye & MMM-Remote-Control
    13 Posts 4 Posters 5.5k Views 4 Watching
      SdeGeata
      So this is not so much of a bug as a conflict within the system. It seems that since verson 2.17, CORS is preventing MMM-MotionEye from loading an image. I just get a broken image icon. If I change address: "0.0.0.0", to address: "localhost",, I get an image, but can no-longer run it from the web interface or command line. Further, MMM-Remote-Control requires address: "0.0.0.0", be set in config.js.
      I have messed with all kinds of ip whitelist stuff to no avail, as well as played with all kinds of options in motion.conf and motioneye.conf. Nothing seems to work.
      Does anyone here have a solution or work-around? I can’t get any answer back on the MotionEye Git Hub.
      Any help would be greatly appreciated! I need this module to work!
        sdetweil @SdeGeata
        @SdeGeata try the real ip address of the pi in the address:“???”
        192.168.??.??
        this I consider to be a NETWORKING error…
        if I am listening on all interfaces, (0,0,0,0) and I send a request out… it should USE one of them
        not send 0.0.0.0 to the remote site…
          SdeGeata @sdetweil
          @sdetweil Hello Sam;
          In playing with the address, I have discovered that MotionEye does seem to display an image using address: "192.168.1.200", (the direct URL of the Magic Mirror, and running MotionEye). However, Motion Webhooks show the image then won’t hide anymore. They just stay onscreen.
          Currently, I have my config set as so:
          address: "0.0.0.0",
          ipWhitelist: ["::1", "::ffff:192.168.1.200", "::ffff:192.168.1.1/120", "127.0.0.1", "::ffff:127.0.0.1", "::ffff:192.168.1.42", "::ffff:192.168.1.23", "::ffff:192.168.1.69", "::ffff:192.168.1.100"],
          trying to cover all bases here. The Mirror still shows a broken image icon, but if I log into the web portal of the mirror, that show’s the camera feed no problem. How can I fix this??>
          S S 2 Replies Last reply Reply Quote 0
            SdeGeata @SdeGeata
            I did notice that MotionEye and the Mirror are both listening on “0.0.0.0”. Is that normal? Could that be my conflict? Can i set MotionEye to listen on another ip, if so, which one???
              sdetweil @SdeGeata
              @SdeGeata turn off the ipWhitelist til you get it all working. then play with the filter
                sdetweil @SdeGeata
                @SdeGeata the cors check is at the server.
                they check the IP address/name of the client making the request.
                localhost is inside the same system
                192.168 or 10. or 172. are non routablebip addresses, so sekfvcontainedvsyatens like localhost
                0.0.0.0 is undetermined… and is mostly rejected .
                as I said, it’s not a valid IP address, so it should never be sent to the other side as part of the request
                  SdeGeata @sdetweil
                  I turned off the ipWhitelist, I was unable to connect MMM-Remote-Control or send any command line to the MM.
                    SdeGeata @sdetweil
                    @sdetweil said in CORS, MotionEye & MMM-Remote-Control:
                    Its funny though, it is only since MM v.2.17 I have been having issues with MMM_MotionEye and the address: "0.0.0.0" issue. It was fine before. I don’t know what changed other than CORS.
                    S karsten13K 2 Replies Last reply Reply Quote 0
                      sdetweil @SdeGeata
                      @SdeGeata we updated libraries we use, so it could be anywhere.
                        SdeGeata @sdetweil
                        @sdetweil So what would you suggest? Is there another address I can have MotionEye listen on while leaving the Magic Mirror address on 0.0.0.0? I see an option to configure that in MotionEye.conf. I just don’t know what to set it to.
                          sdetweil @SdeGeata
                          @SdeGeata the physical adapter ip address
                          the command
                          ip addr
                          will give you the configured addesses
                          • karsten13K Offline
                            karsten13 @SdeGeata
                            @SdeGeata
                            MM is an electron app and electron uses chromium as browser. All browsers are more and more restrictive concerning cors when releasing new versions.
                            I tested MMM-Motioneye with my setup and was not able to get it running.
                            Another approach is to use MMM-iFrame instead which worked on my side.
                              SdeGeata @karsten13
                              @karsten13 Yeah, I was messing with that a little today. I couldn’t find an iframe that was reliable enough.
                              I ended up installing a Home Assistant add-on called go2rtc to serve the video and on the magic mirror, I installed the MMM-WebView module. It works a lot like an iFrame but more stable.
                              So far, it seems to be working. I have MotionEye and SecuritySpy sending command line webhooks upon motion triggers to Home Assistant that in turn shows and hides the module on the magic mirror. I would have liked to get MotionEye working, but this actually sems faster and more stable.
                              Thanks so much for your help though, to both of you.
