    MM Ver.2.21 Electron failed to install error
    6 Posts 2 Posters 3.0k Views 2 Watching
      Rags
      I just updated to ver 2.21. MM crashed and no longer working. npm start shows error
      magicmirror@2.21.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      /home/pi/MagicMirror/node_modules/electron/index.js:17
      throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’);
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
      at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:17:11)
      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:21:18)
      at Module._compile (node:internal/modules/cjs/loader:1155:14)
      at Object.Module._extensions…js (node:internal/modules/cjs/loader:1209:10)
      at Module.load (node:internal/modules/cjs/loader:1033:32)
      at Function.Module._load (node:internal/modules/cjs/loader:868:12)
      at Module.require (node:internal/modules/cjs/loader:1057:19)
      at require (node:internal/modules/cjs/helpers:103:18)
      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:18)
      Please help in resolving issue. A step by step instructions would help. I dont want to reinstall MM all over again. Adding all modules and reconfiguring the config.js file is not an option.
      Thanks.
        sdetweil @Rags
        @Rags how did u update? manual git pull/npm install or my upgrade script?
        can you show output of
        uname -a
        lsb_release -a
        node -v
        npm -v
        u ‘might’ have luck with
        cd ~/MagicMirror
        npm install electron@19.1.0
        report the results.
          sdetweil @Rags
          @Rags also if you use something like my backup/restore it could save you literally DAYS of work
          see
          and my script repo, install/upgrade
            Rags @sdetweil
            I did a git pull in MM directory.
            However before that i had tried to install MMM-json-feed which failed during installation. I guess it must have messed up the electron somhow.
            uname -a
            Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
            npm -v 9.1.2
            node -v 16.8.1
            when i do a npm install electron@19.1.0 i get
            pi@raspberrypi:~/MagicMirror $ npm install electron@19.1.0
            npm ERR! code ENOTEMPTY
            npm ERR! syscall rename
            npm ERR! path /home/pi/MagicMirror/node_modules/ip6
            npm ERR! dest /home/pi/MagicMirror/node_modules/.ip6-Ll8TJZWc
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename ‘/home/pi/MagicMirror/node_modules/ip6’ -> ‘/home/pi/MagicMirror/node_modules/.ip6-Ll8TJZWc’
            npm ERR! /home/pi/.npm/_logs/2022-11-24T16_02_00_445Z-debug-0.log
              sdetweil @Rags
              @Rags ok best to clean
              do
              cd ~/MagicMirror
              rm -rf node_modules
              rm package-lock.json
              npm install --omit=dev  --no-audit --no-fund
                Rags @sdetweil
                Bingo. All systems go…
                Thanks once again.
                I am doing the backup restore thing now.
